82 308 side trim | FerrariChat
82 308 side trim
Discussion in '308/328' started by Quetzel, Dec 17, 2013.
  1. Quetzel
    Quetzel Karting
    Jun 17, 2013
    61
    Sugar Grove, Il
    James Jenke
    Newer member and have a quick question.
    Bought an 82 308 6 months ago. Doing a minor renovation.
    Car has side rubber trim in the space between the upper and lower sides of the body.
    Like the black door guard you see. It sticks out about 1/2 inch from the sides of the body. I haven't been able to find any 308's with "filler/protective rubber" in that space. Obviously done to protect the body from door damage. I'm guessing it is DIY/Aftermarket.
    Are any 308's fitted with this protective rubber side strip? If not, all the one's I have seen have that gap painted black. Is that correct?
    My car is Russo.
    Thanks.
    Jim in Chicago
  2. JV's89
    JV's89 F1 Veteran
    7,278
    Pittsburgh, PA
    I've never seen what your describing. Mat black paint is the factory treatment - as far as I know.
    I'd take my chances with door dings before I'd resort to aftermarket protective trim.
  3. Quetzel
    Quetzel Karting
    Jun 17, 2013
    61
    Sugar Grove, Il
    James Jenke
    Thanks so much. Mat black is all I have ever seen. Owner did a nice job - actually looks good. But as I am doing a respray - might as well get them gone.
  4. nerofer
    nerofer F1 World Champ
    Mar 26, 2011
    12,082
    FRANCE
    Minor precision: the body crease, indent line, etc...should have only its vertical side painted matt black (with a slight little shine) but not its bottom nor its top ("ceiling", if you like). Only one side of the three...
    Rgds
  5. skelly
    skelly Formula Junior
    Mar 24, 2011
    282
    #5 skelly, Dec 17, 2013
    My 328 was wearing similar side trim when I bought the car. It was easy enough to remove the rubber, but the glue was a real bear! I was able to soften it with goo-gone and scrape it off with several afternoons' effort. Of course, if you're going to repaint then it could be sanded off instead.
    All I can figure is that the rubber was added to prevent door dings.
  6. Quetzel
    Quetzel Karting
    Jun 17, 2013
    61
    Sugar Grove, Il
    James Jenke
    Thanks for the correction on what to call the body parts.
    And, I also had a follow on question - you answered. Only the vertical piece gets painted.
    Thanks to both of you.
  7. JV's89
    JV's89 F1 Veteran
    7,278
    Pittsburgh, PA
    If possible, could you post some pictures before you remove it? Just curious, I suppose.
  8. wizig
    wizig Karting
    Jul 8, 2006
    90
    Leawood KS
    It was an aftermarket product back when the car was new. I remember considering it at the time. I am surprised that SIXFOURSEVEN's car was glued. IIRC, it was designed to fit snug without any glue. One of the problems that some people experienced was rust....the rubber trapped moisture, and it would cause rust in the channel. I suggest that you look closely for rust when doing your restoration.
  9. ME308
    ME308 Formula 3
    Nov 5, 2003
    1,550
    Munich, Germany
    Michael
    #9 ME308, Dec 17, 2013
  10. chrisbinsb
    chrisbinsb F1 Rookie
    Oct 20, 2011
    3,675
    Santa Barbara
    Chris B
    Haven't seen it on a 308 but a friend has the same piece on his 328
  11. i-velocita
    i-velocita F1 Rookie
    2,520
    Colorado
    James
    Yes, satin black, not matte.
  12. JV's89
    JV's89 F1 Veteran
    7,278
    Pittsburgh, PA
    Doesn't look as bad as door dings, but it's not for me. Thanks for the picture.
  13. JV's89
    JV's89 F1 Veteran
    7,278
    Pittsburgh, PA
    Thanks for the correction. I had some work done to my car after hitting a deer that included a re-spray of the front clip. The body shop neglected to use satin black forward of the front wheels. My car is black and it took a few days for me to notice. I didn't want to tie the car up for the body shop to fix it and kind of forgot about it. Easy enough repair that I'll get to one of these days.
  14. Quetzel
    Quetzel Karting
    Jun 17, 2013
    61
    Sugar Grove, Il
    James Jenke
    Thanks for the responses.
    Mine is the same as the pic posted - except - it is glued. Not a "snap" fit. Well done - but not a snap fit.
    And you are correct - I have a bit of rust on top of one of the strips. That is the primary reason I want to get rid of them. They look like natural "water traps".
  15. Fairview
    Fairview Formula 3
    Mar 16, 2009
    1,109
    Waynesboro, Virginia
    Jeff Ward
    Hey Michael,
    What is that car in the reflection? Looks kind of like a Big Healey, or an MGA, kind of a mystery.
    Jeff
  16. Dr Tommy Cosgrove
    36,367
    Birmingham, AL
    Tommy
    That was a little item that - as far as I know - was Steve Ahlgrim's idea at FAF back in the day. It was something off a hardware shelf that worked well as a door ding guard. I cannot find the stuff anymore but I am still looking.
    Anyone out there that has it and wants to get rid of it, let me know
  17. Bullfighter
    Bullfighter Two Time F1 World Champ
    Jan 26, 2005
    22,587
    Gates Mills, Ohio
    Jon
    Also need curb feelers to complete the look.
  18. ME308
    ME308 Formula 3
    Nov 5, 2003
    1,550
    Munich, Germany
    Michael
    no idea, neither car is mine ... just to show the trim
  19. itiejim
    itiejim Karting
    Dec 9, 2008
    84
    James Ashton
    Looks like a Mk IV or 1500 Spitfire to me
  20. tomd308
    tomd308 Karting
    Jun 10, 2006
    159
    gainesville florida
    thomas dukas
    My 85 308 has those inserts. I bought the car at FAF in '92 and Steve was the salesman. I'll have to ask him about it next time I see him.
