360 - 430 Gravel Guard Upgrade Fix | FerrariChat
360 430 Gravel Guard Upgrade Fix
Discussion in '360/430' started by RANDY6005, Dec 21, 2019.
  1. RANDY6005
    RANDY6005 Formula 3
    2,271
    Jacksonville
    RANDY
    I have had too replaced the gravel guards a few times and now the new ones have been broken again. I noticed the most of the challenge cars have screens fitted No louvers .The standard gravel guards fitted to 360 and 430 uses the plastic louvers act as a shield. Once the louvers have been broken rocks can damage your cooler , I was looking online Ebay found a new set of 360 Challenge gravel guards with the screens fitted they where asking 1700.00 US dollars PASS ON THAT !! So I found custom car grill screens on Amazon for 20.00 and they recommend using Goop max II adhesive it cost around 11.00 . I bought a cheep jig saw and a rivet tool and aluminum rivets and washers . Here are some pics this only around 30 minutes in too replacing with the screens, wend am done I will post completed ones
    tifosi101 likes this.
  2. RANDY6005
    RANDY6005 Formula 3
    2,271
    Jacksonville
    RANDY
  3. RANDY6005
    RANDY6005 Formula 3
    2,271
    Jacksonville
    RANDY
    Here a Youtube how too video
  4. 02360spider
    02360spider Formula 3
    May 27, 2015
    1,749
    Dartmouth
    Richard oliveira
  5. RANDY6005
    RANDY6005 Formula 3
    2,271
    Jacksonville
    RANDY
  6. Need4Spd
    Need4Spd F1 Veteran
    Feb 24, 2007
    6,678
    Silicon Valley
    Mine would get destroyed on track days, when clag would get thrown up going off line to pass other cars. I finally gave up replacing the OEM ones and installed screens like you have. I won’t win any concours, but my wallet is the better for it.
    RANDY6005 likes this.
  7. RANDY6005
    RANDY6005 Formula 3
    2,271
    Jacksonville
    RANDY
    That was the first one that I have done it was for practice, the next one will look better
  8. RANDY6005
    RANDY6005 Formula 3
    2,271
    Jacksonville
    RANDY
  9. 360trev
    360trev F1 Rookie
    Project Master
    Oct 29, 2005
    4,330
    Gibraltar
    360trev
    This is the way it should have come from factory..
    I wish they would have done louvres in the front fenders to prevent high pressure air build up in the front fender area at higher speeds too ...
    RANDY6005 and Need4Spd like this.
  10. RANDY6005
    RANDY6005 Formula 3
    2,271
    Jacksonville
    RANDY
    Here is the aluminum screen I find
    Roll over image to zoom in
    AUTOT 40"x13" Car Grill Mesh 6x3mm Aluminum Alloy Grille Mesh Sheet Rhombic Type Black
  11. RANDY6005
    RANDY6005 Formula 3
    2,271
    Jacksonville
    RANDY
  12. RANDY6005
    RANDY6005 Formula 3
    2,271
    Jacksonville
    RANDY
    Amazon Prime Goop Max II is the real deal !! If your gravel guard is crack or broke between the screen and Goop Max II it will make it better than new and a heck of allot stronger !! This is the way the Ferrari should have made it they do on there Challenge cars maybe to much labor time ?
  13. RANDY6005
    RANDY6005 Formula 3
    2,271
    Jacksonville
    RANDY
    I found this to be better way to upgrade the gravel guards , the louvers also must reflect the water down as well as rocks and gravel, should have thought at the begging .
  14. RANDY6005
    RANDY6005 Formula 3
    2,271
    Jacksonville
    RANDY
    Used 3M rubberized coating
  15. RANDY6005
    RANDY6005 Formula 3
    2,271
    Jacksonville
    RANDY
