550 X pipe H pipe or Straight pipes | FerrariChat
Discussion in '456/550/575' started by SE16, Dec 25, 2019.
  1. SE16
    SE16 Karting
    Apr 13, 2007
    107
    UAE and London
    My 97 center muffler is needing replacement. I have no interest in more noise or performance but feel that the middle muffler is a bit superfluous.
    Which option is recommended for a replacement of the muffler ? X / H OR straight to keep the most optimal balance between good noise (no droning) and performance?
    Thanks and merry Christmas
  2. tazandjan
    38,087
    If you do not care that much about hp, then an X-pipe or one of Fabio's H pipes will eliminate the drone and still increase hp. Max hp would be to do what the factory did and replace with straight pipes. All 575Ms from late Summer 2003 came from the factory with straight pipes.
    Fabio's H pipe will give more hp than an X-pipe, with a nice sound, too.
    308 GTB likes this.
  3. SE16
    SE16 Karting
    Apr 13, 2007
    107
    UAE and London
    Thanks. Do the 575 drone?
  4. tazandjan
    38,087
    Depends on the exhaust.
  5. Fiat Phil
    Fiat Phil Rookie
    Apr 15, 2015
    8
    Bay Area
    Phil Schmadeke
    I have X pipe with X-OST mufflers on 550. No drone. Good sound. Can talk in car at any speed. Mufflers are valve delete.I even put stock mufflers on for concourse judging. No added noise.
  6. tritone
    tritone F1 Veteran
    6,888
    On the Rock
    James
    Have an SS X-pipe from Phil Hughes in OZ. Never mounted/NIB. Very good price for an F-Chatter.......:D
    PM me if interested....
  7. SE16
    SE16 Karting
    Apr 13, 2007
    107
    UAE and London
    I went with a custom made H pipe in the end and its sounds different at idle but and above 90mph. Its no louder, just deeper and I like it! Additionally, it has no drone..
    308 GTB and F456M like this.
  8. SE16
    SE16 Karting
    Apr 13, 2007
    107
    UAE and London
    Whereabouts are you based?
  9. vee12
    vee12 Formula Junior
    333
    Atlanta
    Les
    Is your car a 550 or 575? What rear mufflers are you running?
  10. SE16
    SE16 Karting
    Apr 13, 2007
    107
    UAE and London
    It’s a 550 on standard set up
  11. Dm993tt
    Dm993tt Rookie
    Aug 19, 2019
    38
    David
    2nd Fabio's stuff
