348 / F355 / 355F1 DIY Technical Threads | FerrariChat
Discussion in '348/355' started by Robb, Oct 31, 2020.
Thread Status:
Not open for further replies.
  1. Robb
    Robb Moderator
    Moderator Lifetime Rossa Owner
    Feb 28, 2004
    14,322
    Robb
    #1 Robb, Oct 31, 2020
    This will be added to over the winter break and on into the future. If you know of a great DIY and technical help thread, please send it to me in a PM. As usual, use all this info at your own risk. Special Thanks to @GrigioGuy for the template from the 3x8 sections... Special Thanks to all the contributors for their time and shared expertise.
    348
    Motor / Engine Out
    http://www.ferrarichat.com/forum/technical-q/305475-348-fuel-injector-intake-plenum-removal.html
    https://www.ferrarichat.com/forum/threads/348-engine-out-major.438576/
    https://www.ferrarichat.com/forum/threads/purge-valve-hoses.595670/
    https://www.ferrarichat.com/forum/threads/185577-updated-oil-chain-tensioner.514804/#post-144530590
    https://www.ferrarichat.com/forum/threads/phase-sensor-replacement.599455/
    Timing Belt Discussions
    http://www.ferrarichat.com/forum/technical-q/148604-setting-up-cams.html
    http://www.ferrarichat.com/forum/technical-q/148917-degreeing-cams.html
    https://www.ferrarichat.com/forum/threads/348-cam-drive-chain-tensioner.593867/
    Suspension / Brakes / Steering
    http://www.ferrarichat.com/forum/technical-q/241309-348-front-bearing-removal.html
    http://www.ferrarichat.com/forum/technical-q/356344-348-rear-camber-adjustment.html
    http://www.ferrarichat.com/forum/technical-q/310176-348-coil-removal.html
    http://www.ferrarichat.com/forum/348-355/241324-348-front-wheel-bearing-removal.html
    https://www.ferrarichat.com/forum/threads/348-front-sway-bar-bushings.481910/
    https://www.ferrarichat.com/forum/threads/348-master-cylinder-abs.516911/
    https://www.ferrarichat.com/forum/threads/handbrake-alignment.338227/
    https://www.ferrarichat.com/forum/threads/348-steering-rack-removal.568601/#post-145798093
    Wheels and Tires
    https://www.ferrarichat.com/forum/threads/348-wheels-reference.409616/
    https://www.ferrarichat.com/forum/threads/348-355-360-wheel-offset.600577/
    https://www.ferrarichat.com/forum/threads/348-wheel-thread.580414/
    Exhaust
    http://www.ferrarichat.com/forum/technical-q/253394-348-o2-sensor-removal.html
    http://www.ferrarichat.com/forum/technical-q/241642-348-vapor-canister-purge-valve-removal.html
    http://www.ferrarichat.com/forum/technical-q/20378-mass-air-flow-sensor-adjustment.html
    http://www.ferrarichat.com/forum/348-355/391409-if-you-like-weld-have-quiet-348-a.html
    Cooling
    http://www.ferrarichat.com/forum/technical-q/385608-348-thermostat-removal.html
    https://www.ferrarichat.com/forum/threads/348-coolant-leak-under-plenum.647876/
    Fuel system
    http://www.ferrarichat.com/forum/technical-q/224988-348-fuel-pump-rebuild.html
    http://www.ferrarichat.com/forum/technical-q/346550-348-throttle-body-throttle-position-sensors-removal.html
    http://www.ferrarichat.com/forum/technical-q/193188-348-gas-tank-removal.html
    https://www.ferrarichat.com/forum/threads/how-to-change-the-fuel-pressure-regulator-on-348s.121977/
    https://www.ferrarichat.com/forum/threads/slight-fuel-leak-very-pressurized-tank.552548/#post145558111
    Electrical / Lighting / Bulbs / Gauges / Starter / Ignition
    http://www.ferrarichat.com/forum/technical-q/142329-348-alternator-removal-rebuild.html
    http://www.ferrarichat.com/forum/technical-q/351819-348-ecu-removal-chip-removal.html
    http://www.ferrarichat.com/forum/technical-q/150812-obd2-codes.html
