599 Radio help | FerrariChat
599 Radio help
Discussion in 'Technical Q&A' started by Auraraptor, Jun 18, 2020.
  1. Auraraptor
    Auraraptor F1 World Champ
    Sep 25, 2002
    13,220
    MO
    I swapped a 599 headunit one my 575. I have the code for the radio, but can never get to the code screen to activate it?
    I tried turning on the radio with the car off, and it said that the ignition need to be on. I then turned the ignition on and the radio then went into ‘Device disabled’ mode with a 60 min countdown.
    An hour later I tried by first turning on the ignition.... That didn’t work either...again with a ‘device disabled’ screen Witt a count down from 60 minutes.
    how exactly do 599/430 owners get your radio to work after a battery dies?
    Its a BE 6111 headunit
  2. Auraraptor
    Sep 25, 2002
    13,220
    MO
    The manual says I guess I have to wait with the ignition on for the full one hour as if it is turned off while still counting down it will reset.
  3. Auraraptor
    Sep 25, 2002
    13,220
    MO
    Yep that was it.
    Basically it resets the timer everytime you turn the car off, hence the issue. Leave it on for an hour and all is well. Works great!
  4. Bob in Texas
    Bob in Texas F1 Rookie
    Apr 23, 2012
    2,668
    Just East of Weird
    Bob
    Good to know!
    Sent from my iPad using Tapatalk Pro
