458 front shocks leaking | FerrariChat
Discussion in '458 Italia/488/F8' started by simchanova, May 3, 2021.
  1. simchanova
    simchanova Formula Junior
    584
    Philadelphia
    Stuart
    Hi All!...had a Ferrari tech check my 2013 458 Spider out Saturday and stated my front shocks are leaking...I have only owned the car for a little over a year and have not used it much yet...is this a thing where with more usage the seals will be ok?...he stated I could use the car for awhile but eventually “I’ll know” when to replace...they are VERY expensive and it’s not a fix I factored in-anything to do to preserve the longevity of them?...are they covered under the Ferrari power warranty which I have?...what experience do all have with this?...thanks
  2. buddyg
    buddyg F1 Veteran
    6,259
    Naples, FL
    Buddy
    Yes the warranty should cover it.
  3. FFan5
    FFan5 Formula Junior
    Jul 7, 2018
    550
    Had mine fixed under the power warranty. It was a garage queen before I got it, so perhaps more miles would have been better.
    Sent from my Pixel 5 using FerrariChat.com mobile app
  4. FerrariCognoscenti
    FerrariCognoscenti Formula 3
    Jan 19, 2021
    2,429
    East Coast
    The power warranty covers suspension/shocks???
  5. simchanova
    584
    Philadelphia
    Stuart
    What dealer did yours?
  6. simchanova
    584
    Philadelphia
    Stuart
  7. vjd3
    vjd3 F1 Rookie
    2,728
    Massachusetts
    Vic
    I believe they would be covered if you extended the original new-car warranty for the one or two year period that was available when the car was still under the original warranty as that extension applies bumper-to-bumper. (But a 2013 car would not still be under that coverage anyway.) But under the New Power warranty, it does not appear to be covered (from the New Power brochure, which specifically excludes seals and leaks):
    Suspension and steering: complete steering box, suspension arm joints, power steering pump (excluding drive belt), toe-in tie-rods, ECU for controls on steering wheel (oil seals and oil leaks not covered).
    Doesn't mean the dealer can't go to bat for you with Ferrari for some goodwill, however.
  8. bball16
    bball16 F1 Rookie
    4,111
    NY LI FtL
    Shocks aren’t covered under Power.
  9. Need4Spd
    Need4Spd F1 Veteran
    Feb 24, 2007
    6,678
    Silicon Valley
    elt360 likes this.
