360 aftermarket suspension | FerrariChat
Discussion in '360/430' started by Easy888, Jan 28, 2020.
  1. Easy888
    Easy888 Formula Junior
    Sep 28, 2006
    515
    CA, NV
    Jim
    Guys, I'm at a crossroads and could use some help.
    The initial plan was to get KW coilovers for the 360, but turns out because the Novitec name was slapped on there in conjunction with KW, the system now is $5K+. The same suspension that went on my 997 was a little under $3K if I recall correctly. So not really willing to pay double for similar product.
    That said, for those who have extensively looking into modifying the suspension componentry of the 360, please share your findings on alternatives. I have heard JRZ makes coilover units. Anyone here have experience with the brand?
    I'm open to even just using aftermarket springs (if Eibach or H&R makes any) and also sway bars. For the sway bars and springs, I looked into swapping out the existing units for the CS versions, but coming across those are difficult.
    Thanks.
  2. Tubi Sales
    Tubi Sales Karting
    Jul 5, 2019
    172
    PHX
    JRZ is a very good brand compared frequently with KW.
    JRZ isn't as well known stateside but they are quite the brand when it comes to the worldwide market.
    I'm actually helping one of my good friends who is working on his 458 get a set of JRZ's currently. Take a look at the photo below.
    I received this photo from JRZ today saying that the 458 coilovers just finished pre-production and are set to be finished tomorrow.
    Figured it would be good to share.
    tifosi101 likes this.
  3. GCalo
    GCalo F1 Veteran
    Sep 15, 2004
    7,645
    Northern California
    Greg Calo
    Look at AFCO's 23400CR springs at 400 lbs for the front.
    Unfortunately they are available only as chrome plated now at $60.00 each.
    However, they are a fantastic spring for the 360/430 front, and they are very cost effective
    You can adjust the ride height as you please w/o having to deal with another's pre-set ride height
  4. tazandjan
    39,150
    They can be painted with the right primer.
  5. GCalo
    GCalo F1 Veteran
    Sep 15, 2004
    7,645
    Northern California
    Greg Calo
    These were originally supplied in a yellow paint.
    Apparently it's a ton of work to paint over chrome.
    Here is what I found-
    To paint over a chrome surface, start by sanding it so the paint is able to stick to it. Then, wipe down the chrome surface with wax and grease remover so it's clean when you paint it. Before you apply any paint, add 2 coats of two-part epoxy primer, allowing the primer to dry after each coat
  6. GCalo
    GCalo F1 Veteran
    Sep 15, 2004
    7,645
    Northern California
    Greg Calo
  7. DonJuan348
    DonJuan348 F1 Rookie
    Aug 5, 2008
    4,442
    Taxing Jersey
    What’s the price of JRZ ? Are they available for 360 and what’s the website.
    I’m looking to put on coil overs to eliminate the faulty electronics.
  8. Tubi Sales
    Tubi Sales Karting
    Jul 5, 2019
    172
    PHX
    Hey Don,
    I'll send you a PM with the pricing for the 360 along with the website information.
  9. DonJuan348
    Aug 5, 2008
    4,442
    Taxing Jersey
    Thanks Mike
  10. tifosi101
    tifosi101 Karting
    Jun 12, 2013
    90
    France
    Could you please share at least an idea of price ?
    And pictures ?
