Another 6spd conversion! | Page 5 | FerrariChat
Discussion in '360/430' started by jg360, Apr 9, 2020.
  1. jg360
    jg360 Formula Junior
    319
    New Jersey
    John Gurrieri
  2. jg360
    319
    New Jersey
    John Gurrieri
  3. 24000rpm
    24000rpm F1 Rookie
  4. jg360
    319
    New Jersey
    John Gurrieri
    Yeap. It wasn’t that bad to do.
  5. one4torque
    one4torque F1 Veteran
    5,123
    Houston
    One4torque
    Killer build! How bad was the trans to stab and line up? I presume the clutch kit comes w a pilot tool?
  6. brogenville
    brogenville Formula 3
    2,020
    Robin
    Didn’t come with one when I did my 360’s clutch. Helpfully Ferrari put the required dimensions of the tool in the workshop manual. If you know someone with a lathe then you can get one turned up very easily.
  7. duskybird
    duskybird F1 World Champ
    11,995
    29 Electoral Votes
    Bill B.
    They are very easy to make. I've made several for friends over the years. The water pump seal tool is also pretty easy to knock out.
    I've made them out of both aluminum and delrin depending on what I had on hand.
    one4torque likes this.
  8. jg360
    319
    New Jersey
    John Gurrieri
    It actually really easy. Slid right in. I installed it by myself. Strapped the trans to my floor jack and pushed it right in. This was one of the easiest install I have ever done. Everything right from the top.
    I didn’t have an alignment tool so I made one with a few sockets and an extension. Worked perfect!
  9. one4torque
    5,123
    Houston
    One4torque
    Short of the overhead cams/belts/variators.... this is easier to work on than a (insert domestic here)......
    Access to the rear-engine area is soooo good.
  10. jg360
    319
    New Jersey
    John Gurrieri
  11. jg360
    319
    New Jersey
    John Gurrieri
    So Excited!!!! went out yesturday for a short test drive to make sure everything is working correctly. Car shifts perfect and the clutch is amazing. I used the kevlar and clutch release is so smooth. Need to make some minor adjustments with the cables and clutch pedal. Also need to finish up welding the clutch pedal. I have a few more parts to reupholster. Trans also shifted perfect with no more grinding. Ill post some more pics as I go along. I still need ti reflash the ecus and dash but that will be my last task as i need to learn more about that.
    AandSC, hessank, brogenville and 2 others like this.
  12. hessank
    hessank Formula 3
    1,748
    Canada, Florida
    Fred
    That is fantastic news John. Congratulations.
    I believe you've just pioneered the use of the kevlar clutch in the 360 manual transmission.
    It has been said that it caused problems with the F1 and so no one wanted to try it out on the gated.
    You're the first.
    Bravo!
  13. brogenville
    2,020
    Robin
    Awesome news. How did you do the clutch pipe then? Braided hose all the way?
    Curious to know how the engine ran in F1 mode too? Did you find the revs hanging during gear changes?
  14. one4torque
    5,123
    Houston
    One4torque
    cool to watch this swap get -de-coded- ...... it is not magic.
  15. DonJuan348
    DonJuan348 F1 Rookie
    Aug 5, 2008
    4,441
    Taxing Jersey
    Where are you located in Jersey?
  16. ItalienCar
    ItalienCar Karting
    Nov 12, 2016
    62
    California
    Awesome work!
    Curious, on the transmission grinding issue, did you just change the synchros and bearings?
  17. xtLSport
    xtLSport Karting
    Dec 18, 2019
    79
    Switzerland
    C.L.
    hats off, you are so skilled. amazing work!!!
  18. jg360
    319
    New Jersey
    John Gurrieri
    I read the same on other forums also. I figured that it can’t be any different than other clutch’s on a manual. It’s amazing how linear it deals and takes off with such ease. Maybe I’ll post a short video
  19. jg360
    319
    New Jersey
    John Gurrieri
    Yes all three synchros and the main bearings.
    hessank and ItalienCar like this.
  20. clean512
    clean512 Formula 3
    2,029
    Josh @jtcarprojects
    Looks great.
  21. jg360
    319
    New Jersey
    John Gurrieri
    North Jersey near Mahwah
  22. jg360
    319
    New Jersey
    John Gurrieri
    So I had a local hydraulic company make a line. I ordered it 10’ with a banjo fitting at the front and make fitting on the other end. I ended up using the original flex line from the f1 system. I just removed it from the upper block and attached to the new flex line. The only thing is that’s it’s not a braided line so this is just temporary until I get a new braided line ordered.
    I did notice that it revs sluggish at the low rpm range. Not crisp as I want it. I’m assuming when I flash it with the new cs maps it will get better. Other than that, it’s just an amazing car as a manual.
  23. brogenville
    2,020
    Robin
    The CS mapping will certainly improve things, as will the removal of the throttle demand delay. Getting it switched to manual mode though will also unlock the clutch pedal switch as an input to the ecu's. This will allow the revs to drop faster when the clutch is depressed. I've no doubt Trev will work his magic for you.
    02360spider likes this.
  24. DonJuan348
    Aug 5, 2008
    4,441
    Taxing Jersey
  25. hessank
    hessank Formula 3
    1,748
    Canada, Florida
    Fred
    Thanks John. Can you share who relined yours?
