360 spider e2 fault code | FerrariChat
Discussion in 'Technical Q&A' started by m302ho, Mar 20, 2020.
  1. m302ho
    m302ho Rookie
    Oct 1, 2019
    5
    Québec
    Stéphane Langlais
    Somebody know what e2 fault code in top module is.
    The top stop working, microswitch I can reach is fine and I only have a e2 fault code.
    The top is closed, Tomorrow I gonna manuely open it and look to find all microswitch.
  2. 2NA
    2NA F1 World Champ
    Dec 29, 2006
    18,221
    Twin Cities
    Tim Keseluk
    I have no idea what the "E2" you referred to is. What are the symptoms? What do you mean by "stop working"? Does the pump run? Is the engine lid closed? If the top closed successfully, I don't think limit switches are your problem. What is the symbol on the multi-function display when you try to operate the top?
  3. 2NA
    2NA F1 World Champ
    Dec 29, 2006
    18,221
    Twin Cities
    Tim Keseluk
    Is the battery fully charged? Low voltage can cause problems.
  4. tbakowsky
    tbakowsky F1 World Champ
    Sep 18, 2002
    19,935
    The Cold North
    Tom
    Never seen "e2" as a fault either. What machine are you using to read the top ecu? What is the top not doing?
