355 Water Pump | FerrariChat
355 Water Pump
Discussion in '348/355' started by kalinsd, Oct 10, 2016.
  1. kalinsd
    kalinsd Formula Junior
    Apr 14, 2010
    438
    Washington
    DJ
    #1 kalinsd, Oct 10, 2016
    Think the water pump seal is on the way out. Left side of clutch housing is showing signs of antifreeze, while the other side is clean. Also, the antifreeze is showing on the oil sump. If not the water pump, what might it be?
    BTW, the car does not drip any coolant onto the floor.
    Thanks in advance.
    DJ
  2. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    13,541
    San Carlos, CA
    Mitchell Le
    I am not sure that would be my diagnosis.
  3. PAP 348
    Dec 10, 2005
    100,216
    Mount Isa, Australia
    Pap
    Something is starting to weep DJ, that's for sure.
    Can you pressure test the cooling system yourself?
    If not, take it to someone who can pressure test the cooling system for you so you/they can inspect for leaks.
    It could be the water pump, but it could be a hose clamp that needs to be nipped up a 1/4 of a turn.
    Definitely have the cooling system pressure tested, it's the only way to know for sure what is leaking mate.
  4. dougburhyte
    dougburhyte Karting
    Dec 28, 2005
    166
    Douglas Burhyte
    DJ - Could be the seal, as it does fail in the 355. I had a similar problem... smelled a bit of anti-freeze while driving with the targa top removed but didn't have visible signs of a leak. If you have a means to pressurize the cooling system to, say, 5-10 psig, which I think is close to normal when the engine is warm and running, you might be able to detect some leakage around the seal. Mine was pretty minor, so I lived with it for a couple of years until I had the engine-out service performed. Hope this helps.
    Doug
  5. yelcab
    Nov 29, 2001
    13,541
    San Carlos, CA
    Mitchell Le
    If the water pump seal fails, the water drips out of the weep hole under the pump, gets splashed around by the spinning action of the belts and sprays it to the left front of the engine.
    The leaks onto the case of the transmission points to a possible coolant leak over the top of the engine. There are so many possibilities. A pressure test will tell right away.
  6. kalinsd
    Apr 14, 2010
    438
    Washington
    DJ
    Thanks everyone. Pressure Test It Is!
    Best,
    DJ
  7. PAP 348
    Dec 10, 2005
    100,216
    Pap
    Good man, please let us know what happens. :)
  8. kalinsd
    Apr 14, 2010
    438
    Washington
    DJ
    Need to get this pressure test completed. Would like to get a recommendation on which tester to purchase.
    Thanks and will report back on what is found on this poor old and tired 355....
  9. yelcab
    Nov 29, 2001
    13,541
    San Carlos, CA
    Mitchell Le
    Install the new waterpump. Fill car with coolant. Apply Stant pressure tester unit to the coolant tank (with a specific tank cap adapter). Watch for leaks.
  10. kalinsd
    Apr 14, 2010
    438
    Washington
    DJ
    Long overdue update on the cooling system leak on the 355........ Used the Motive Pressure Bleeder to charge the system to ~15lbs and found the leak. Located just in front of the right head is a hose/clamp where the clamp was just finger tight. A few twists on that clamp, repressurized the system and no leaking.
    Dumping the oil and want to dump the old gas too. Less than a 8th of a tank of gas and wondering if the remaining gas is easily drained via the plug at the bottom of the tank? Once that plug is removed, will it require a gasket or is the existing reusable.
    Thanks and looking forward to at least driving this one to Cars & Coffee. Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
  11. spaghetti_jet
    spaghetti_jet Formula Junior
    Jan 5, 2005
    925
    Europa
    Bob
    the brass bolt on the bottom of the fuel pump housing is the drain plug. You will get virtually all the fuel out from there. Getting the plug out creates a mess, but once out it drains straight down.
    There is a small rubber o ring on the drain plug and they’re pretty cheap, so worth changing.
    I thought my tank was almost empty, I did maybe 80km with the fuel light on and I was almost caught out by the amount of fuel still in there. Prepare cans for double whatever you think is in there. It’s no fun to run out of cans while the fuel is still gushing out.
    Qavion likes this.
  12. Ferrarium
    Ferrarium F1 Veteran
    Sponsor Rossa Subscribed
    Jul 28, 2018
    5,728
    Central NJ
    Eric
    After the low fuel light comes on there is still 5 gallons of so left. At least in mine there was. What a mess.
    taz355 likes this.
  13. kalinsd
    Apr 14, 2010
    438
    Washington
    DJ
    Gentlemen all! Thanks for the heads up. I've lots of storage containers for the old gas.
