365 motor assy complete with transmission | Page 11 | FerrariChat
Discussion in '365 GT4 2+2/400/412' started by bundas, Sep 5, 2015.
  1. DaveO_48
    DaveO_48 Karting
    Jul 29, 2013
    184
    Henderson, Nv
    David Odland
    When I had my gallbladder removed it was done thru a tiny incision in my navel and three holes in the chest cavity . It took less than two hours, according to my wife. I was up and about, going home the same afternoon. Unless his gallbladder was ruptured he should be about and well within a couple of days maximum. The days of cutting the patient open for that surgery are long gone. I hope, for your benefit, that he does well with the surgery.
    He will feel a whole lot better once it's over with. And, he will be able to concentrate on his work instead of abdominal pain.
    David
  2. bundas
    bundas F1 Veteran
    Dec 31, 2005
    7,090
    lexington ky usa
    mitchell barnes
    Shop owner just called. Motor has been run twice on dyno. No leaks. Motor will be installed this coming week and car will be running again. That is the current plan.
  3. blkprlz
    blkprlz Formula 3
    Mar 24, 2007
    2,169
    Tampa bay
    Bruce
    That is great news :D
  4. bundas
    bundas F1 Veteran
    Dec 31, 2005
    7,090
    lexington ky usa
    mitchell barnes
    I had given up
  5. roger21
    roger21 Formula Junior
    Aug 13, 2015
    262
    France
    Stéphane
    Nice to read some news. Happy that you soon drive it!
  6. rustytractor
    rustytractor Formula 3
    Mar 25, 2012
    1,078
    London
    Russell Schacter
    Mitch, I have an idea that you're not one to give up that easily.
    Great news - happy to see the project is still on track 👍🏻
  7. blkprlz
    blkprlz Formula 3
    Mar 24, 2007
    2,169
    Tampa bay
    Bruce
    He's demonstrated that he does have quite a bit of patience, irked at times but at least he has plenty of other automotive distractions :D
  8. bundas
    bundas F1 Veteran
    Dec 31, 2005
    7,090
    lexington ky usa
    mitchell barnes
    Motor in. The jets are too rich now that the motor is correct. I need 126. Easy problem. BUT the advance springs in the distributor are mismatched. Big problem. I will need a shop that can do the correction. They have not driven the car. I ask if I could get it back a week from now. No sure answer. But at least the car is back together.
  9. roger21
    Aug 13, 2015
    262
    France
    Stéphane
  10. willrace
    willrace Three Time F1 World Champ
    34,841
    North Tay-has
    Kurt
    It's PROGRESS ! ! ! ......and you're fighting to get better yourself. Should be an epic reunion.
  11. Newman
    Newman F1 World Champ
    Dec 26, 2001
    14,441
    Canada
    Newman
    Was it run on a dyno or a run stand?
  12. bundas
    bundas F1 Veteran
    Dec 31, 2005
    7,090
    lexington ky usa
    mitchell barnes
    The motor was run on a Dyno. For oil leaks. With the two distributors doing different advances I think that needs to be addressed before I get the car back. The difference is great. One double the other. Shop said I would not be able to tell the difference but I have gone this far, and so I feel this needs to be corrected. Opinions, please
  13. Newman
    Dec 26, 2001
    14,441
    Canada
    Newman
    Before and after should be significantly different when timing is that far off. Notice or not, too much timing on one bank wouldn't do your engine any favours.
    I asked because I was curious what the output was.
  14. bundas
    bundas F1 Veteran
    Dec 31, 2005
    7,090
    lexington ky usa
    mitchell barnes
    Top advance 24 the other 41
  15. DaveO_48
    DaveO_48 Karting
    Jul 29, 2013
    184
    Henderson, Nv
    David Odland
    There has to be some mechanical reason for this discrepancy.The distributors have to be installed on a different drive gear tooth causing you to turn the distributor to make up the difference. It should be easy to find out of the car. In the car, good luck!
    It all goes back to the engine assembly work. I guess that explains it doesn't it.
    Fix it now, no reason to leave bandages on bubblegum repairs. Another of the many issues with the quality of work you got stiffed with.
  16. Casino Square
    Casino Square Formula 3
    1,728
    Hong Kong / USA
    Andrew
    It seems Brett finally went quiet when you had the engine opened and found all the major discrepancies from his original work invoice. Curious.... What an epic misery. Wish you all the best.
  17. bundas
    bundas F1 Veteran
    Dec 31, 2005
    7,090
    lexington ky usa
    mitchell barnes
    Finally in trouble. I cannot get my distributors fixed. Sent to, Mel's Distributor. One is half apart. The other, not touched
  18. Rifledriver
    37,059
    Any good Ferrari shop can fix them. Box it all up and send it somewhere else.
  19. bundas
    bundas F1 Veteran
    Dec 31, 2005
    7,090
    lexington ky usa
    mitchell barnes
    I will wait until I see them
  20. Rifledriver
    37,059
    Mitchell, following your various troubles I can only surmise you are either the unluckiest Ferrari owner on earth or you have not been doing a good job of choosing contractors. I have been in this business a long time and have been witness to many nightmare scenarios but never one person with so many. No question there are many bad shops and dishonest or unqualified people but there are many that are honest and very skilled. You need to do something different in your selection process.
    I am not petitioning for your business, far from it but I will be happy to privately help you select someone who can meet your needs.
  21. fastradio
    fastradio F1 Rookie
    Apr 26, 2006
    3,664
    New England
    David Feinberg
    Contact:
    Tom Meadows
    Marelli Service in CA
    He did a pair of 330 distributors for me. The before and after resulting were astonishing. Nice person to work with...
  22. bundas
    bundas F1 Veteran
    Dec 31, 2005
    7,090
    lexington ky usa
    mitchell barnes
    Thank you. No one has mentioned this. Even FOSF. I THINKABLE this has the path to a finish
  23. bundas
    bundas F1 Veteran
    Dec 31, 2005
    7,090
    lexington ky usa
    mitchell barnes
    Colin inspection this morning. Yesterday the fourth poop had a lot of bright red blood , a lot
  24. fastradio
    fastradio F1 Rookie
    Apr 26, 2006
    3,664
    New England
    David Feinberg
    The ones that are exceptional fly way under the radar. Best of luck with your project....
  25. Ferrari Tech
    Ferrari Tech Formula 3
    Mar 5, 2010
    1,215
    Georgia
    Wade Williams
    #275 Ferrari Tech, Apr 18, 2016
    I can fix them, I have the knowledge and special equipment.
    PM me.
