599 Issues - First drive after winter storage | FerrariChat
Discussion in '612/599' started by eaf124, Mar 14, 2021.
  1. eaf124
    eaf124 Rookie
    Dec 25, 2015
    41
    Westchester, NY
    Eric Field
    Hi all,
    This afternoon, my father and I took the cover/trickle off the 599 and took it for the first drive of the season. When we put the car away last year, aside from a TPMS failure and a few other electrical gremlins, the car was perfect.
    Today, on startup, the car was fine. By the time we reached the end of our driveway (about 800 feet), what seemed like white smoke was coming out of the hood. Strangely, it came out right under the windshield (underneath the wiper) and it was only on the driver's side. Smelled pretty bad. Disappeared after a few minutes (happened once before, maybe a year ago - our shop inspected and said it was fine). When opening the hood to check it out, I put my ear into the engine bay and heard a new noise - almost sounds like an empty plastic bottle rattling around.
    I took a video of both. In the video showing the smoke, its barely visible (was a bit more visible in person). In the video showing the engine sound, first I zoom on the area that the smoke was coming from, then I zoom in on where the sound seems to be coming from.
    https://photos.app.goo.gl/r8B53Ck4uVpmeLLY9
    Any ideas what either of these (the smoke, or the noise) could be? Drove the car for 15 minutes - temp and oil pressure were normal.
    2007 599 GTB with 14k miles, never tracked or abused.
    Thanks!
  2. Ferrari 360 CS
    Ferrari 360 CS F1 Veteran
    Dec 4, 2004
    6,886
    Cape Town,SA
    Jacques
    Re the engine bay nose, sounds to me looks a heat shield has worked its way loose.
  3. Mamich
    Mamich Karting
    Mar 29, 2020
    82
    Zed
    Hi I had exactly the same thing happen to my car and I was advised by Ferrari when I took it in that it was the quote on quote
    "Slight burning smell in vehicle when starting from cold, we have identified that both Cam cover gaskets are leaking (not excessive). The rectification would be to replace the Cam cover gaskets and inlet manifold gaskets estimated at £2000+ Vat.
    Skidkid and Makuono like this.
  4. Skidkid
    Skidkid F1 Veteran
    9,513
    Campbell, CA
    John Zornes
    Pretty common and a lot of work to do. SO, on my car they are going to stay that way until it an issue or something has to come apart.
  5. Justin Hughes
    Justin Hughes Karting
    187
    Oxfordshire - UK
    Hughesie
    My guy repainted my Cam covers as they were tatty at the back (a common issue) and it was a £1.2k job inc paint strip and refit.
  6. eaf124
    eaf124 Rookie
    Dec 25, 2015
    41
    Westchester, NY
    Eric Field
    Thanks everyone for the replies. I'll give our shop a call later this afternoon and update the thread when I know more. Now that you all mention it, seems like it very well could be the cam cover gasket.
    Sent from my GM1917 using FerrariChat.com mobile app
  7. gsholz
    gsholz Formula Junior
    347
    Oregon
    Jerry
    Pretty common. Oil seems to be pooling in the rear of the cam covers and then seep onto the headers. Just a few drops can create lots of smoke. You can try to snug up the cam cover bolts - don't overdo it. If it only happens during long-term storage, I'd not worry about it.
  8. eaf124
    eaf124 Rookie
    Dec 25, 2015
    41
    Westchester, NY
    Eric Field
    Started the car today. Let it run in the garage for a few mins. Nothing happened, no smoke. I backed it out of the garage and saw very little smoke which only lasted for a few seconds before clearing. Smelled of either rubber or oil. Drove the car for maybe 5 mins. Nothing else.
    Now that I think about it, the few times this has happened in the last year, they were after reversing. Also, I started the car once over Winter and remember the car started differently - it normally explodes to life, but that one time it sounded like a "lazy" start. Not sure if any of that is related but figured I'd mention it.
    Right now I have an appointment for the car to go in early next week. Will check the bolts and if the problem persists, I'll mention it to the shop.
    In your experience, what would cause oil to pool in the cam covers?
    Thanks!
  9. tazandjan
    39,141
    Eric- First thing I would do is put a new battery in her. That causes all kinds of problems, obviously not oil leaks.
  10. odf911
    odf911 Formula Junior
    Nov 30, 2013
    557
    London UK (Chelsea)
    Olivier
    I would get the oil leak fixed. Something similar happened to me and got remedied before bigger damage to the car. Still costed me $5000 but avoided the oil to creep up into ECUs etc. That would have costed a lot more ... also started with bit of white smoke!
  11. gsholz
    347
    Oregon
    Jerry
    Owning a Porsche 993 has cured me of worrying about minor valve cover oil leaks. It seems to happen every 3-4 years. On a 993 the oil pools on top of the heat exchanger. Talk about smoking when she warms up. Replacing the seals is neither hard nor expensive but access is awkward.
    On the 599, I'd consider replacing the seals if it smokes on every start-up. Replacing the camshaft cover seals is pretty straightforward but time-consuming. You do not have to take off the entire intake manifold.
  12. eaf124
    eaf124 Rookie
    Dec 25, 2015
    41
    Westchester, NY
    Eric Field
  13. jimshadow
    jimshadow F1 Veteran
    Feb 19, 2006
    6,250
    Indiana/North Carolina
    JIM
    Excellent! Drive in good health and keep the pics coming! :)
    599_GTO and eaf124 like this.
