458 Oil Leak | FerrariChat
458 Oil Leak
Discussion in '458 Italia/488/F8' started by Scout123, Jun 26, 2020.
  1. Scout123
    Scout123 Formula Junior
    496
    #1 Scout123, Jun 26, 2020
    Took my 13 458 Spider in for its first non-dealer service (bought it last Oct. from Ferrari Scottsdale) all prior service done under 7 year warranty. My mechanic found this oil leak build up. Car has just shy of 17k miles (I have put around 1200 miles on it). They are beginning process to see where leak is coming from. Hard to believe dealer never noticed this as the oil shown has been there a while.
  2. MalibuGuy
    MalibuGuy F1 Veteran
    Sep 18, 2007
    5,291
    Would like to find out if this is truly a leak. Clean up the case and then you will be able to trace any fresh oil.
  3. Ianjoub
    Ianjoub Formula Junior
    Dec 22, 2019
    901
    Homosassa, FL USA
    Ian Joubert
    Clean it with brake cleaner. Check it next oil change. Brake cleaner is cheap.
  4. Scout123
    496
    Plan is to clean it all up, do oil change, and then drive a few weeks and check again. I never had any low oil warning, etc.
  5. MalibuGuy
    Sep 18, 2007
    5,291
    Good plan. Don’t start doing mechanical stuff until you know the problem.
    My 458 ‘14 has 122,800 miles and no oils leak ever. I’m going in for an annual service next week. I’ll let you know if they find an oil leak.
  6. Natkingcolebasket69
    Natkingcolebasket69 F1 World Champ
    123k miles is impressive!
    technom3 and DefunctNeurons like this.
  7. RayJohns
    RayJohns F1 Veteran
    7,402
    West Coast
    Ray
    That looks more like just dirt or exhaust blow-by as opposed to an actual oil leak. As other's have said, clean it up and see if it reappears. I would also inspect the under panel just below that. If it is an actual leak, then you should have evidence of something on the under panel.
    If it were a leak in that area, it could be from an input shaft seal in the gearbox and/or perhaps a rear main seal. However, even a very tiny drip in those areas will create a giant mess and leave fluid dripping under there. If it was a fluid leak, I think you'd see a lot more evidence of fluid when you removed that panel under the flywheel.
    Here's a photo of my Toyota transmission, which did have a fluid leak (both at the rear main and input shaft). As you can see, there is ample evidence that liquid was involved. I don't see that present in your photo.
    Ray
    Solid State likes this.
  8. Scout123
    496
    There was some accumulation on the underbody panel. My mechanic told me the one area he saw it to cause him concern was some dried oil in an area where only It could’ve come from a transmission seal. Something like a bell housing area?
  9. RayJohns
    RayJohns F1 Veteran
    7,402
    West Coast
    Ray
    Yeah, on the DCT there is a bell housing and then you have the starter and flywheel on the back of the motor - just like most RWD setups, except it's more of a transaxle design, as opposed to a traditional transmission - but it's a very similar layout overall. Here's a photo; you can see the little open area in the lower left front (I added a purple arrow), which is that in inspection window you posted a picture of.
    Ray
  10. RayJohns
    RayJohns F1 Veteran
    7,402
    West Coast
    Ray
    Ask you mechanic to get a little inspection mirror and look around up in there if you can. Sometimes you can see where things are leaking from. If it's a rear main, it will be coming down from the back side of the motor. If it's an input seal, it will usually be more on the bell housing side of things.
    If it's not a huge mount of fluid loss, it might not be too much to worry about just yet. It will be interesting to here what the final conclusion is here. They also have UV dye kits, which you can add and then see if the liquid has dye in it, etc.
    Ray
  11. RayJohns
    RayJohns F1 Veteran
    7,402
    West Coast
    Ray
    I would also check the exhaust coupling seals and gaskets. To me, that looks more like exhaust gas build up (which often has moisture in it) and which can tend to cause normal road dirt and grim to build up. So be careful rushing to conclusions here.
    Ray
  12. MalibuGuy
    Sep 18, 2007
    5,291
    Of course, I need to point out that the mechanics at the Ferrari Service center go thru intensive periodic educational classes. The certified Ferrari service center has the correct diagnostic computers and tools to do a meticulous and accurate inspection of your vehicle, as well.
  13. Scout123
    496
    thanks. My guy is pretty good. E.g. Folks send F-40s From all over for him to work on , has most up to date Davinci software, etc.
  14. dgoldenz94
    dgoldenz94 Formula Junior
    562
    Las Vegas
    David Gold
    Tip of the hat to you sir, that's awesome.
    MalibuGuy likes this.
  15. Carnut
    Carnut F1 Rookie
    3,797
    Gladwyne PA
    Morrie
    I agree with Ray on this I don't think it is a leak. I rarely use the dealer for anything unless it is free, but I always put my cars up on my lift before they do go to any dealer. These days there are service techs and then there are mechanics sadly mechanics are much harder to find since these techs just plug in a computer cable and that tells them what is wrong if nothing comes up nothing is wrong. They dont go looking for things like they used to. By the way no guarantee that if you had a bad seal or gasket that the oil light will come on, more chance is that you would see something on the ground under where you park the car.
  16. MalibuGuy
    Sep 18, 2007
    5,291
    just finished my service. No oil leak.
    any word on your car?
  17. humdizzle
    humdizzle Karting
    Mar 9, 2016
    161
    i had a ppi done prior to sale. shop said they found a small oil leak (mine is a 2010 / 15k miles). A little less than 2k to fix.
    odd because i never saw any oil on my garage floor.
  18. MalibuGuy
    Sep 18, 2007
    5,291
    how was it fixed?
  19. Scout123
    496
    Taking it back next week to put up on lift and remove under panels to take a peek. Thorough review from up top shows everything clean as a whistle.
  20. MalibuGuy
    Sep 18, 2007
    5,291
    I think that the 458 engine is very robust and durable. Very few issues. The earliest cars are hitting the 10 year mark!
    Wondering how the 488s compare in this regard.
  21. Mlachance
    Mlachance Rookie
    May 29, 2021
    1
    What was the conclusion ? Have the same problem at the moment with my 458 spider ?
  22. 458guy2012
    458guy2012 Rookie
    May 26, 2021
    2
    Collin
    I have a strange leak coming from the front of the car, right under the front axle. Any idea what this could be??? That “tube” or flap under the car is where the leak is coming from and it just looks like it should be there in the first place...
  23. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    5,686
    Central NJ
    Dominick
    The ac condensation
  24. Ianjoub
    Dec 22, 2019
    901
    Homosassa, FL USA
    Ian Joubert
    Yes, a/c drain. A good tech will blow some air up through there when doing a service to keep it from clogging.
