348 wheels 18 or 19s ? | FerrariChat
Discussion in '348/355' started by Fast mustang, Dec 21, 2014.
  1. Fast mustang
    Fast mustang Karting
    Nov 15, 2014
    173
    Island lake Il
    Ron
    Would like your guys thoughts on wheel size for a Ferrari 348 18 s or 19 s and let's see some pics on what you have thanks
  2. awilson
    awilson Formula Junior
    Sep 15, 2013
    368
    Annapolis Md
    Andrew G. Wilson,II
    I am interested in this also. Andy
  3. Oengus
    Oengus F1 World Champ
  4. driveitdaily
    driveitdaily Formula 3
    Jul 20, 2013
    1,041
    lake ariel pennsylva
    john
    18's , its a small car , 19's look too big
    18's on my 348 in this pic
    1994 ferrari 348 spider , third owner purchased may 2013 w/ 27804 miles[​IMG]
  5. RaginBull
    RaginBull Formula Junior
    Oct 24, 2006
    996
    Bay Area, CA
    Darryl
    Looks great! For me, i want to fill the well especially the gap in the rear but dont want it too low to the ground. The 19's will achieve this and leaves room to lower the stance to fill the gap
  6. harleyx49
    harleyx49 Karting
    Jun 26, 2013
    122
    Hutchinson, MN
    #7 harleyx49, Dec 21, 2014
    Dino L likes this.
  7. driveitdaily
    Jul 20, 2013
    1,041
    john
    That does look fantastic . That is the only aftermarket ?wheel i like on the 348 , imho . Whatever they are ,i like em !
  8. chas-3
    chas-3 Formula 3
    1,270
    Colorado
    Chuck
  9. driveitdaily
    Jul 20, 2013
    1,041
    john
    #10 driveitdaily, Dec 21, 2014
    You need to be careful of offsets and wheel widths , a lot of rubbing can go on , do a search , you will find a lot of discussion on this topic . Filling the opening will look great , but will suck if they rub over every bump and dip . Good luck
  10. Wade
    Mar 31, 2006
    32,793
    East Central, FL
    Wade O.
  11. plugzit
    plugzit F1 Veteran
    7,677
    Redondo Beach, CA
    Bruce Bogart
    19s leave VERY LITTLE sidewall to absorb potholes, etc. Split sidewalls, bent wheels result. You don't carry a spare. How far you going?
    vvassallo and 2NA like this.
  12. 4rePhill
    4rePhill F1 Veteran
    Oct 18, 2009
    8,180
    Worcester, England
    Phill J
    Just to add:
    The 348 is quite stiffly sprung so if your roads are a bit rough you could find that the car becomes a bit too crashy on 19's and no longer a pleasure to drive.
    albert328gts likes this.
  13. Fast mustang
    Nov 15, 2014
    173
    Island lake Il
    Ron
    Are any of your cars have that's have 19s lowered to as well or stock height
  14. 4rePhill
    4rePhill F1 Veteran
    Oct 18, 2009
    8,180
    Worcester, England
    Phill J
    The car sits on adjustable coil-overs so what's "stock" height?
  15. AceMaster
    Feb 6, 2009
    34,570
    Ontario, Canada
    I think 18" is just right for the 348
  16. DonJuan348
    DonJuan348 F1 Rookie
    Aug 5, 2008
    4,441
    Taxing Jersey
    I had 19s on mine and they were perfect
  17. driveitdaily
    Jul 20, 2013
    1,041
    john
    #18 driveitdaily, Dec 21, 2014
    In post # 4 , image 5887 . Imho , take a close look ,the size and offset of those rear wheels make it look like a clown car
    The 348 is a wide short car , and i think the wide rear looks good , but go too wide with the rear wheels and the car looks wider than it is long , not good .
  18. DonJuan348
    Aug 5, 2008
    4,441
    Taxing Jersey
    Huh???
    make it look more aggressive definitely handles much better with wider rubber and lower stance
  19. D N M
    D N M Karting
    Dec 20, 2013
    68
    Chicago area
    Dan
    #20 D N M, Dec 21, 2014
    I have the same 19 wheels as harleyx49...... I think they look great on this car, however, I also have the original 17s in case I'd ever want to convert the car back to OEM
  20. Fast mustang
    Nov 15, 2014
    173
    Island lake Il
    Ron
    There's alot more wheel choices in 19 I'm finding out as well
  21. Meister
    Meister F1 Veteran
    5,516
    Duluth, MN
    The Meister
    pretty sure those are 360 modular wheels, my favorite too
  22. Robb
    Robb Moderator
    Moderator Lifetime Rossa Owner
    Feb 28, 2004
    13,903
    Robb
    Ron,
    I like the 19's but think the 18's improve on the oem 17's and sit perfectly without "overdoing it."
    Robb
  23. 4rePhill
    4rePhill F1 Veteran
    Oct 18, 2009
    8,180
    Worcester, England
    Phill J
    In the World of BMW E46 M3's there's a saying:
    "19's for show - 18's to go!"
    Basically, test drivers found that 18" wheels gave a fantastic ride and suited the chassis really well, but on 19" wheels, which they said looked better, the car became too crashy and felt more nervous resulting in the car being slower and less enjoyable to drive on twisty roads.
    The other problem with 19's on a 348 (as some have already noted), is that the 348 was designed for 17" wheels and so 19's look like the wheels are too big for the car, giving a bit of a "Hot Wheels" look. This also applies to the 355. Basically the 19's are out of scale to the car.
    The 360 cars onwards were designed for 18"+ wheels and so 19" wheels still look to be in scale to car and suit them better.
    At the end of the day it's a personal choice that no one else can make for you, but I'd be wary of making car too stiff (due to the lack of side wall), and making the car less of a pleasure to drive.
    For Me personally, going is far more important than showing!
  24. DonJuan348
    Aug 5, 2008
    4,441
    Taxing Jersey
    If 19s is " hot wheel" then there's no better look that exists
