575 GTO | FerrariChat
575 GTO
Discussion in '365 GT4 2+2/400/412' started by 246tasman, Jun 25, 2007.
  1. 246tasman
    246tasman Formula 3
    Jun 21, 2007
    1,446
    Will Tomkins
    #1 246tasman, Jun 25, 2007
    The GTO special is one we built for myself a few years back. It's on a 365GT4 chassis shortened to 2.4m. The engine is mildly tweaked and dry sumped (revs clean to 8000), then lowered 4in & moved back 8in. It tops out at about 195mph and is surprisingly stable at that speed.
    In the next couple of weeks the engine will be coming out and we'll be dropping in a 575 unit & transaxle. It will be tight but should just fit. The inlet manifold will be junked and 12 throttle bodies & trumpets fitted. It will need a 330GTO style bonnet bulge or maybe we'll fit a 250 Testarossa style perspex bubble. Another slight advantage is that the first 5 gears are a lower overall ratio than the 365 box which will be better for the circuit. I suspect the new powertrain may be lighter too. The old 365 steel gearbox and diff weigh a ton.
    I'll post you some GTO pictures shortly
  2. 246tasman
    246tasman Formula 3
    Jun 21, 2007
    1,446
    Will Tomkins
  3. msdesignltd
    msdesignltd Two Time F1 World Champ
    20,242
    NYC. / E. Hampton
    Michael
    #3 msdesignltd, Jun 25, 2007
    Excuse me ???...we built, just what do you do.....Body Fabrication?
    You are having too much fun, send some of that stuff across the Pond...
    What else are you hiding from us.???
  4. Kds
    Kds F1 World Champ
    How do you plan to set up the ignition ? The whole concept sounds interesting.
  5. 246tasman
    246tasman Formula 3
    Jun 21, 2007
    1,446
    Will Tomkins
    #5 246tasman, Jul 10, 2007
  6. ClassicFerrari
    ClassicFerrari F1 World Champ
    Jan 7, 2004
    16,798
    Toronto
    Vasco
    This is amazing and really deserves a dedicated and detailled thread!:)
  7. open roads
    open roads F1 Rookie
    Jan 28, 2007
    3,799
    Sarasota, Fl.
    Stan
    What a great project.
    BRAVO !!!!!!!!
  8. msdesignltd
    20,242
    NYC. / E. Hampton
    Michael
    You;re good, you are good.....
    Ithink this car should go into mass production....
    Who wouldnt want one.
    550 HP....and an 1800 lb chassis.
    and not too shabby looks.
    What would it be called a GTOMG
  9. 246tasman
    246tasman Formula 3
    Jun 21, 2007
    1,446
    Will Tomkins
    We can't get anywhere near 1800lb. I think it will be 1150kg = 2535lb. But hoping for a bit more than 550hp. The engine will be standard internals with a good exhaust and straight inlet ports and trumpets. It will probably be 3 months before it's on the Dyno.
    I've just been offered another 575 engine and a little demon is suggesting
    getting it and eventually doing a full race version. The cam timing looks amazingly mild on the standard engine.
    It seems to be calling itself a 575 GTO.
  10. Daytonafan
    Daytonafan F1 Rookie
    Oct 18, 2003
    2,748
    Surrey, England
    Matthew
    That's a might impressive power to weight ratio!
  11. msdesignltd
    20,242
    NYC. / E. Hampton
    Michael
    #11 msdesignltd, Jul 12, 2007
    Yes, I meant chassis without mechanicals!
    This car will be the equivilent of the 1960's Chevy Cheetah!!!
    Power2Weight Ratio
    What type of Tyres will you be running, Old school??
  12. bigodino
    bigodino F1 World Champ
    13,114
    The Netherlands
    Peter den Biggelaar
    That 575 engine looks right at home in there. Thanks for sharing your pictures and story on this project.
    I think I've seen this yellow GTO replica for sale some years ago with Marcel Roks in Belgium. Is this the same car? Do you have the s/n? Thanks.
    Best regards, Peter
  13. 246tasman
    246tasman Formula 3
    Jun 21, 2007
    1,446
    Will Tomkins
    Yes, Marcel had it advertised for me a while back before I got all enthusastic about fitting the big engine.
    S/n is 23457 which is a 400GT number. The splined hubs & suspension with the solid bushes came off a 365GT4 I had at the time which then took the bolt-on hubs & rubber bush suspension from the 400. Later we lightened the suspension quite considerably. I seem to remember we lost about 32kg over all 4 corners.
  14. 246tasman
    246tasman Formula 3
    Jun 21, 2007
    1,446
    Will Tomkins
    It's on Michelin XWXs but I think they're too hard compound expecially with the relatively low chassis weight and I'm thinking of Avon ZZRs (sort of stickier old school) for the road.
    We've been using Dunlop M racing tyres on cast wheels for the track, but for the future it will depend on what series will let it race and what the tyre rules are.
  15. 246tasman
    246tasman Formula 3
    Jun 21, 2007
    1,446
    Will Tomkins
    What would it be called a GTOMG[/QUOTE]
    I'm a bit slow - the penny just dropped - very good!
  16. Chelle
    Chelle Formula 3
    Dec 6, 2003
    1,036
    N. burbs of Chicago
    Michelle
    um, if you don't want the 575 engine I might have a home for it... any idea the weight of the 550 and 575 engines? With the M70 V12 we are at 2250lbs
    Beautiful project btw :)
  17. 246tasman
    246tasman Formula 3
    Jun 21, 2007
    1,446
    Will Tomkins
    Just weighed the 575 engine:
    With lighter alternator, no a/c pump, 400GT (iron) p/s pump, no exhaust manifolds, jenvey throttle bodies, no clutch = 215kg
    Standard exhaust manifolds = 38kg, Fabricated extractor manifolds = 18kg (rather shocked by this - could be made lighter)
  18. 246tasman
    246tasman Formula 3
    Jun 21, 2007
    1,446
    Will Tomkins
    #18 246tasman, Jul 11, 2009
  19. #Lennard
    #Lennard Formula 3
    Aug 26, 2006
    1,073
    Zeewolde/Netherlands
    Lennard
    We need more info and pics :D
  20. rossocorsa13
    rossocorsa13 F1 Rookie
    Jun 10, 2006
    2,557
    Nashville, Tennessee
    M
    ^ What he said.
    But yummy anyway.
  21. SSNISTR
    SSNISTR F1 Veteran
    Feb 13, 2004
    8,046
    SFL
    Looks like an Enzo V12 in some classic....so far so good!
  22. FerrariF1v12
    FerrariF1v12 Formula Junior
    410
    Liberty City
    Christian
    modern tipo v12 with old school trumpets.
  23. tx246
    tx246 F1 Veteran
    6,659
    Texas
    Shawn
    is that an enzo motor in a gto "body"?
  24. Sfumato
    Sfumato F1 World Champ
    Nov 1, 2003
    10,194
    Llanfairpwllgwyngyll, Anglesey, Wales
    Angus Podgorney
    Wow. Really set back in that chassis.
    Looks like cambelts, so it's probably a Maranello motor. Haltech injection? Looks nice, really like the airbox.
  25. SSNISTR
    SSNISTR F1 Veteran
    Feb 13, 2004
    8,046
    SFL
    Good catch, I missed that one....
