Replacing the oil pressure sender on my 360 2003 Spider. Did a search and found the VDO 360-021 gauge will fit... rather than OEM. I know it needs a thread converter but can’t find details. Appreciate some guidance. Regards.
I used VDO part #360-025 with this adapter. http://www.issprogauges.com/Metric-Adapter-Fitting-p/iss-r7965.htm
Thanks...appreciate the quick replies. Question.... is the OEM sender made by VDO? or... Do people replace by the VDO sender because it’s cheaper or more reliable than OEM. Thanks.
Got the new oil sender in...the VDO gauge that needs the thread crossover. Made sure to connect the WRK terminal to the original wire...not to G. Started the car and pressure was maxed on the gauge at 140. Engine still cold. Haven't driven it yet to see if it settles to a more reasonable figure. Anyone have similar experience? Comments. Appreciate it.
I think you have the terminals reversed - G is the variable signal, WK is warning light which 360 does not use. Connect the signal wire to "G" terminal.
Agree with this. Turn the ignition to accessory and look through the rear window as you change the terminals. If it jumps all the way to the right, its grounding out and the wrong one.
Ok I’ll try this but when the ignition is on the gauge reads 0 psi. It’s only when the engine is running that the needle climbs to 140. I was also real careful to look at the old connections when I took them off. Appreciate the help.
Ok I reversed my connections.... how does it go... mea culpa mea culpa etc. You were both correct. Thank you. I was so damn careful as well... even marked the old connection on the car, and colored the new connection in case it was difficult to see the G and WRK. I think I am the first recorded case of mechanical dyslexia! Thank you both again.
I ended up going this direction and am having trouble -- received my VDO 360-021 and R7965 adaptor i am assuming the nut pictured on the back of the VDO sender will spin off and the adapter spins on in its place? But i can't seem to break it free with the wrenches i've got / holding the VDO unit in a vice. Does anyone have any suggestions or am i doing something stupid / did i get the wrong stuff? Image Unavailable, Please Login
doh. thanks @mello So VDO 360-021 has thread: 1/4"-18 NPT -- am i correct in assuming I need a M18 to 1/4" NPTF adaptor? Anyone have an immediate suggestion / can someone confirm so I don't mess up again? looks like https://www.fittings.space/gtm2p-m18x15m-08zf is an option? Another seems to be https://www.threadtoolsupply.com/m18x15-to-12-14-npt-steel-thread-adapter.html Edit: for anyone who comes along after me. VDO 360-025 has thread 1/8"-27 NPT and needs adaptor R7965 to go from M18 X 1.5 to 1/8" NPTF VDO 360-021 has thread: 1/4"-18 NPT and needs adaptor (options above) to go from M18 X 1.5 to 1/4" NPTF. DO NOT order R7965 with VDO 360-021, as above.
just leaving additional breadcrumbs for anyone coming behind -- here's the thread that got me to order the VDO 360-021 instead of the -025. https://www.ferrarichat.com/forum/threads/360-oil-sending-unit-sensor.433173/#post-142819273 Specifically, the -025 has the two poles which would be needed for the warning light on the F430, would work on the 360 but would potentially add confusion at install time. The -021 only has the one pole so nothing to mistakenly connect to.
When I did the sender replacement years ago, I was hard-pressed to find the right adapter for the 360-021. That's why I went the 360-025 with the R7965 adapter route. You might just have to do the same. BTW, I put a silicone sock on the new sender to protect it from the engine temperature. I bought it from Ricambi, and not an exact fit for the 360-025. Had to make some cuts to it to make it fit.
Thanks mello. Definitely causing more work for myself at this stage. Note to anyone following along the two adaptors I listed above ARE NOT right. those are 1/2 NPT and not 1/4. This so far appears to be the only option i can find on the internet: https://www.fittings.space/gtm2p-04zf-m18x15m (and i am definitely not an expert and definitely not sure it will work yet).
Hello,I am encountering some fluctuations in my oil pressure reading and am considering changing the oil sender on my 2004 360. Performity did this adapter work for you? “This so far appears to be the only option i can find on the internet: https://www.fittings.space/gtm2p-04zf-m18x15m” And can anyone direct me to a thread that shows the procedure. Thanks, Todd
I've taken a very different approach after several super expensive and super frustrating lessons learned in Ferrari ownership. 1) don't try to save money on hacky parts / approaches, just do things right the first time 2) labor (even my own) is way more expensive than parts in almost every case (but not every case) As such -- I'd personally only use the Ferrari part here. it's $120 from Eurospares. https://www.eurospares.co.uk/Parts/135940/Ferrari/New/45014 Not to say that I don't take advantage of Maserati parts when they're direct compatible, or buying Bosch MAFs without the Ferrari logo -- but things like this where the part isn't a direct compatible and requires an adaptor? Too much risk to save too little dollars in my book. Costs way more time and effort to get to the part than it's worth in savings. YMMV etc.
Just to echo the above, when the sender went on my car.. I bought a direct Ferrari replacement from Ricambi. It was like $140 bucks? $160 maybe?.. but I knew it would work. Just unbolt the terminals and oil filter for room, unscrew with wrench, screw back on and done.
I’d have no problem fitting a vdo oil pressure sensor, just make sure any adapters are up to the task of vibrations heat pressure w a 8500 rpm exotic. Im not sure I’d want to run that pictured adapter w what appears to be a rubber o ring…. I would not want to pump the oil out of my Fcar.
How often do you guys see these sensors failing in your applications? I bought my 2003 360 in ~2013 and then changed the oil sensor because the reading was all over the place...now ~10 years later I am having some inconsistent readings again. Basically pegged at max when driving and middle when idle. Nothing has changed, oil level is good, temp readings are a little low (but this was on a cooler day and I have the challenge intake retrofitted which I think makes things run cooler). Thoughts? Image Unavailable, Please Login Image Unavailable, Please Login
My 2001 modena oil p sender was reading very low p at idle when warm.. 29k miles. new sender oil p steady at normal range now.
