BMW e36 v e46 M3, which is the better car? | FerrariChat
Discussion in 'Other German' started by Texas Forever, Apr 26, 2020.
  1. Texas Forever
    Texas Forever Seven Time F1 World Champ
    76,211
    Texas!
    I think I asked this question a long time ago, but I can't find the thread.
    Which do you think is the better DRIVING car? I know the e46s are faster, but I don't go 170 mph. Said another way, which car is more fun at legal speeds?
    Thoughts?
  2. flat_plane_eddie
    flat_plane_eddie F1 Rookie
    Mar 30, 2013
    3,143
    NE FL
    Eddie
    The American E36 M3 isn't really an M3 so my vote goes to the E46.
    m5shiv and Flavio_C like this.
  3. Texas Forever
    76,211
    Texas!
    Eh?
  4. RaceMX-M3
    RaceMX-M3 Formula Junior
    Dec 15, 2010
    527
    Frisco, TX
    Scott
    I didn't spend enough time driving the E36 to give thoughtful differences but owned the E46 for years and loved it. I had three of them.
    Flavio_C and Texas Forever like this.
  5. Jorligan
    Jorligan Formula Junior
    266
    Dexter, MI
    Tim
    I had an E46 and an E92, E46 better than the E36 for the street, e92 M3 is better yet for the street but if you are going to track the car, I would go with the E36. Lighter and more fun to toss around.
    Texas Forever likes this.
  6. fatbillybob
    Aug 10, 2002
    26,430
    socal
    A low mile E46M3 6spd it the best "M" BMW has ever made.
    Performify, gt1995, m5shiv and 3 others like this.
  7. fatbillybob
    Aug 10, 2002
    26,430
    socal
    I also worked on E36, E46, and E92. The E92 is down right painful and stupid in design. Many design things are almost as bad as a Ford. The 36 is easiest for diy. But the 46 is very doable and has much more intelligent systems than the 92+. When I worked on my 1st 46 I was shocked at how well done it was.
  8. flat_plane_eddie
    Mar 30, 2013
    3,143
    NE FL
    Eddie
    Care to elaborate more on the bad designs of the E92?
  9. 19633500GT
    19633500GT F1 World Champ
    12,023
    Blueberry
    Muffin-Tops
    Got all four wheels of my E36 M3 off the ground on a nice bender, top of fourth gear.
    Driven a lot of BMW M cars, and I prefer the E36. The E46 is beyond fantastic, I just can't drive it anywhere as close to the limits as I could with the 36.
  10. ttforcefed
    ttforcefed F1 World Champ
    18,876
    i have 2 e36 M3s so im biased. didnt love my e46. hated the clutch when it was in sport.
  11. fatbillybob
    Aug 10, 2002
    26,430
    socal
    Let's see 8 or 9 seals for the 6 cylinder valve cover. My V12 Ferrari isn't that complicated. Dumb electric water pump. I had 4 of those in 1 car 0-100000 miles. Finally stopped using the BMW boxed WP and put the cheapest POS I could find and that one stayed working. You almost never have a conventional pump fail and strand you. A conventional pump 99% of the time gives you plenty of warning. Can you imagine oil leaks from the top mount filter housing all of a sudden? How about failed filter base gasket and 2 bolts no problem and 1 bolt you have to take the intake manifold off! Why not just turn the bolt around and thread it the other way? I have nothing but praises for early BMW's. I absolutely despise late model BMWs. The only thing I hate working on worse is the mustang GT that I race. But it is good to hate your racecar so you can beat the living snot out of it on track.
    m5shiv and Texas Forever like this.
  12. m5shiv
    m5shiv Formula 3
    1,259
    SF Bay Area
    Shiv
    I have 2 x e46 M3, since the E36 m3 USA doesn't come with a 321 hp Evo motor, it's not a valid choice for US owners.
    AtSomePoint likes this.
  13. fatbillybob
    Aug 10, 2002
    26,430
    socal
    I knew a guy in cali who raced the E36 with that motor in it. He got the motor from overseas and put it in his donor racecar. That car was fast and handled well. He put that thing just about anywhere on the track.
  14. Texas Forever
    76,211
    Texas!
    Keep in mind I lean toward the “it’s more fun to drive a slow car fast than a fast car slow” school. I have even been known, gasp, to drive a Miata. But, don’t worry, I put a paper bag over my head. I was The Who Dat man.
  15. flat_plane_eddie
    Mar 30, 2013
    3,143
    NE FL
    Eddie
    Sorry I'm confused since you said 6 cylinder valve cover above but your prior post said the E92 is poorly designed. Are you referring to the E92 above?
  16. fatbillybob
    Aug 10, 2002
    26,430
    socal
    Sorry to confuse you. E9X all suck.
    E92M3 was no gem. DCT failed on track often. I think they could never be kept cool? That s65 motor would eat itself at street speeds from an undiagnosed and never solved bearing issue. The aftermarket claimed a fix by changing main bearings...not an easy job but the fix was questionable. The run on that motor was 5+ years and bmw never, acknowledged or attempted a fix.
  17. m5shiv
    m5shiv Formula 3
    1,259
    SF Bay Area
    Shiv
    E60 M5 suffers from same rod bearing issues
  18. ttforcefed
    18,876
    no need to import a european motor. for 10K you can do this to your s52:
    87mm bore 11:5 compression
    custom grind cams
    BBTB
    PnP Head, stock valve springs, stock size ferrea valves.
    Obd I manifold
    SS Euro long tube headers and full catless Euro SS midsection and axleback.
    RK custom dyno tune 93 pump.
    Porsche HFM
    24lbs injectors
    CAI
  19. flat_plane_eddie
    Mar 30, 2013
    3,143
    NE FL
    Eddie
    OK thanks. I really like the E92 and know of its shortcomings regarding the rod bearings and actuators but just wanted to get more info.
    The S65 is a chopped down S85 but at least on the S65 they fixed the VANOS pump issues.
  20. fatbillybob
    Aug 10, 2002
    26,430
    socal
    A lot of money for 300HP and questionable reliability. Problem is you can build a perfect motor on paper. The reality is even harder and finding a competent builder for even simple motors is nearly a lost art. I went through 4 simple stock LS6 GM motor builds before I got a reliable one and that one still wasn't as good as the one that came with the car! We racers suffer from this all the time and are blamed for the failures because we are racing. The truth is street use disguises the builder's shortcomings. Whenever you can buy a crate motor from the factory that's what you want to do unless you are building for something else.
  21. ttforcefed
    18,876
    thats a real build, local to me...10K is not much for that...going with a GM motor is sacrilegious to me.
  22. otoupalik
    otoupalik Formula Junior
    345
    Scottsdale, AZ
    Brad Otoupalik
    I have owned multiple trim levels/styles of both the e36 and e46. The only one I still have is an e46 M3 cab. The e46 is truly more enjoyable in every way.
