308 GT4 Engine Rebuild | FerrariChat
Discussion in '308/328' started by marklintott, Jan 6, 2018.
Tags:
  1. marklintott
    marklintott Formula Junior
    579
    Taipei Taiwan / Somerset UK
    Mark Lintott
    Taking my daughter to the airport after my father's funeral back in June my GT4 packed up on the M5 heading to Bristol UK. A loud bang was followed by massive drop in power and a sound like nuts in a tin can......
    Of course I pulled over immediately and it was flat bedded back home. Great start to my sole ownership. I used to share it with my Dad and split everything 50/50. When he passed I got the lot so there's a sense he's smiling down on me but not in a good way!
    We're in the West country UK and qualified repair places are few and far between. It was suggested I check out Ftech and Carrs the "local" main dealer. Both were highly recommended even for this age of car. In the end I opted to leave it with Ashley and Chris at Braunton Engineering, Devon as they have worked on it before and although mainly Porsche people Ashley was keen to do the work.
    I''m overseas most of the time so the first chance I had to meet with them face to face was after they had removed and fully stripped the engine. First pics were emailed to be beforehand and its clear what happened. Few pics below....
    Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
  2. bertspeed
    bertspeed Formula Junior
    Sep 19, 2009
    302
    wow,sorry to hear of your misfortune. At least when its done you can drive it with a peace of mind. What was the history of the cars use,did it sit for long periods or something else that may have caused this.
  3. marklintott
    579
    Mark Lintott
    Met with Ashley just before Christmas. He had fully stripped and examined most parts. It all cleaned up very well and despite the usual trouble of separating the heads from the block it all looks pretty good. Heads have been lightly skimmed, new valves and guides fitted and high comp pistons ready to go in. They still have to renew the big end and small end bearings but basically the bearing surfaces looked okay.
    I had assumed this was all caused by the notorious sodium valves hence the valve head floating around in no. 1 cylinder. In fact on closer inspection it looks like the front timing belt slipped a tooth introduced the exhaust valves to the pistons on that bank. There are slight dents in each piston crown for that bank. The broken one put a hole in its piston and slightly damaged the area of head between the 2 valves. Why the belt slipped I don't know. They were changed a couple of years ago and its done little mileage since then. However the guard on one of the pulleys has broken off. The originals seem to be all plastic of some sort and perhaps a stone or something got thrown up into the pulley causing it to slip and break.
    Anyway other items to be done "while we're in there" are:
    New JE piston set with all new bearings, bolts caps etc
    Higher flow valves from Superformance
    Stone guards to protect the cam pulleys and belts on the engine side
    New pulley set - not sure yet if to use the Forza set from the US or go for the more basic model from Superformance
    Replace the forward manifold with SS to match the rear
    Renew all hoses throughout including the long ones going to radiators
    Renovate the engine bay to bring it back to "as new"
    Some minor rust repairs although generally it seems pretty solid from underneath
    More pics below...
    cheers
    Mark
    Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
    Roward7 likes this.
  4. marklintott
    579
    Mark Lintott
    Thanks. It will be nice to be more confident in the mechanicals and perhaps a very slight increase in performance...
    Its only done a certified 36000 miles so yes its spent long periods sitting around throughout its life. Inevitably that's not good.
    It did strike me that I've seen several 308's in the past without the black shields protecting the cam belts etc. This can't be good and rather invites dirt and debris into this area.
    Mark
    PDB and Pero like this.
  5. PDB
    PDB Formula Junior
    Feb 1, 2011
    575
    Leicestershire, UK
    Paul
    It looks like he’s doing a good job. Those pistons look nice.
    These cars need to be used and used hard. The engines are really strong if they’re well maintained and used regularly. I took mine to Spain and back in September and it didn’t miss a beat. They’re fantastic classics for touring with great luggage space and a terrific ride.
    Paul
    marklintott likes this.
  6. kiwiokie
    kiwiokie Formula 3
    Aug 19, 2013
    1,464
    Tulsa, OK
    John McDermott
    Those pistons have a high dome and pronounced ridge between the valves that I dont remember my JE Pistons having. From memory they did not have any off-the-shelf 308GT4 pistons. Did you supply drawings for them to use?
  7. killer58
    killer58 Formula 3
    Jun 30, 2010
    1,190
    CA & DC
    Perhaps the valve did fail. Then, as the piston compressed the remains, the belt slipped due to the resistance? Just a thought (guess).
    marklintott and Mike Florio like this.