    http://www.ferrarichat.com/forum/348-355/353742-real-cheap-spark-plug-wire-set.html
    http://www.ferrarichat.com/forum/348-355/371562-shift-light-cool-toy-installation-demonstration.html
    http://www.ferrarichat.com/forum/348-355/347627-gold-kit-video.html
    http://www.ferrarichat.com/forum/technical-q/46232-348-door-wiring-connector-repair.html
    https://www.ferrarichat.com/forum/threads/changing-bulbs-in-355-348-3rd-brake-light-pictorial.89076/
    https://www.ferrarichat.com/forum/threads/348-motronic-2-7-connector-harness-repin.444155/#post143057320
    https://www.ferrarichat.com/forum/threads/348-maf-adjustment.167575/#post137074650
    https://www.ferrarichat.com/forum/threads/348-bosch-2-7-ecu-pin-out-and-functions.478805/#post143754667
    https://www.ferrarichat.com/forum/threads/348-speedo-burned-internals.503511/
    https://www.ferrarichat.com/forum/threads/348-starter-sometimes-it-just-clicks.305582/#post-145968398
    https://www.ferrarichat.com/forum/threads/ferrari-348-ignition-switch.585995/
    https://www.ferrarichat.com/forum/threads/fuel-sender-repair-348-defect-in-my-opinion.596552/
    https://www.ferrarichat.com/forum/threads/alternator.601964/
    https://www.ferrarichat.com/forum/threads/348-alternator-removal-rebuild.142329/
    Transmission / Differential / Clutch
    http://www.ferrarichat.com/forum/technical-q/372483-348-throwout-bearing-removal.html
    http://www.ferrarichat.com/forum/technical-q/296274-348-clutch-removal.html
    http://www.ferrarichat.com/forum/348-355/124766-348-transmission-removal.html
    http://www.ferrarichat.com/forum/technical-q/101885-pap348-gearbox-oil-change-9.html
    https://www.ferrarichat.com/forum/threads/348-clutch-release-bearing-stoogie-style.301895/
    https://www.ferrarichat.com/forum/threads/triple-seals-and-pumpkin-installation-another-way.500255/
    https://www.ferrarichat.com/forum/threads/348-ratio.234915/
    Climate Control
    https://www.ferrarichat.com/forum/threads/repairing-348-climate-control.19629/
    https://www.ferrarichat.com/forum/threads/348-dead-hvac.453511/
    https://www.ferrarichat.com/forum/threads/my-fix-for-the-348-climate-control-problem-with-pictures.478776/
    https://www.ferrarichat.com/forum/threads/hot-wiring-the-348-heater-valve.578459/
    https://www.ferrarichat.com/forum/threads/348-recirculation-door-for-the-hvac-is-non-functional.400666/
    https://www.ferrarichat.com/forum/threads/348-hvac-amp-connector-re-pinning.588390/
    https://www.ferrarichat.com/forum/threads/hvac-flap-motor-and-hiden-fuse.590569/
    https://www.ferrarichat.com/forum/threads/view-inside-the-climate-control-ecu-info-request.596451/
    Interior
    http://www.ferrarichat.com/forum/348-355/402628-carbon-dip-door-sills-diy.html
    http://www.ferrarichat.com/forum/technical-q/368608-how-fix-clean-348-maybe-others-window-switches.html
    https://www.ferrarichat.com/forum/threads/glove-box-fix.594614/
    Exterior / Bodywork / Doors / Mirrors
    https://www.ferrarichat.com/forum/threads/348-automatic-door-lock-fix-howto.445416/
    https://www.ferrarichat.com/forum/threads/replacing-the-door-latch-cable-in-my-ferrari-348-the-rest-of-the-story.461259/
    https://www.ferrarichat.com/forum/threads/replacing-door-speakers-and-installing-window-accelerators-in-my-348.461000/
    https://www.ferrarichat.com/forum/threads/348-door-hinge-overhaul.522051/#post144684456
    https://www.ferrarichat.com/forum/threads/348-side-mirror-fix.233238/
    Windows
    http://www.ferrarichat.com/forum/technical-q/106031-simple-solution-348-slow-windows.html
    http://www.ferrarichat.com/forum/348-355/304893-glass-348-slow.html
