360 Modena F1 - Jerky transmission | FerrariChat
Discussion in 'Technical Q&A' started by Andrea348, Jul 30, 2020.
  1. Andrea348
    Andrea348 Rookie
    Apr 29, 2013
    2
    Italy
    Hi everyone,
    Lately, I experienced some problems with the transmission of my 2003 360 Modena F1 car, I did not before. When the engine is still cold and I downshift, for few seconds the transmission jerks. Then, when engine is hot, problem practically disappears. In normal driving and in upshifting no problem appears and the transmission is always smooth, also with engine cold.
    Did anyone experience the same problem? Could be a signal of a needed service for the clutch or something worst?
  2. tazandjan
    38,087
    Sounds like a good start would be to service the F1 system. F1 fluid should be changed every three years and the system bled, leak checks made, and a self test run. PIS can also be optimized at that time to give best service from the clutch.
  3. Ferrari Tech
    Ferrari Tech Formula 3
    Mar 5, 2010
    1,126
    Georgia
    Wade Williams
    Sounds like the throw out bearing is dragging when cold. I have seen this before. It will require resealing the throw out bearing. If that is the issue. You should seek a qualified Ferrari tech with the proper diagnostic tools to handle this job. It may not need to be rebuilt as tazandjan said, it may just need to be serviced, again by a qualified Ferrari tech with the proper tools.
  4. Andrea348
    Andrea348 Rookie
    Apr 29, 2013
    2
    Italy
    Thank you for your suggestions, I'll check and then update you
    Ferrari Tech likes this.