  8. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    12,662
    San Carlos, CA
    Mitchell Le
    I don't know if they have replaced the liner orings, but you should ask them to. For a job this big, it would be a shame not to do that. Check the flatness of the deck, as well as liner protrusion.
    derekw likes this.
  9. marklintott
    579
    Mark Lintott
    I think they came from Superformance here in the UK although I didn't order them myself. I'm assuming they'll fit...! :eek:
    Comparing the old ones to the new - you're right there is quite a difference in their height. They are described as "high compression" which might account for it. Ashley at Braunton said he would be dry assembling the heads/block/pistons etc to check clearances which sounds like a good idea considering the extra space taken up by the piston crowns.
    Mark
  10. marklintott
    579
    Mark Lintott
    Yelcab, thanks - good reminder on the O rings. I believe the liners have been out and checked during disassembly so I'm fairly sure the O rings would have been replaced then. Worth double checking though. The deck and heads have been checked for flatness already and all is okay apparently.
    Anybody got any suggestions for other things to check/replace while the engine is out? I thought about replacing the engine mounts but when cleaned up and inspected they seem to have got a clean bill of health.
  11. Squirrelmonkey
    Squirrelmonkey Karting
    Dec 27, 2010
    126
    Manitoba ,Canada
    Tom Thieme
    Cam drive bearing seals for sure ! They will be hard as a rock by now and will shatter eventually ! Talk about oil leaks !!! lol
    Yeah someone mentioned the liner O-rings ?? very important to change them out. It would suck the have a coolant leak into your oil after you have installed all those nice expensive gaskets etc.
  12. marklintott
    579
    Mark Lintott
    Update on my GT4 rebuild....
    Finally got to pick up my baby from Braunton Eng on my birthday after what's been more than a year since it detonated on me last may.
    Ashley and Chris from Braunton did a great job and more than expected in terms of "while I'm in there" stuff. They repainted most of the accesible chassis members, renewed the firewall insulation, hoses etc etc. Car goes great and very smooth. There is still some fine tuning to be done on the carbs which I think are probably overdue for a full rebuild. Lots of popping and a slightly irregular idle but the change in performance is very noticable. Ashley will take a look at it when he brings back my other Italian.
    We're not entirely sure of cause of the original failure but it seems to have been a sodium valve that broke and made the belt jump a tooth or two. In the process it put a hole in a piston. Or possibly a stone thrown up from the road got into the belts causing one to jump etc. In the process it took the lip off one of the cam sprockets. These seem to be some kind of plastic which seemed odd to me. I've now got stone guards fitted to protect the belts etc - from Superformance.
    Can't recommend Braunton Engineering enough. They have done what they promised close to the budget promised and have always been open to discussion or questions. (the length of time is down to me being so far away most of the year)
    I'm glad its over and the car is home again. Once a few teething issues are ironed out it will be better than ever. Thinking of saving up for electronic ignition to eliminate the weaknesses of the original single distributor set up but that for next year I think.
    Anyway, here's a few progress pics to bring the thread up to date.
    sltillim likes this.
  13. Portofino
    Portofino Formula Junior
    Sep 17, 2011
    578
    Yorkshire UK / Switzerland/ Liguria ( Italy )
    Portofino
    Great to see it back .
    What do the stone guards look like and where do they fit please .
  14. marklintott
    579
    Mark Lintott
  15. marklintott
    579
    Mark Lintott
    Just some closure on this thread. After Braunton finished the engine re-build (excellent job by the way) COVID kicked off and I didn't get back to the UK until last week. Since then Carrs in Exeter reinstalled the AC, overhauled the cooling system, rebuilt and balanced the carbs and fitted a Pertronix electronic system. They also went thru the electrics and the brakes/suspension completely and I've managed to put a few hundred miles on it in the last week - despite the appalling weather!
    Heads up to Carrs and in particular Harvey in the shop who have been brilliant to deal with and very very helpful in getting everything in tip top shape. It has never been this good - starts on the button, stops in a straight line and idles smooth enough for the edge of a coin trick on the airbox!
    Looking forward to some spring sunshine and events to geet some more use out of it. Knowing its now reliable makes it a much better bet for trips and events over the summer.
    mark
