Battery tie down | FerrariChat
Battery tie down
Discussion in 'Boxers/TR/M' started by kartboy1234, Feb 3, 2020.
  1. kartboy1234
    kartboy1234 Formula Junior
    Nov 10, 2014
    723
    Palos Verdes, CA
    Michael L
    Hello everyone, I am replacing my 7 year old battery with a new one. I have found many threads on what battery to buy, but im having issues with how to strap it down. Can someone take a picture of their stock tiedown for the battery? Mine isn't strapped down at all and slides around while driving.
    It looks like it's a metal bracket that uses a long screw to hold it in, I think.
    Thank you.
    Sent from my GM1917 using Tapatalk
  2. vincenzo
    vincenzo F1 Rookie
    Nov 2, 2003
    3,373
    Yes...
    Long bolt that secures the clamp holding the battery down at its base.
    White wire is a SR fuse box upgrade. Connector is for trickle charger. Yellow mat stops acid from reaching the car.
    Previously used an Interstate MTP-91 (700 CCA) which is no longer available. They tell me the MTP-48-H6 (730 CCA) is the new replacement.
    The MTP-91 has an oval vent on the terminal side at top middle. It points directly at the hold down bolt.... not good. I think (?) the MTP-48-H6 has side vents... if so, much better because I can connect a vent tube. Planning to pick one up tomorrow. We’ll see.
    https://www.interstatebatteries.com/products/mtp-48-h6
  3. ago car nut
    ago car nut F1 Veteran
    5,495
    Madison Ohio
    David A.
    Grease the bottom of the tray, reduces corrosion.
    Shamile and turbo-joe like this.
  4. kartboy1234
    Nov 10, 2014
    723
    Palos Verdes, CA
    Michael L
    Thank you for the help. My problem was that my battery was the wrong size. So I purchased the right size. Now I'll buy the hold down clamp and the screw
    vincenzo likes this.