    http://www.ferrarichat.com/forum/technical-q/310804-slow-window-fix-less-than-$30-00-a.html
    https://www.ferrarichat.com/forum/threads/348-window-motor-serviceable.590600/
    Radio / Antenna
    https://www.ferrarichat.com/forum/threads/installing-sony-radio-in-my-348.460998/
    https://www.ferrarichat.com/forum/threads/348-roof-antenna-removal.573978/
    Spider Tops / GTS Tops
    Restores, Refurbs and Similar
    https://www.ferrarichat.com/forum/threads/the-in-famous-358-rises-from-the-dead.304864/
    Mega Picture Thread
    https://www.ferrarichat.com/forum/threads/picture-of-your-348-you-took-today.482397/
    Misc
    http://www.ferrarichat.com/forum/technical-q/318113-how-read-ferrari-vin-vehicle-identification-number.html
    https://www.ferrarichat.com/forum/threads/the-348-registry-is-live.192516/
    https://www.ferrarichat.com/forum/threads/the-official-348-355-sale-thread-non-affiliated-sales-or-links-to-ferrariads-only.131671/
    F355 and 355F1
    Motor / Engine Out
    https://www.ferrarichat.com/forum/threads/355-engine-out-with-4-post-hoist-the-safe-way-with-pictures.234071/
    https://www.ferrarichat.com/forum/threads/355-f1-engine-is-out.181966/
    https://www.ferrarichat.com/forum/threads/355-reassembly.231696/#post-138407599
    https://www.ferrarichat.com/forum/threads/355-head-rebuild-pics.197627/
    https://www.ferrarichat.com/forum/threads/355-major-part-1-how-to-drop-the-engine.53351/
    https://www.ferrarichat.com/forum/threads/any-355-owner-rebuikd-their-own-lifters.476284/
    https://www.ferrarichat.com/forum/threads/355-major-with-some-upgrades.576995/#post-146009697
    https://www.ferrarichat.com/forum/threads/setting-the-cam-timing-belts-on-a-355.130430/
    https://www.ferrarichat.com/forum/threads/degreeing-cams.148917/
    https://www.ferrarichat.com/forum/threads/a-not-so-expensive-brake-upgrade-for-f355.258160/
    https://www.ferrarichat.com/forum/threads/non-air-bag-oem-steering-wheel-fit.393653/
    https://www.ferrarichat.com/forum/threads/how-to-update-the-power-steering-tank-on-a-355.292079/
    https://www.ferrarichat.com/forum/threads/355-airbag-removal.176453/
    https://www.ferrarichat.com/forum/threads/f355-shock-acuators.385614/
    https://www.ferrarichat.com/forum/threads/how-to-remove-the-steering-rack-from-a-355.430060/
    https://www.ferrarichat.com/forum/threads/how-to-rebuild-a-power-steering-rack-f355.505342/
    https://www.ferrarichat.com/forum/threads/shock-actuators.209629/
    Wheels and Tires
    https://www.ferrarichat.com/forum/threads/painting-challenge-wheels.383847/
    Exhaust
    https://www.ferrarichat.com/forum/threads/simple-2-7-slow-down-ecu-replacement-only-for-no-cats.538719/
    https://www.ferrarichat.com/forum/threads/excess-fuel-in-cat-converter.576429/
    Cooling
    https://www.ferrarichat.com/forum/threads/355-coolant-change-procedure.420845/
    https://www.ferrarichat.com/forum/threads/replaced-radiator-fans-on-f355-today-easy-project.284513/
    Fuel system
    https://www.ferrarichat.com/forum/threads/f355-alternator-rebuild-update-with-part-numbers.124504/
    https://www.ferrarichat.com/forum/threads/thermocouples-slow-down-lights-related-cels-and-how-to-conquer-them.378429/
    https://www.ferrarichat.com/forum/threads/355f1-oil-temp-gauge-clock-swap.382211/
    https://www.ferrarichat.com/forum/threads/hid-lights-possible-on-f355-newbie-question.72653/
    https://www.ferrarichat.com/forum/threads/f355-coil-on-plug-conversion.36012/
    https://www.ferrarichat.com/forum/threads/355-headlamp-pod-going-strange.393013/
    https://www.ferrarichat.com/forum/threads/led-dash-lights.355399/
