456 - Accessing Speakers | FerrariChat
Discussion in '456/550/575' started by Ros456GTA, Jan 13, 2020.
  1. Ros456GTA
    Ros456GTA Karting
    Dec 16, 2019
    68
    Ros Tagard
    Speakers in a 456....
    a. 2 in the rear parcel shelf
    b. 2 under the rear seat ! ! ! (is that real)
    c. 2 in the doors
    d. 2 in the front dash
    Did I miss any ?
    Mine are really in need of replacement.
    The rear speakers seem the hardest to get at .
    So are there any decent write ups on how to access the speakers ?
    paulchua likes this.
  2. Ros456GTA
    Ros456GTA Karting
    Dec 16, 2019
    68
    Ros Tagard
    Anyone.
    To get to the rear speakers what's the order of disassembly on the rear seats ?
  3. killer58
    killer58 Formula 3
    Jun 30, 2010
    1,190
    CA & DC
    If you don't have access to a shop manual, try looking at the diagrams on Ricambi's site.
    Peel back the carpet tabs just below the bottom seat bolster to find two 10mm bolts.
    Remove those and lift the seat bottom up and towards you.
    Once the bottom bolster is removed, you'll find additional bolts for the upper bolster and the adjacent side panel.
    There are also some screws that hold the pillar pieces in place.
    Take your time, be gentle, and don't force anything. If it seems difficult to remove a piece, it's because you missed a fastener.
  4. Laserguru
    Laserguru Formula 3
    Aug 7, 2016
    1,255
    New Hampshire
    Eric
    Killer58 is entirely correct. In addition, the immobilizer is behind the side panel on the rear of the passengers side. There is a how to remove the immobilizer set of instructions on the FerrariFobs website. It's very useful. https://www.ferrarifobs.com/456-immobilizer-removal.
    Once you have done enough of this, you'll feel pretty confident on how to dig any of this stuff out. Let us know how its going....
    paulchua and Qavion like this.
  5. Ros456GTA
    Ros456GTA Karting
    Dec 16, 2019
    68
    Ros Tagard
    Many thanks.
  6. Laserguru
    Laserguru Formula 3
    Aug 7, 2016
    1,255
    New Hampshire
    Eric
    I gather your excavation was successful.....
  7. paulchua
    paulchua Cat Herder
    Jul 1, 2013
    16,096
    Menlo Park, CA
    Paul Chua
    Thanks, guys for this info, when I get to it, I plan to upgrade all the speakers (I think it's the originals) any recommendations?
    Best wishes
  8. Ros456GTA
    Ros456GTA Karting
    Dec 16, 2019
    68
    Ros Tagard
    Rear Speakers
    No need to remove anything.
    Floor Speakers
    There is a speaker under each rear seat, facing forwards hidden behind the carpet.
    Lift the floor carpets, and then lift up the vertical carpet to reveal the speaker.
    There is a protective spacer ring glued on the front to stop damage.
    It's a 5" round unit.
    Parcel shelf speakers
    2 screws hold the grill in place.
  9. Ros456GTA
    Ros456GTA Karting
    Dec 16, 2019
    68
    Ros Tagard
    Rear Centre Console
    Now if you want the rear ashtray out then it's a bit more work.
    The rear seats need to come out.
    2 bolts at the front of the bottom cushions (either side of the speaker) 9mm
    Then the vertical cushion, 1 bolt and 1 screw
    The Centre console mounting brackets can be seen 4 bolts - again 9mm
    Now the centre console is out, you can access the ashtray.
  10. paulchua
    paulchua Cat Herder
    Jul 1, 2013
    16,096
    Menlo Park, CA
    Paul Chua
    Just wanted to thank you for taking the time to write this.
    Do you have any thoughts and suggestions on replacing the head unit?
    Cheers
  11. Fennicus
    Fennicus Formula Junior
    Apr 10, 2015
    592
    Helsinki, Finland
    Pekka T.
    Hi,
    If this is an original 456GT unit in the trunk and a face/control unit in the center console it can be recondotioned and work like a charm again. It is compatible with all ”uniink” Sony equipment. Mine needed 10+ capasitors replaced, the trunk gets hot and has no ventilation, there’s a thread about the stereo in this forum.
    If it is a later 456M unit, then I suppose it could be replaced easier, although I always think OE adds to the value of the car.
    Cheers!
  12. paulchua
    paulchua Cat Herder
    Jul 1, 2013
    16,096
    Menlo Park, CA
    Paul Chua
    Thanks so much again for your time, I appreciate it - it is for a 456M, however my question is do you know the procedure on how to remove the deck unit? If it's too lengthy or complicated, no worries - I don't mean to take your time. I do plan to keep the original, but since most my media is digital, I plan on purchasing a simple bluetooth deck for ease of use.
    Best wishes.
  13. Fennicus
    Apr 10, 2015
    592
    Helsinki, Finland
    Pekka T.
