360 - 360 Misfire Issue | FerrariChat
360 360 Misfire Issue
Discussion in '360/430' started by Aeron Fout, Aug 1, 2020.
  1. Aeron Fout
    Aeron Fout Karting
    Nov 21, 2019
    88
    Cocoa Beach, FL
    flyadf
    This morning I went to start my 2001 360 and it was running very rough and the check engine light was on. I shut it down and immediately smelled very rich fuel in the engine bay. It was throwing misfire codes for cylinders 1 thru 4.
    The car just had its major service about 1k miles ago including all new belts, intake gaskets, and spark plugs.
    I’m thinking this could potentially be an injector problem, but I think it’s more likely the ECU that runs cylinders 1 they 4. It seems strange to me that one entire side of the engine would misfire at one time.
    Just for information, the car was last ran about a week ago for a 50 mile drive and it was perfect. I would greatly appreciate anyone’s input or experience on this issue. Thanks
  2. KC360 FL
    KC360 FL Formula 3
    Jun 20, 2017
    1,937
    Melbourne Florida
    KGC
    Coil packs? common but I didn't get any CEL.
    sparetireless and Aeron Fout like this.
  3. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,834
    Central NJ
    Dominick
    Did you start too quickly and not wait for "ok" on dash
    Sent from my moto g(7) using Tapatalk
    Aeron Fout likes this.
  4. Aeron Fout
    Aeron Fout Karting
    Nov 21, 2019
    88
    Cocoa Beach, FL
    flyadf
    No, I just started it the way I always have.
  5. Aeron Fout
    Aeron Fout Karting
    Nov 21, 2019
    88
    Cocoa Beach, FL
    flyadf
    I don’t see how all four cool packs on one side of the engine could go bad at once.
    Penzinger and Apollo 11 like this.
  6. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,834
    Central NJ
    Dominick
    The reason I ask if that sometimes if you turn key on and not wait for "ok" and start ..one of the ECU may not "turn on" ..
    I would say try to start again but wait for "ok" and see if that helps
    By any chance is battery old and weak ?
    Skidkid and one4torque like this.
  7. Aeron Fout
    Aeron Fout Karting
    Nov 21, 2019
    88
    Cocoa Beach, FL
    flyadf
    I’ll give it a try and see if waiting a little longer on starting helps out. The battery is about 4 months old and always stays on a battery tender.
    flash32 likes this.
  8. S F
    S F Karting
    May 13, 2016
    166
    Texas
    Just went through this. I had random misfires on an entire bank and a very rich running condition on half of the engine. It turned out to be the mass air flow sensor on my car. I went ahead and replaced both along with plugs and o2 sensors and it runs beautifully now.
    My Foxwell OBD2 scanner was able to show the mass air readings on both ECUs, in my case, one was reporting half of the airflow of the opposite bank which was causing all of my issues as the fueling was way off.
  9. KC360 FL
    KC360 FL Formula 3
    Jun 20, 2017
    1,937
    Melbourne Florida
    KGC
    yup, sorry I read your post and thought you said 1 and 4, not 1 thru 4
    But with that said, I had 21K miles on my '03 360 and had a few going bad and replaced all eight. But again, no CEL just random misfires I could feel in the driver's seat.
  10. one4torque
    one4torque F1 Veteran
    5,699
    Houston
    One4torque
    Highly likely mass air meter.
    try swapping a known good mas
  11. Aeron Fout
    Aeron Fout Karting
    Nov 21, 2019
    88
    Cocoa Beach, FL
    flyadf
    Thanks for the info. I’m probably going to go ahead and replace the mass airflow sensors and o2 sensors.
  12. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,834
    Central NJ
    Dominick
    Before we start changing parts ..
    Start with the easy stuff ..starting properly.. pulling codes , check if the oil was over filled and caused maf to fail
    A good diag tool is needed if you want to see what is going on
    I do agree it can be the maf but a diag tool would tell you either in codes or data stream ..
    Considering you had a service ..could be a overfill which caused the maf to fail
    You can always move parts from one side to the other to see if that helps and narrow down part
    Skidkid likes this.
  13. Aeron Fout
    Aeron Fout Karting
    Nov 21, 2019
    88
    Cocoa Beach, FL
    flyadf
    I just swapped them side to side and it seems to have reversed the issue to the opposite bank. I’m going to order 2 new MAF sensors.
    rudkinjc likes this.
  14. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,834
    Central NJ
    Dominick
    Cool ..glad we were able to narrow it down .. was it oil that caused it ..did you see alot of oil residue ?
  15. Aeron Fout
    Aeron Fout Karting
    Nov 21, 2019
    88
    Cocoa Beach, FL
    flyadf
    There was some oil residue on both sensors, but more on the misfire side. I’m going to pull the intake tubes off and see how much oil is inside the top of the manifold.
  16. Skidkid
    Skidkid F1 Veteran
    9,502
    Campbell, CA
    John Zornes
    Overfill on the oil causes oil getting into the intake. Oil and MAF don't mix and next thing you know, they are shot. Check the oil level engine warm and idling. Set the cap on the reservoir, don't screw it down. You wouldn't want to replace the MAFs only to ruin the new ones because you didn't chase down an overfill.
  17. Aeron Fout
    Aeron Fout Karting
    Nov 21, 2019
    88
    Cocoa Beach, FL
    flyadf
    Good advice. Thank you
  18. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,834
    Central NJ
    Dominick
    Exactly my thoughts ..[emoji106]
  19. Need4Spd
    Need4Spd F1 Veteran
    Feb 24, 2007
    6,678
    Silicon Valley
    Even oil fumes too close to MAFS will degrade their performance without throwing codes.
  20. S F
    S F Karting
    May 13, 2016
    166
    Texas
    Good deal. Did you order by the Bosch part numbers? I was able to get the pair for a little over $200 doing it that way. Substantial savings over ordering the Ferrari part numbers and the exact same units showed up.
  21. brookliner7
    brookliner7 Formula Junior
    837
    San Antonio, TX
    Hans
  22. Aeron Fout
    Aeron Fout Karting
    Nov 21, 2019
    88
    Cocoa Beach, FL
    flyadf
    I haven’t ordered them yet. Who did you order yours from?
  23. S F
    S F Karting
    May 13, 2016
    166
    Texas
    Rock auto was the best price I could find but recommend you look around as they’re probably all drop shipped from the same supplier.
  24. velocegiallo
    velocegiallo Karting
    101
    California
    I had similar symptoms recently on mine. Turned out it was one bad coil pack. CEL showed misfire on several cylinders. Shop ID’d and replaced the bad coil and now perfect.
  25. KC360 FL
    KC360 FL Formula 3
    Jun 20, 2017
    1,937
    Melbourne Florida
    KGC
    Keep an eye on the others. The extreme heat in the engine bay cooks the insulation, that cracks, and then the misfires begin. If one went I'm betting it's not long before others bite the dust.
    I bought mine (Bosch) online at e-bay and replaced all 8 at once. It's a simple job you can do yourself. No need to pay a shop for the labor on this one or the mark up on the parts.
    All the best, Ken
