430 - Best $100 you will and can ever spend on your car - specially if you work on it yourself. | FerrariChat
430 Best $100 you will and can ever spend on your car - specially if you work on it yourself.
Discussion in '360/430' started by carguy007, Apr 9, 2021.
  1. carguy007
    carguy007 Formula Junior
    Apr 24, 2013
    891
    Gentlemen,
    For anyone that works on their car of wants to have some insights to general health I highly reccoment you get the ThinkDiag tool. It appears to be the same software as Launch x431 but for just $120 and work with your Andriod or IOS device effortlessly.
    Each year will cost you $39 to resubscribe to the Ferrari Manufacture Software.
    It will be the best money you ever spend for your car. You can do everything: F! self learn, Clutch Read, PIS setting, manufacture specific cel.
    I have a coupon code that knocks it down to $100 bucks for those interested shoot me a PM. Here is the device and so info. I reccoment ordering from Amazon.
    https://www.cnautotool.com/goods-6964-Launch-Thinkdiag-Full-System-OBD2-Diagnostic-Tool.html?gclid=CjwKCAjw9r-DBhBxEiwA9qYUpYVdZqHXO_FpXcaRKQwKpnIhmh2Rcgbrz3O_RcPow2h-TNJ169U6GRoCGkUQAvD_BwE
    veilstylez, Jaymac, RedNeck and 4 others like this.
  2. carguy007
    Apr 24, 2013
    891
    Credit for this find @flash32 for Dominick pointing me in this direction when inquiring about the Launch x431.
    Jaymac and flash32 like this.
  3. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,856
    Central NJ
    Dominick
    Glad it all worked out for you ..and thanks for being the guinea pig for all of us
    If you have any questions on the use of the device let me know if I can help
    Jaymac likes this.
  4. Patrickd_21
    Patrickd_21 Rookie
    Feb 9, 2020
    16
    Montreal Quebec
    Patrick D
    Very cool! Pm'ed you for the coupon code.
  5. CoreyNJ
    CoreyNJ Formula 3
    2,421
    New Jersey Shore
  6. MJGinTX
    MJGinTX Karting
    Mar 30, 2019
    161
    Indianapolis, IN
    Thank you. Do you know if it will do the F1 bleed?
    Matt
  7. Ghostdiver
    Ghostdiver Formula 3
    Mar 18, 2005
    1,348
    Southeast Texas
    Wally Hollar
    Interested as well. Can this be used to set the PIS?
    PM sent too...
    PKIM likes this.
  8. 02360spider
    02360spider Formula 3
    May 27, 2015
    1,749
    Dartmouth
    Richard oliveira
    Just ordered it only $92?
    Sent from my SM-G996U1 using Tapatalk
  9. CarAholic
    CarAholic Formula Junior
    May 10, 2016
    519
    Looks interesting wonder if it works with newer Porsches too
  10. carguy007
    Apr 24, 2013
    891
    Yes it can work for other models but that is dependent on the software they stole. It's bidirectional meaning it can imput and turn on sensor and actuators. Clutch read and PIS are not an issue. The amount of data this thing extracts from your car will blow your mind. You can set up live logging too of a pump, or O2 etc. Just buiy it.
    Jaymac likes this.
  11. 02360spider
    May 27, 2015
    1,749
    Dartmouth
    Richard oliveira
    I'm excited for it to come in
  12. BrettC
    BrettC Formula 3
    Aug 13, 2012
    2,113
    Calif
    Brett
    So.......with a 3 pedal 360 would I find it useful and for what? Thanks
  13. brogenville
    brogenville Formula 3
    2,252
    Robin
    Some possible uses:
    ABS pump cycling for full brake fluid bleeding.
    Live data monitoring on the engine.
    Actuator tests if it can do them.
    BrettC likes this.
  14. Smiles
    Smiles F1 World Champ
    Nov 20, 2003
    16,673
    Pittsburgh, PA
    Matt F
    Will the software be compatible with McLaren? I don’t see it listed.
