458 cracked headlight lens | FerrariChat
Discussion in '458 Italia/488/F8' started by RT777, Aug 9, 2020.
  1. RT777
    RT777 Rookie
    Apr 23, 2020
    25
    Roy T
    Hello guys, does anyone know if there is a way to replace the lens only on a 458 headlight? There is a fine crack on mine that I would like to somehow repair instead of having to replace the entire headlight for $2,000+
    Any ideas?
    Thanks!
  2. RayJohns
    RayJohns F1 Veteran
    7,914
    West Coast
    Ray
    Do you have a photo of the crack? You'd be surprised how well Super Glue works sometimes, although you have to be careful. They also make products to repair cracks in glass, which might be something to consider. I'm actually about to use one I just purchased to repair a crack in the windshield of my truck.
    There are many good quality two part products on the market for repairing stuff. You just have to do your research.
    As far as removing the lens, I seem to remember on the 360 forum people had come up with a way to open the headlights to clean them. Have you searched over there to see if you can find anything?
    Ray
  3. gilly6993
    gilly6993 F1 Rookie
    Aug 20, 2009
    2,557
    Longmeadow, MA
    Eric
    A fine crack should be able to be repaired.....there is likely a specific product out there....I would check with a local body shop or a windshield repair shop....
  4. MalibuGuy
    MalibuGuy F1 Veteran
    Sep 18, 2007
    5,874
    Maybe ask your local certified service center. They may know a specialist with experience handling this. Obviously one wouldn’t want to make matters worse with messy glue spots which will be permenant. In the meantime how about some clear tape to keep the inside of the lamp dry.
  5. KC360 FL
    KC360 FL Formula 3
    Jun 20, 2017
    1,937
    Melbourne Florida
    KGC
    Be careful of super glue. It almost always clouds the area repaired when used on clear plastics. Not at first, but days later. I've found this to be true on Lexan.
