82 Mondial 8 speedometer/odometer dead | FerrariChat
Discussion in 'Mondial' started by ATSAaron, May 28, 2019.
  1. ATSAaron
    ATSAaron Formula 3
    1,135
    Shady Shores, TX
    Aaron Bunch
    My speedometer and odometer have stopped working. I replaced the speedometer sensor at the transmission with another used one that I had, but no change. Although it's possible that it was bad too? However what is the next step in the flowchart of diagnosis?
    Thanks in advance,
    Aaron
  2. belfry
    belfry Formula Junior
    May 14, 2015
    484
    Robert Batt
    Can you check the face of the old sensor for wear?
  3. ATSAaron
    ATSAaron Formula 3
    1,135
    Shady Shores, TX
    Aaron Bunch
    I did notice that the faces of the sensors looked different. I didn't realize they ran so close as to actually wear.
  4. belfry
    May 14, 2015
    484
    Robert Batt
    On mine I had the same symptoms. Speedo and odometer stopped working. New sensor did not work either.
    It was the gearbox intervals that were the issue, hence checking for any wear marks on the sensors. I didn't know this and continued to drive the car. Now the gearbox is being rebuilt.
    I this happened to me agai, and new sensor didn't cure the issue I would drain the oil and check the magnetic drain plug for debris.
  5. ATSAaron
    ATSAaron Formula 3
    1,135
    Shady Shores, TX
    Aaron Bunch
    Well I just happened to have changed the trans fluid this weekend and there were no surprises inside.
  6. belfry
    May 14, 2015
    484
    Robert Batt
    After my experiences it'd be nice to see no wear marks on the sensor, just for peace of mind.
    ATSAaron likes this.
  7. ATSAaron
    ATSAaron Formula 3
    1,135
    Shady Shores, TX
    Aaron Bunch
    Do you have your sensor that you can post a picture of it?
  8. belfry
    May 14, 2015
    484
    Robert Batt
    jkstevens2 likes this.
