308 Main Shaft and Lay Shaft Lock Nuts | FerrariChat
Discussion in 'Technical Q&A' started by brook308, Jan 14, 2020.
  1. brook308
    brook308 Formula Junior
    Oct 19, 2007
    339
    SS Coast, Australia
    George
    Hi All,
    I need to strip the gearbox in a 308 as a bearing has failed.
    Have the 56mm ring tools to undo the lock nuts x 4.
    Just need to know the thread direction for these nuts, which ones are LH thread and which are RH?
    Cheers
    George
  2. brook308
    Oct 19, 2007
    339
    SS Coast, Australia
    George
  3. Steve Magnusson
    25,149
  4. fatbillybob
    Aug 10, 2002
    26,430
    socal
    I have always just looked at the ringnut and shaft and could see enough to determine LH or RH.
  5. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    12,662
    San Carlos, CA
    Mitchell Le
    ****, I would not know to even look at the threads unless I have an inkling that there is a need for a left handed thread. That is not obvious.
  6. brook308
    Oct 19, 2007
    339
    SS Coast, Australia
    George
    Hi Steve, yes your diagram above is correct for LH and RH thread.
    Cheers
    George
  7. brook308
    Oct 19, 2007
    339
    SS Coast, Australia
    George
    Yes Steve your diagram is correct.
  8. Steve Magnusson
    25,149
    Thank you -- you can see that they made an error in the item numbers on TAV 27 and have 14 and 15 swapped.
  9. 2dinos
    2dinos F1 Rookie
    Jan 13, 2007
    2,780
    Thank you for that correction!
