360 Twin Turbo - specs | FerrariChat
Discussion in '360/430' started by superflyte, May 13, 2019.
  1. superflyte
    superflyte Karting
    Jun 4, 2009
    101
    Melbourne, VIC
    Troy
    Hi all. I'm gathering all the parts for a twin turbo build on my 360 motor, and was interested in knowing what brand and spec turbos and wastegates people are using for this.
    All info greatly appreciated. Thanks
  2. BAD430BENZ
    BAD430BENZ Formula Junior
    May 13, 2014
    709
    EL PASO , TX
    JASON
    • Twin 5857 Billet Turbos
    • (8) 780cc Injectors
    • (2) Tial Wastegates
    • Boost Logic Twin Air to Water Intercoolers
    • Boost Logic Water Tank
    • Boost Logic Heat Exchanger1
    • Boost Logic Resonated Exhaust System
    • Rebuilt Ferrari Clutch
    • Custom Tune on Factory ECU
    Drestless likes this.
  3. BAD430BENZ
    May 13, 2014
    709
    EL PASO , TX
    JASON
    Just depends what kind of power you are looking to make . I use this kit and it is well worth it .
    More power = more issues :eek::eek::eek:
    _JERRY_ likes this.
  4. JoeTSI
    JoeTSI Formula 3
    1,433
    Huntsville, AL
    Joe K.
    As Jason stated above, this is all dependent upon what power levels you are reaching for and what your budget is to get there. Ultimately, the tune is the most important factor especially on vehicles of this pedigree which may also limit those who have the experience to do so. What is listed above is just the bare minimum to run a few psi on stock internals. Anything more than that will require a built engine and heads and that will get expensive in a hurry for these motors. For reference, I have built many forced compression engines from Supra's to a V8 TT Esprit so I know enough to be dangerous.
    BAD430BENZ likes this.
  5. BAD430BENZ
    May 13, 2014
    709
    EL PASO , TX
    JASON
    I am happy with this kit and would never upgrade internals :D:D:D
  6. one4torque
    one4torque F1 Veteran
    5,709
    Houston
    One4torque
    Bb—. What is hp tq and boost for your setup?
  7. BAD430BENZ
    May 13, 2014
    709
    EL PASO , TX
    JASON
    never stuck it on a dyno but basically 6-8lbs for 550whp :D
    .....and trust me when i tell you , this thing is a blast with this power !
  8. superflyte
    superflyte Karting
    Jun 4, 2009
    101
    Melbourne, VIC
    Troy
    Thanks for the info. What size diameter are the primary pipes in the headers, typically?
    And twin external wastegates instead of big single as per F40?
  9. BAD430BENZ
    May 13, 2014
    709
    EL PASO , TX
    JASON
    Unfortunately , i was not the one that fabricated or designed the kit so i can't give you those kind of specs . You are more than welcome to reach out to Boost Logic for all the info you need on their bolt-on kit :D
  10. MaranelloDave
    MaranelloDave Formula 3
    Apr 27, 2010
    2,203
    LA
    Dave
    Wow, $25,000 just for the parts. Now that's a Ferrari tax.
