360 water pump and thermo change | FerrariChat
Discussion in 'Technical Q&A' started by 78bonanza, Nov 30, 2019.
  1. 78bonanza
    78bonanza Formula Junior
    Apr 1, 2018
    331
    Jim Cear
    Going to change the water pump and thermostat on my 360 . I have the shop manual . Ordered parts,gaskets,clamps, etc from Ricambi.
    Any other hints, tips or advise on the change ?
  2. tazandjan
    38,083
    Likely more advice available in the 360/430 forum, if it has not already been covered.
  3. Rifledriver
    34,119
    Austin TX
    If you do not use an Airlift the 360 is notoriously hard to bleed.
    2NA likes this.
  4. vincep99
    vincep99 Formula 3
    Jun 8, 2009
    1,931
    Agreed, look on the 360 section.
    Rifledriver is right (as always) about bleeding. You can;t even see the bleed screw. I used a goose-neck inspection scope so I could locate it and loosen it. Still a PIA
  5. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    12,662
    San Carlos, CA
    Mitchell Le
    Use an Airlift.
    2NA likes this.
  6. 78bonanza
    Apr 1, 2018
    331
    Jim Cear
    Ordered , on its way
