550 steering wheel airbag bubbles... any fixes other than replacing it? | FerrariChat
Discussion in '456/550/575' started by mbyormark, Jul 20, 2018.
  1. mbyormark
    mbyormark Karting
    Jul 25, 2017
    101
    Connecticut
    Michael Yormark
    Hi everyone,
    I'm slowly working my car toward perfection, but the one thing I can't put off is the airbag, those damn bubbles are taunting me!
    Does anyone have any tips for eliminating the bubbles without completely replacing the airbag (and without risking the airbag not deploying in a collision [knocks on wood])?
    I was thinking about getting some painters tape, laying it over the bubbles, then taking a syringe with a little super glue, injecting it through the painters tape into the bubbles and then sucking out the air through the same hole. I figure this will remove the bubbles, re-glue the leather to the surface of the airbag and once it's dry, it would be no match for an airbag deployment. Thoughts? Suggestions? Previous experiences I could draw from?
    Thanks!
    Also, if anyone has a spare LH seat back control switch for a 360, 550 or 575, I'm looking for one. :D
  2. henryr
    henryr Two Time F1 World Champ
    22,386
    Atlanta
    Juan Sánchez Villa-L
    i am told that those skilled with a syringe and a heat gun can inject new glue
  3. tazandjan
    39,127
    You should be able to remove the leather, stretch, and reglue. You always want to use the battery disconnect switch first and then disconnect the airbag before doing any work on it. Should be some threads on doing that here. If uncomfortable with doing that, one of the steering wheel companies would probably do it for you for a nominal charge. Passenger side requires removing pieces so you can disconnect the airbag and recover.
  4. mbyormark
    mbyormark Karting
    Jul 25, 2017
    101
    Connecticut
    Michael Yormark
    Hmmm, any specific type of glue?
  5. mbyormark
    mbyormark Karting
    Jul 25, 2017
    101
    Connecticut
    Michael Yormark
    Thanks! I will look for those threads
  6. BobH
    BobH F1 Rookie
    3,142
    Morristown, NJ
    Robert H
    I used a hair dryer and a plastic body filler spreader to smooth out the bubbles.
    Gently heat, lower temperature, the area around the bubble and use the plastic spreader to remove the air like you were hanging wall paper and smoothing out air pockets. The heat seemed to energize the old glue, perhaps it is similar to a hide glue, and the car pocket has not resurfaced in two years.
    LARRYH, Il Tifoso and mbyormark like this.
  7. BobH
    BobH F1 Rookie
    3,142
    Morristown, NJ
    Robert H
    That should read air pocket not car pocket
    mbyormark likes this.
  8. mbyormark
    mbyormark Karting
    Jul 25, 2017
    101
    Connecticut
    Michael Yormark
    Thank you everyone! I just tried a hair dryer on low and it worked!!! A few spots were stubborn, but persistence seems to have paid off. I'll check the car tomorrow morning, if it worked I owe all of you a round!
    Il Tifoso likes this.
  9. Il Tifoso
    Il Tifoso Formula 3
    Oct 22, 2013
    1,640
    SF Bay Area, CA
    Ruben
    Awesome and cheap solution... in my experience new leather always has a slightly different look to it, so I hope it works out for you!
    Ruben
  10. tres55
    tres55 F1 Rookie
    3,566
    Canada
    Any update on if it stuck? My interior is for the most part in great shape but the airbags are loosey goosey and I would love to avoid redoing the dash for as long as possible.
  11. del mar
    del mar Karting
    Feb 28, 2008
    52
  12. mbyormark
    mbyormark Karting
    Jul 25, 2017
    101
    Connecticut
    Michael Yormark
    So It seemed to work, checked it the next day and saw a definite difference in the steering wheel. It's been a few weeks and took a trip to the shop, so I will check back in to see how it worked over time
  13. mbyormark
    mbyormark Karting
    Jul 25, 2017
    101
    Connecticut
    Michael Yormark
    Wait... the switches are the same ones used on an audi? Probably a 1997 something?????
  14. mbyormark
    mbyormark Karting
    Jul 25, 2017
    101
    Connecticut
    Michael Yormark
    I think it's identical to a 1997 Audi A8
  15. mbyormark
    mbyormark Karting
    Jul 25, 2017
    101
    Connecticut
    Michael Yormark
    1998 Audi A8
    Part Number 4A0959765A
    Color Code 01C (Satin Black)
    ... now I just have to find it.
  16. JimEakin
    JimEakin Formula Junior
    989
    Mountain Living
    Jim
    I've had bubbles in the leather in my steering wheel since I bought it. I knew of this trick from an earlier FChat post, and finally did it. I bought a drywall edge smoother at Lowes and got out my ex's hairdryer. I applied the heat and rolled the leather smooth. I was careful about the heat since I didn't want to damage the leather. The leather is smooth now, it'll be interesting to see how long it lasts.
    F456M likes this.
  17. mbyormark
    mbyormark Karting
    Jul 25, 2017
    101
    Connecticut
    Michael Yormark
  18. fatbillybob
    Aug 10, 2002
    28,867
    socal
    Good find! Does the audi switch panel fit or just the tilt back bar? Those things get broken off by the parking brake handle. I have my parking brake set up to activate low to try and help prevent that.
  19. mbyormark
    mbyormark Karting
    Jul 25, 2017
    101
    Connecticut
    Michael Yormark
    The back and seat bars are the same, the panel itself is different.
  20. ridege55
    ridege55 Formula 3
    1,383
    Manhattan Beach, CA
    I just purchased a 599 and have bubbling on the dash and instrument pod. I think I will try the heat gun trick in those areas. They should be glued in back like the steering wheel?
  21. mbyormark
    mbyormark Karting
    Jul 25, 2017
    101
    Connecticut
    Michael Yormark
    I imagine it would work. I'm waiting for the weather to cool down to have another go at it. I figure that way the glue will cure more quickly and increase the likelihood for a good end result.
    ridege55 likes this.
  22. NE550
    NE550 Formula Junior
    Mar 23, 2017
    460
    Omaha, NE
    Dave
    Heat gun treatment really worked on my passenger airbag cover. Used a Milwaukee heat gun on the second lowest setting (350 deg F), held about 12" away and working over one small area at a time with a soft plastic decal blade. Might go over it again to get out the few remaining bubbles, but it turned out pretty well and only took about 15 minutes. Here's a before & after shot:
    Before:
    After:
  23. ridege55
    ridege55 Formula 3
    1,383
    Manhattan Beach, CA
    Awesome! I'm going to give it a try this weekend.
  24. mbyormark
    mbyormark Karting
    Jul 25, 2017
    101
    Connecticut
    Michael Yormark
    I’ll be working on it again tomorrow. Will do before an after photos and report back. It does work though.
  25. LARRYH
    LARRYH F1 Veteran
    9,624
    virginia usa
    I did the same thing on my 550 about 2 years ago and it is still perfect.. i just heated the area in place with a hairdryer and worked the bubbles out with a plastic body filler squeege and in 5 minutes it looked like new the process is so easy it is hard to believe it would work....but it did for me.
