360/430 Spider Cracked Frame Piece | FerrariChat
Discussion in '360/430' started by EastMemphis, Aug 30, 2020.
Tags:
  1. EastMemphis
    EastMemphis Formula 3
    May 25, 2019
    1,853
    Memphis, TN
    I found today exactly why this frame piece cracks. It's because of that bar that should go rearward when the top is opened. When it doesn't, this frame piece impacts it rather hard when it flops over at the 90 degree point. The bar moves back because of the elastic band built into the headliner.
    For anyone that's had problems with the bar not moving backwards, check to see if you have cracks in this frame piece.
    The solution is to replace the elastic bands that move the bar, or if you're a purist, replace the headliner.
    If you don't know what the bar is, then it's very likely your top is functioning properly up to now.
    Need4Spd likes this.
  2. EastMemphis
    May 25, 2019
    1,853
    Memphis, TN
    Just for reference, this posting is in regard to the "LH Front Convertible Top Casting Frame". Every frame for sale on ebay is or was cracked and listed for ~$1000.
    This is a right side part.
  3. delaney
    delaney Formula Junior
    Nov 8, 2003
    717
    Montgomery TX
    PETER DELANEY
    Get it welded. $50. Repaint. Perfect.