    Hi,
    Sorry, I don’t know the details of the 456M unit, but I think it should be simpler. Does it have the four round small holes in the front face for ”DIN” bracket removal? If not I would consider removing the center console which does require unmounting the rear seat piece by piece and some other interior but then you could also fix other small things.
    Also I have most content in digital, but the CD unit now works fine for all CD’s (another later Sony unit) and I put the cables (USB and 3.5mm stereo miniplug) in the rear seat ashtray/ cigarette lighter mounting for the Sony XA-300 unit in the trunk.
    Cheers!
  14. paulchua
    paulchua Cat Herder
    Jul 1, 2013
    16,096
    Menlo Park, CA
    Paul Chua
    Awesome! I will check! thanks again for taking the time to respond. Best wishes to you!
  15. Ros456GTA
    Ros456GTA Karting
    Dec 16, 2019
    68
    Ros Tagard
    Rear Seat and Rear Window speakers are done.
    The rear window speakers are odd as they are mounted with only 3 screws.
    Ferrari literally drill a hole in the flange of the speaker to mount it.
    Door Speakers
    So - how to access the door speakers ?
  16. killer58
    killer58 Formula 3
    Jun 30, 2010
    1,190
    CA & DC
    Paul,
    The stock 456M head unit is probably the BE2372:
    To remove it from the center console, first remove the faceplate by pushing the tab on the far right.
    Then, you insert the removal tools into the slots at the lower corners (see pen point to the left one)
    Below is a picture of the spring clips that hold the unit in the mounting bracket, the tool draws those spring clips in, allowing you to pull the head unit up and out.
    If you have one of the newer units, the 6104 or 6105, it's much the same only easier to access the slots.
    Laserguru, paulchua and Qavion like this.
  17. paulchua
    paulchua Cat Herder
    Jul 1, 2013
    16,096
    Menlo Park, CA
    Paul Chua
    You are my hero and I am very grateful for this information, huge thanks!
  18. Laserguru
    Laserguru Formula 3
    Aug 7, 2016
    1,255
    New Hampshire
    Eric
    What is this magic tool you speak of, killer??
  19. Qavion
    Qavion F1 World Champ
    11,578
    Ian Riddell
  20. killer58
    killer58 Formula 3
    Jun 30, 2010
    1,190
    CA & DC
    Mine are the thinner type with the extra little gizmo on the thumb holes:
    I believe the thicker ones are for the 6104/6105/6112.
    My car did not have them when I bought it, they were obviously misplaced at some point.
    Usually always a few pair for sale on eBay for around $3.00-4.00.
    For the price at Soundgroup, you can get an entire 20-piece set.
    Just be very careful inserting the tools, they should go straight in. If they go askew, they can easily get jammed or damage the spring clips.
    Qavion likes this.
  21. Laserguru
    Laserguru Formula 3
    Aug 7, 2016
    1,255
    New Hampshire
    Eric
    I learn a little something every day!! Thanks. Now I have another little tool to hunt for, find, buy, and then not lose!!
  22. ferraridriver
    ferraridriver F1 Rookie
    Aug 8, 2002
    4,137
    Bay Area Calif.
    Dave
    These are not for a carbon console, the whole console must lift out with radio attached.
  23. paulchua
    paulchua Cat Herder
    Jul 1, 2013
    16,096
    Menlo Park, CA
    Paul Chua
    Great info, just got my two removal keys today. Thanks again
    $6
  24. paulchua
    paulchua Cat Herder
    Jul 1, 2013
    16,096
    Menlo Park, CA
    Paul Chua
    Okay, just wanted to update the community, replaced the head unit with something more modern, keeping the old one of course. The speakers are shot me think, I'll replace the rear ones as it seems those are easy to do. I hear the dashboard tweeters are PITA, I assume the front door panel needs to come out for those?
    Anybody have sizes?
    Cheers
  25. paulchua
    paulchua Cat Herder
    Jul 1, 2013
    16,096
    Menlo Park, CA
    Paul Chua
    Okay just finished the deck install (speakers are shot, so doing that next)
    Hope this helps,
    1999 MGTA Speaker Wire colors
    Green = Right Rear Positive
    Green/Black = Right Rear Negative
    Black = Right Front Positive
    Gray/Blue = Right Front Negative
    Gray/Blue (yes, same as color as Right Front Negative...go figure) = Left Front Positive
    Black/Red = Left Front Negative
    Gray/Red = Left Rear Positive
    Black/Gray = Left Rear Negative
    Now on to replace the door speakers, rear speakers
    Instructions/Video on how to remove door panel
    It seems the rear speakers under the seats are straightforward, anyone have advice for the 456M rear parcel shelf speakers? I don't see any apparent bolts to remove.
    From what I can tell the tweeters in the dash is practically a no-go without removing the whole dash...
    Cheers
    Natkingcolebasket69 likes this.
