Another 6spd conversion! | FerrariChat
Discussion in '360/430' started by jg360, Apr 9, 2020.
  1. jg360
    jg360 Formula Junior
    Feb 8, 2018
    320
    New Jersey
    John Gurrieri
    So I finally was able to get most of the manual parts to convert my car to a stick shift! I purchased this car 2 years ago as a project with the intent to convert it. I Know my car was going to be a big project because it was poorly maintained and needed a lot of care. It start with just the basic tune up and also had some f1 issues. I found out about after a few months that the heat exchanger was bad and had antifreeze in the trans. Not happy because I had no idea how long it was like this. So first major job was the heat exchanger replacement. Afterwords it’s been nothing but issues with the f1 system. I’ve also been converting it to a CS. All exterior finished except mirrors. Have molds and working on fabricating them.
    Since we are all in the situation with the virus and have all this time, I figured I would get started with the interior portion and removal of the trans. After I had the issue with the heat exchanger and fixed most of the issues with the F1 system I was getting gear grinding in all gears, I new my trans was toast. So after pulling the trans apart I found that the synchros were toast! I was able to find the 1st/2nd and 3rd/4th synchros but nothing with 5th/6th. Factory closed for now and don’t now how long it will be before parts are released. ( if any one has one laying around....let me know [emoji20]).
    I’ll post some pics of the progress. I also am having the clutch re-lined with Kevlar. I ordered a new throw out bearing for the manual. So as soon as I get the clutch back I’ll get that in.
    As for the interior, I ordered the alcantara for the interior. My mother was a seamstress and I figured this would be a great time for her also since were all stock inside and would keep her busy. I removed all interior and will start to scrape all of the underpayment off.
    Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
  2. hessank
    hessank Formula 3
    1,911
    Canada, Florida
    Fred
    Dude you have some serious skills. Jealous, of course.
    Please let us know how that install and run goes when you're done. Few people have good results with a kevlar clutch on this car
  3. ItalienCar
    ItalienCar Karting
    Nov 12, 2016
    66
    California
    Were only your synchros damages? I had some coolant go into my transmission as well from the Heat xchanger, replaced, wondering what the extent of the damage might be. Am hearing some occasional grinding in 3rd gear.
  4. carguy007
    carguy007 Formula Junior
    Apr 24, 2013
    891
    How did you manage to get all the parts for the six speed conversion?
    one4torque and gqmd like this.
  5. one4torque
    one4torque F1 Veteran
    5,710
    Houston
    One4torque
    Great post!!!! Subscribed.
    gated cs!!=== dream car
    SoftwareDrone likes this.
  6. gqmd
    gqmd Rookie
    Jul 25, 2017
    46
    Really looking forward to a success story here. Although mine will stay F1 at this time. I am also curious about your source for parts, especially that third pedal.
  7. jg360
    Feb 8, 2018
    320
    New Jersey
    John Gurrieri
    yes just the synchros were bad. I’m replacing the bearings as well since I’m in there. I don’t want to pull the trans again! Not for awhile anyways.
    ItalienCar likes this.
  8. jg360
    Feb 8, 2018
    320
    New Jersey
    John Gurrieri
    A friend of mine who’s was going to convert another car but had a change of heart.
  9. jg360
    Feb 8, 2018
    320
    New Jersey
    John Gurrieri
    Well.....the clutch pedal I have is for a right hand drive so I’ll need to modify it.
    greg328 likes this.
  10. jg360
    Feb 8, 2018
    320
    New Jersey
    John Gurrieri
    Jackson32 likes this.
  11. greg328
    greg328 F1 Rookie
    Nov 17, 2003
    4,209
    Austin, TX USA
    Greg
  12. Nachtfalter
    Nachtfalter Formula Junior
    Feb 28, 2012
    450
    So-Cal
    Perhaps think about making a sand cast or some other form of casting of the pedal and trans linkage. They can be reproduced and sold to lots of people.
  13. jg360
    Feb 8, 2018
    320
    New Jersey
    John Gurrieri
    [emoji848] hmmmm.....
  14. Nachtfalter
    Feb 28, 2012
    450
    So-Cal
    I’m not joking, I know things are a little crazy in Jersey right now but if you could give those parts to a guy that owns a CNC machine.... well, I’m sure I don’t need to help you with the math.
  15. veilstylez
    veilstylez Formula 3
    1,011
    SoCal
    niiiice! and nice to see what what it looks like under the carpets......are you going to paint the floors black like the CS? I want to do this too...can you keep us updated on this process as well too please.
    What did you use to remove the soundproofing?
  16. 24000rpm
    24000rpm F1 Rookie
    after pulling gearboxes for at least 20+times, I can do it for within a few hours now
    good luck with the mirror mold.
    RANDY6005 likes this.
  17. 24000rpm
    24000rpm F1 Rookie
    do you have some close up pic of the synchro? Is the main/lay shaft worn?
  18. one4torque
    5,710
    Houston
    One4torque
    I’m interested in some of the mirror housings if you make a few sets.
    jg360 likes this.
  19. vrsurgeon
    vrsurgeon F1 World Champ
    16,507
    Charleston, SC
    Curt
    This. esp the pedal. If not make an glass fiber/epoxy reproduction.
    EastMemphis likes this.
  20. RedNeck
    RedNeck F1 World Champ
    12,187
    The CSA
    Me
    Fantastic. Glad to see this project panning out. Will be watching along.
  21. brogenville
    brogenville Formula 3
    2,252
    Robin
    You know that European Road and Racing have already done this. See here:
    https://www.ferrarichat.com/forum/threads/360-shift-gate.595591/page-2
    I think EAG has too.
    I had to make my own clutch pedal in CAD for my 612. PM if anyone decides they need one. They're a lovely desk ornament if nothing else!
  22. jg360
    Feb 8, 2018
    320
    New Jersey
    John Gurrieri
    Lmao. It’s actually not that bad capered to most vehicles.
    Mirrors are on hold until I get the trans back in. I need to find someone to make the swivel part also.
  23. G. Pepper
    G. Pepper Three Time F1 World Champ
    38,329
    Texas/Colorado
    George Pepper
    I'm still choosing between a 456M manual, and converting a 612. I've spoken with Art and he has the technical specs to do a 612, but he hasn't done one yet.
    So that could be a good part. I'll keep it in mind.
  24. jg360
    Feb 8, 2018
    320
    New Jersey
    John Gurrieri
    The floors will get the black trim color though-out just like the CS.
    I ended up using and plumbers touch to heat up the soundproofing and a wood chisel to scape it off. Then some paint prep solvent to get the reaming glue off. Worked like a charm. Prior to this I was actually trying to remove it with no heat and realized it would have taken me days!
    veilstylez likes this.
  25. jg360
    Feb 8, 2018
    320
    New Jersey
    John Gurrieri
    not yet, ill take some and post
    catdog likes this.
