Adding Pics | FerrariChat
Adding Pics
Discussion in '365 GT4 2+2/400/412' started by JPinna, Nov 6, 2016.
  1. JPinna
    JPinna Karting
    Nov 9, 2012
    70
    Jeremy Pinna
    Please can someone tell me , in plain speak, how to add a picture to a thread ?
    Jerry
  2. samsaprunoff
    samsaprunoff F1 Rookie
    4,453
    Edmonton, AB Canada
    Sam Saprunoff
    #2 samsaprunoff, Nov 6, 2016
    Good day Jeremy,
    I have attached a few pictures of the screens to help.
    1. You must Select the "Go Advanced" button (see Picture)
    2. After adding whatever text you wish to add in the Message area, select the "Manage Attachment" button to add the images you wish (see picture)
    3. Another Dialog box will open (Manage Attachment Dialog Box) and now select the "Browse" button (see picture).
    4. Select the image you wish to upload and then select open from the Browse dialog window. This will return you to the Manage Attachment Window where you will see the file adjacent to the browse button you selected.
    5. Once you have selected the files (up to four), select the "Upload" button on the right side of this Window.
    6. You will see the files uploaded in the Window below the "browse" buttons
    7. Now you can select more Images by repeating the steps 4 to 6. You can only upload a maximum of 24 images per post.
    8. Once you are done then select the "Close this Window" link in the upper right corner
    9. This will bring you back to the Advanced Reply Window.
    10. You can now select the "Preview Post" button (bottom of the Reply Window) to see the images and your text prior to posting it or you can submit everything by selecting the "Submit Reply" button.
    11. You are now done... Time to have a Whiskey ... er Grappa :) ... Saluti
    Cheers,
    Sam
  3. JPinna
    JPinna Karting
    Nov 9, 2012
    70
    Jeremy Pinna
    Hi Sam , Thanks for the info , I will try and send a pic shortly
    Best Wishes
    Jerry
  4. godabitibi
    godabitibi F1 Veteran
    Jan 11, 2012
    6,329
    Papineauville, Quebec
    Claude Laforest
    Just some more info in case it happen to you too. For me I have to select my picture and upload them one at a time. If I select 4 or them and then upload it doesn't work. This way you can have your four pictures in one post if you upload them each time you select one.
  5. JPinna
    JPinna Karting
    Nov 9, 2012
    70
    Jeremy Pinna
    #5 JPinna, Nov 8, 2016
