BATTERY DRAIN F512M | FerrariChat
BATTERY DRAIN F512M
Discussion in 'Boxers/TR/M' started by HOU, Nov 3, 2019.
  1. HOU
    HOU Karting
    May 2, 2009
    88
    Houston, Texas
    John S
    my 66K mi. M has developed a significant battery drain
    overnight the voltage reads 11.4 at the engine starter terminal
    the battery is new interstate
    any suggestions where i should look first ?
    thanks in advance.........
    john s
  2. Shamile
    Shamile F1 Veteran
    Dec 31, 2002
    6,712
    Lakeland FL
    Shamile
    The only thing that comes to mind is that your alternator has gone bad and one of the electronic internals...rectifier? is passing through the current...something like that.
    I had that happen on a 308 gtsi I owned a gazillion years ago. A rebuild of the alternator solved the problem.
    Shamile
    Freeze....Miami Vice!
    Sent from my SM-G950U using Tapatalk
    Natkingcolebasket69 likes this.
  3. Rifledriver
    37,043
    Put an amp meter between the battery and the car and start pulling fuses until draw goes down to normal (25mA or so). That will narrow it down quickly. As I recall ignition, the Motronic boxes and starting/charging systems are the only unfused systems. The most common culprits are non factory installations, radio, phone, alarm.
  4. Shamile
    Shamile F1 Veteran
    Dec 31, 2002
    6,712
    Lakeland FL
    Shamile
    Daymn...that's a good trouble shooting method...I like that!
    Shamile
  5. Natkingcolebasket69
    Natkingcolebasket69 F1 World Champ
    Agreed -my alarm used to drain the battery pretty bad, also a non functioning radar which I got rid of.
  6. tf308
    tf308 Formula 3
    Dec 14, 2003
    1,168
    Virginia Beach
    Tim
    Watch a new video from Scotty Kilmer on YouTube....he goes over how to do this. It’s a good skill to learn and use.