    Matt
  15. 02360spider
    May 27, 2015
    1,749
    Dartmouth
    Richard oliveira
    I wonder if it bleeds the f1 system
  16. Daryl Zernick
    Daryl Zernick Formula Junior
    Jul 7, 2020
    261
    South Bend, IN
    Daryl A. Zernick
    I bought a Foxwell NT510 Elite, but found it problematic in finding the right test program to run and the results were difficult to interpret. Would you say this device is better on all counts?
  17. Skippr1999
    Skippr1999 F1 Rookie
    4,497
    Will it do a 355F1 ?
  18. MJGinTX
    MJGinTX Karting
    Mar 30, 2019
    161
    Indianapolis, IN
    I am wondering the same thing. Can someone (who has this unit) comment as to whether it will bleed the F1 system?
    02360spider likes this.
  19. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,856
    Central NJ
    Dominick
    Considering the OP has done that and the software is pretty much the same as the x431 - i would say it does .. can't be to sure with older 360 where various diag tools have trouble connect to TCU
  20. ItalienCar
    ItalienCar Karting
    Nov 12, 2016
    66
    California
    When you say “older 360”, do you mean 360s as a whole, or certain production years?
    Trying to figure out if this is only useable on 430 and up...
  21. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,856
    Central NJ
    Dominick
    Older meaning meaning older 360 .. not sure what year the tcu changed to allow communication they the oBd port .. I know the 360cs works well .. I am sure someone else can chime in about vin number that the tcu can be read thru obd port
  22. 02360spider
    May 27, 2015
    1,749
    Dartmouth
    Richard oliveira
    Mine is a 2000 and I had to switch it to a 2002 tcu to do a cs flash and be able to adjust pis.
  23. curtisc63
    curtisc63 Formula 3
    Dec 13, 2005
    2,290
    Maryland
    Curtis Campbell
    I have an OLD OBDII reader and looking to upgrade to one with more capabilities. Reading through this thread may push me to actually buy one. Just a couple questions:
    1. I can check codes from the OBDii system on any car with no additional S/W, correct? I just need a manufacturer pack if I want to dig deeper.
    2. What does the "RESET" Subscrition bring? Can I not clear a code with the regular subscription? Is this for other operations beyond std OBD functions?
    Thanks for the help.
    BTW Amazon now lists a 2021 updated version for this unit. Same $99 price.
    https://www.amazon.com/dp/B08G4MNHP9/ref=sspa_dk_detail_1?psc=1&pd_rd_i=B08G4MNHP9&pd_rd_w=QWGJp&pf_rd_p=085568d9-3b13-4ac1-8ae4-24a26c00cb0c&pd_rd_wg=Cu685&pf_rd_r=1MNAD0E3G97XQM08ES7M&pd_rd_r=982cad7a-f5e4-4f59-89f9-90124b416f07&spLa=ZW5jcnlwdGVkUXVhbGlmaWVyPUEyM0VEQ1pQNUlTVkFKJmVuY3J5cHRlZElkPUEwMzUyNzc3MjVLMkc4QU8xWlVDRCZlbmNyeXB0ZWRBZElkPUEwOTYwODgxMTZKTTRORFUwQ1dZViZ3aWRnZXROYW1lPXNwX2RldGFpbCZhY3Rpb249Y2xpY2tSZWRpcmVjdCZkb05vdExvZ0NsaWNrPXRydWU=#customerReviews
  24. ChipM
    ChipM Rookie
    Jan 1, 2013
    40
    Spartanburg, SC
    Chip McLeod
    Some older comments here but maybe it will help others. I have been trying to resolve the passenger seat weight sensing system due to a constant "airbag on" then "airbag off" message. When someone is in the seat it seems to function fine. I removed the seat the and in the meantime have set off the airbag light and symbol on the TFT screen. My AL619 and my Foxwell NT510 Elite (with up-to-date Ferrari software) cannot connect to the SRS. I have been reading about the Think Diag, probably the Think Scan Plus S7. Has anyone had success with that with a SRS in a 612 or other similar period/weight sensing F-car? Thanks.
