A few questions with Testarossa clutch install | FerrariChat
Discussion in 'Technical Q&A' started by Mitchell kohrmann, Apr 6, 2020.
  1. Mitchell kohrmann
    Oct 7, 2019
    9
    Columbus, Ohio
    Mitchell Arthur kohrmann
    Hi everyone, I purchased a 1989 Testarossa in the fall, did my own major over the winter, and am now about to install a new clutch to get it ready for summer! I’ve run into a problem, my new clutch kit didn’t come with the spacer and studs. Before disassembling everything, I took a peak through the inspection ports and the pressure plate and spacer seem completely different. There are no records of a clutch being done on my car that I have, I’m wondering if anyone has seen, or recognizes the clutch my car currently has. I’m assuming it would make my life easier to find replacement disks for the existing one. If not, I believe I need to purchase the 9 studs I found on a diagram along with the spacer, and have it all rebalanced. If anyone has any input it would help a lot. Thanks!
    Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
  2. ago car nut
    ago car nut F1 Veteran
    5,495
    Madison Ohio
    David A.
    Did you look in the workshop manual? Explains the size of the shims.
  3. Steve Magnusson
    26,716
    And maybe a flywheel? :(. That seems a very different design with smaller diameter friction discs and a completely different strategy for the intermediate plate?
    I've no information on what you've got presently, but here's a photo I saved that reminded people that "spacers go under the leaf" (as they are zip tied in your new assembly):
  4. Mitchell kohrmann
    Oct 7, 2019
    9
    Columbus, Ohio
    Thanks for the quick replies guys. I do have a manual, but I was more worried/curious about my intermediate plate and pressure plate looking nothing like what I’ve seen on other cars. I’m hoping that when I get into it, the flywheel will be compatible with my new kit, and also salvageable.
    That picture helps greatly, if you have any more I would appreciate it! I want to make sure I have everything I need before I take things apart, but from what I see through my inspection port it’s pretty hard to judge given my setup looks completely unique.
  5. Mitchell kohrmann
    Oct 7, 2019
    9
    Columbus, Ohio
  6. Mitchell kohrmann
    Oct 7, 2019
    9
    Columbus, Ohio
    Alright I have one more update. I figured I wouldn’t make any progress without taking it apart, so I went for it today. I was shocked that it only took roughly an hour to get to the clutch. Anyway, the whole assembly looks odd, and unfortunately the flywheel is aftermarket. I’ve been trying to decide if I should keep this aftermarket thing going, or give in and buy the factory flywheel, spacer and hardware. The clutch discs have no part number on them, but they do look very similar to the brand Spec’s logo and writing. Here are some pictures of everything taken apart, if anyone has an idea of where to find this clutch, or any of the components I need to go back to factory that would be great. Thanks!
    Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