    https://www.ferrarichat.com/forum/threads/relays-in-355-for-what.500973/
    https://www.ferrarichat.com/forum/threads/355-5-2-engine-harness.501337/
    https://www.ferrarichat.com/forum/threads/355-actuator-gear-fixed.198923/
    https://www.ferrarichat.com/forum/threads/seatbelt-warning-light-cabling.525227/#post-144748714
    https://www.ferrarichat.com/forum/threads/f1-accumulator-bulb-replacement-procedure.555260/
    https://www.ferrarichat.com/forum/threads/best-spark-plug-for-the-355.212870/
    https://www.ferrarichat.com/forum/threads/make-your-own-180072-siren-cable.562869/
    https://www.ferrarichat.com/forum/threads/how-to-change-the-clutch-on-a-355.27374/#post-134345405
    https://www.ferrarichat.com/forum/threads/355-flywheel-grease.152737/
    https://www.ferrarichat.com/forum/threads/360-f1-pump-install-in-the-355.302088/
    https://www.ferrarichat.com/forum/threads/bleeding-355f1-system.402272/
    https://www.ferrarichat.com/forum/threads/355-f1-pump-and-motor-fix.549020/
    Climate Control
    https://www.ferrarichat.com/forum/threads/355-climate-control-air-direction-not-working.431747/
    https://www.ferrarichat.com/forum/threads/355-heater-control-valve.560559/
    Interior
    https://www.ferrarichat.com/forum/threads/how-to-remove-the-f355-kick-plate.420968/
    https://www.ferrarichat.com/forum/threads/f1-reverse-level-fix-in-detail.516118/#post-144559224
    https://www.ferrarichat.com/forum/threads/free-diy-ferrari-f355-ashtray-repair-by-sticky-rx.526414/
    https://www.ferrarichat.com/forum/threads/removing-front-bumper.481669/#post144719395
    https://www.ferrarichat.com/forum/threads/355-door-panel-removal-how-to.191977/
    https://www.ferrarichat.com/forum/threads/how-to-remove-outer-door-panel-and-replace-door-handle-on-355.434508/
    https://www.ferrarichat.com/forum/threads/f355-f-shield-placement.507100/
    https://www.ferrarichat.com/forum/threads/door-sill-rocker-panel-removal-355.187113/
    https://www.ferrarichat.com/forum/threads/rear-brake-duct-moulding-removal.599915/#post-146598566
    Radio / Antenna
    https://www.ferrarichat.com/forum/threads/procedure-to-cure-a-355-spider-roof-that-does-not-close-properly-due-to-old-fluid.316148/
    https://www.ferrarichat.com/forum/threads/fear-not-the-seat-pot-potentiometer-how-to-rebuild-one-without-removing-it.288373/
    https://www.ferrarichat.com/forum/threads/how-to-repair-f355-spider-top-sensor-for-power-windows.522719/
    https://www.ferrarichat.com/forum/threads/355-spider-convertible-top.128103/
    https://www.ferrarichat.com/forum/threads/1995-f355-gts-restoration-and-major-service.493751/page-45#post-147479858
    https://www.ferrarichat.com/forum/threads/95-berlinetta-weight-reduction-and-modifications.548376/
    https://www.ferrarichat.com/forum/threads/my-355-mini-restoration-story.341922/
    https://www.ferrarichat.com/forum/threads/on-the-road-again-robbs-ferrari-adventures.510456/
    Mega Picture Thread
    https://www.ferrarichat.com/forum/threads/picture-of-your-355-you-took-today.404360/
    Market Thread
    https://www.ferrarichat.com/forum/threads/f355-market.487947/
    Misc
    https://www.ferrarichat.com/forum/threads/jack-pads-355.546821/
    https://www.ferrarichat.com/forum/threads/355-annual-fluid-change.360307/#post-141297064
    https://www.ferrarichat.com/forum/threads/helpful-information-for-those-in-search-of-a-355.447037/
    https://www.ferrarichat.com/forum/threads/355-owners-map.437156/
    https://www.ferrarichat.com/forum/threads/355-registry.123485/
    https://www.ferrarichat.com/forum/threads/understanding-obd-ii.458652/
