488/F8 rim bolt pattern | FerrariChat
Discussion in 'Ferrari Discussion (not model specific)' started by APPLECO1, Nov 28, 2019.
  1. APPLECO1
    APPLECO1 Rookie
    Dec 18, 2010
    43
    MISSISSIPPI
    JOHN
    I want to buy rim/tires for my 488 but with an F8 on order I would like to make sure they will bolt right on. Does anyone know if I can swap rims between cars?
    I know it changed from F430 to 488GTB.
  2. willrace
    willrace Three Time F1 World Champ
    34,744
    North Tay-has
    Kurt
    Not sure that the rims unbolt at all, unless there's a factory 2 or 3-piece option. You might have better luck with swapping the whole wheel, and then it will come down to that bolt pattern, and offset.
  3. APPLECO1
    APPLECO1 Rookie
    Dec 18, 2010
    43
    MISSISSIPPI
    JOHN
    The offset and bolt pattern is what I’m curious about for the “whole wheel”
    I just don’t want to order a new rim tire combo for my 488 and then not be able to use them on my new F8
  4. tbakowsky
    tbakowsky F1 World Champ
    Sep 18, 2002
    19,912
    The Cold North
    Tom
    Unless ferrari has changed it for the new cars, should be 108x5 pattern. Same as Volvo..
  5. LVP488
    LVP488 F1 Veteran
    Jan 21, 2017
    5,831
    France
    The standard wheels for the F8 are the standard wheels of the 488 (the first time it happens as far as I know that they do not release new standard wheels for a new model).
    So all the characteristics (sizes, bolts, offset) are shared between the 488 and F8.
  6. APPLECO1
    APPLECO1 Rookie
    Dec 18, 2010
    43
    MISSISSIPPI
    JOHN
    Ok thank you..I had an issue going from F430 to 458 and thought Ferrari was using same offset but wasn’t sure. I asked Ferrari and have yet to receive a reply. Even Ferrari service didn’t want to confirm
  7. Auraraptor
    Auraraptor F1 World Champ
    Sep 25, 2002
    13,940
    MO
    Omar
    They haven’t used that in years. Starting with the 612 generation it moved to ~5x114.
    tbakowsky likes this.
  8. tbakowsky
    Sep 18, 2002
    19,912
    The Cold North
    Tom
    Thank you for this.
