Another 6spd conversion! | Page 2 | FerrariChat
Discussion in '360/430' started by jg360, Apr 9, 2020.
  1. jg360
    jg360 Formula Junior
    319
    New Jersey
    John Gurrieri
    I saw your post and the final pedal looks amazing. Would you mind sharing the cad file? Maybe I can modify for the 360?
  2. one4torque
    one4torque F1 Veteran
    5,123
    Houston
    One4torque
    Fyi- I have an aftermarket carbon steel clutch pedal in my e36. You could easily fab a carbon steel clutch pedal as well... until you were able to source the fancy al part.
    EastMemphis and jg360 like this.
  3. brogenville
    brogenville Formula 3
    2,020
    Robin
    360/430 use a completely different pedal box to 599/612- the CAD file honestly wouldn’t help you I’m afraid.
  4. jg360
    319
    New Jersey
    John Gurrieri
    Yes saw online how different they are. Just figured it would help me get started with a cad drawings. Thanks
  5. EastMemphis
    EastMemphis Formula 3
    May 25, 2019
    1,742
    Memphis, TN
    #30 EastMemphis, Apr 10, 2020
    One thing to consider about the clutch pedal. It's not like the brake or gas. People don't punch the clutch or stomp on it. It's gently pressed and rarely to full length. I doubt very much if more than 20 lbs. of force is used to operate it. I had a 40 lb. clutch on my 911 and that one was a bear to operate in traffic but still, not nearly the force the brake can take. I suspect a brake pedal can have 100 lbs. of force applied regularly.
    A carbon or fiberglass pedal with a steel shaft would be fine.
    The gate itself could be made from aluminum with a steel backing plate to keep the aluminum from wearing down. The plate could be water cut and the gate easily machined with the average cnc machine. Another way to make it would be to use aluminized epoxy with the backer plate. It wouldn't be factory but would work great.
    If I ever undertook such a conversion, I would likely make a lot of the parts by copying them from my gated 360. It would be great to do a conversion with a gated car as a model.
  6. veilstylez
    veilstylez Formula Junior
    760
    SoCal
    Niceeeee. Paint prep solvent...like acetone? thank you.
    I was just looked on youtube You think this dry ice method works?
  7. jg360
    319
    New Jersey
    John Gurrieri
  8. veilstylez
    760
    SoCal
    hmmm just found You can freeze it with a can of dust off and use it upside down and freeze the soundproofing.
    one4torque likes this.
  9. veilstylez
    760
    SoCal
    Oh sweet you got it all out. I need to do this too....let us know how the painting the floor process goes too
  10. jg360
    319
    New Jersey
    John Gurrieri
  11. one4torque
    5,123
    Houston
    One4torque
    Looking good! Nice isolation works....
    How heavy is that trans?
  12. jg360
    319
    New Jersey
    John Gurrieri
    Its actually not that bad. I removed it all by myself. used a jack and strapped it to the jack. Moved it back off the motor andthen turned it sideways and lowered under the rear support bar.
    greg328 likes this.
  13. veilstylez
    760
    SoCal
    Thats a lot of skills man!
  14. hessank
    hessank Formula 3
    1,747
    Canada, Florida
    Fred
  15. Bradwilliams
    Bradwilliams F1 Veteran
    Do you have the insructions on how to get around the electrical changes/harnesses? You have some courage and skill!!!
    I think this would be really cool to try on a california.
  16. jg360
    319
    New Jersey
    John Gurrieri
  17. jg360
    319
    New Jersey
    John Gurrieri
    From what I read, there are only 2 Californias ever made!
    As far as instruction, its pretty simple. Ferrari basically built the 360 the same and just added the F1 system the the car. So all of the electrical is basically there. Even the plug for the reverse sensor on the manual shift box. There is only one thing that needs to be changed and thats the bypass loop for the starter, since the F1 provides power from the TCU.
    Bradwilliams likes this.
  18. hessank
    hessank Formula 3
    1,747
    Canada, Florida
    Fred
    Thanks. I can't wait for a report on how that works out because I'd like my next clutch to be kevlar as well.
    jg360 likes this.
  19. 02360spider
    02360spider Formula 3
    1,730
    Dartmouth
    Richard oliveira
    Subscribed let me get my popcorn good stuff.
    Sent from my SM-N975U using Tapatalk
  20. brogenville
    2,020
    Robin
    On the electronics side (you probably already know this), you’ll need to get the ecus reflashed for manual mode, and the get the dash reconfigured for manual.
    Good opportunity to get some tuning upgrades at the same time!
  21. jg360
    319
    New Jersey
    John Gurrieri
    Yea I have the ecu’s going to mase engineering. He’s installing the cs flash and a tune based on my setup. Also have the dash going to FAI for reprogram to a manual.
  22. jg360
    319
    New Jersey
    John Gurrieri
    tifosi101 and duck.co.za like this.
  23. jg360
    319
    New Jersey
    John Gurrieri
  24. jg360
    319
    New Jersey
    John Gurrieri
    greg328 and brogenville like this.
  25. one4torque
    5,123
    Houston
    One4torque
