308 Cam Belt Drift | FerrariChat
308 Cam Belt Drift
Discussion in '308/328' started by waymar, Jan 17, 2020.
  1. waymar
    waymar Formula 3
    Sep 2, 2008
    1,354
    Northeast, PA - USA
    Wayne Martin
    308GTSi 1982 I Image Unavailable, Please Login 308GTSI 1982 I installed new cam pulleys from Superformance. The cam belts now drift to the end of the pulley guide after cold cranking the starter. The front belt drifts outboard and the rear belt drifts inboard. I changed out the tension bearing twice to eliminate one variable. The belts are both facing the same direction with the printing. My OEM pulleys did not experience drift. Has anyone experienced similar issues? Thank you for any input. Regards Wayne.......
  2. Rifledriver
    37,043
    It can only be caused by misalignment of the pulleys. The cam pulleys can only be off if the heads were resurfaced off of straight or the cam bearings were align bored wrong. It is usually caused by a tensioner bearing or mounting issue.
    mike996 likes this.
  3. mwr4440
    57,919
    Bavaria, The 'Other' Germany
    Mark W.R.
    Brian,
    Can you elaborate and exactly what to look for?
  4. Rifledriver
    37,043
    Something, anything that prevents the pulley axis from being exactly parallel to the lower drive pulleys or the cam pulleys.
    I forgot another possibility. It will do that if the bearings on the lower drive gears are bad but in that case it should drive to belts forward, not back.
  5. mike996
    mike996 F1 Veteran
    Jun 14, 2008
    6,868
    Mike 996
    "My OEM pulleys did not experience drift."
    Verify that the pulleys are correctly installed/seated correctly. If so, put the OEM pulleys back on. If they don't drift, leave the OEM's in place. Running it as it is is losing a fair bit of the belt's "tooth strength." You definitely don't want that! ;)
  6. Rifledriver
    37,043
    I agree completely. Also I have seen the fences tear up the belts.
  7. Rifledriver
    37,043
    Mike said something that makes me think of another possibility. Never seen it with factory pulleys so did not think of it before. If for some reason in the manufacturing either of the pulleys is tapered it would do that too. It doesn't take much.
    Why did you replace the original pulleys?
    derekw and 2NA like this.
  8. mwr4440
    57,919
    Mark W.R.
    If the lower drive gears are worn the 'drift' should have occurred with them too.
    Yes?
  9. Rifledriver
    37,043
    Absolutely. But after a few revolutions no matter the source of the problem it will end up at the edge of every pulley.
  10. waymar
    waymar Formula 3
    Sep 2, 2008
    1,354
    Northeast, PA - USA
    Wayne Martin
    I put the OEM pulleys back on. The belt runs to the outboard side now but not up against the fence ...... I will change out the front bank tomorrow. Interesting...... Image Unavailable, Please Login
  11. 2NA
    2NA F1 World Champ
    Dec 29, 2006
    18,221
    Twin Cities
    Tim Keseluk
    It should be easy to measure the new pulleys for taper. This looks like it must be the problem.
  12. mike996
    mike996 F1 Veteran
    Jun 14, 2008
    6,868
    Mike 996
    Yeah, as long as the full width of the belt is on the pulley, it's fine, no need to be centered. As noted, I'd agree that the aftermarket replacement pulleys are defective. :(
  13. fatbillybob
    Aug 10, 2002
    28,912
    socal
    Interesting. This thread got me thinking about fences. I have never seen belt walk but my datapoints are low. I have seen the aftermath of walking where there is failure ripped up timing gears or fence chewing belt or fence falling off. There are many who like to tack weld the fence to the cog with some pretty stout TIG welds. Ferrari makes cogs that seem to last the life of the motor yet poorly peens on the fences. I have seen many fences rattle on the cog. This is either sloppy lazy cheap or fences are somewhat to maybe useless to Ferrari. On the 308 the head has inboard and outboard fences. I guess that is some kind of belt security desire. On the 550 there are no fences at all preventing the belt from riding off. It all depends on parallelism of the system. I guess the OP's pics make a case for fences! It was smart to crank the motor and check your work. I'm pretty sure 90% of people would have closed everything up and unknowingly run those pullys to perhaps a failure.
    Right or wrong I think of the fences as not real important. Are you pros welding fences? Helms is a big fence welder. I have TIG, MIG, and gas in a state of readiness within 20ft of me yet I have never bothered to weld a fence that wasn't loose.
  14. derekw
    derekw Formula 3
    Sep 7, 2010
    1,521
    London, UK
    Derek W
    Wayne, it’s worth giving the lower pulleys a wiggle while in there as the bearings are prone to wear in the 2V and early QVs with 40mm bearings. I agree with others than there may be a slight taper on the new pulleys. If you have the steel OEM pulleys, stick with them. I’m sorry I dropped the ball a bit on sending you a set— a move across the pond got in the way :-(
  15. Rifledriver
    37,043
    The only cars I have ever seen loose fences on were 3.4s and I almost never work on them. I have never welded one. Lots of cars dont have fences on any but the drive pulley. More than that should never be needed.
  16. 2NA
    2NA F1 World Champ
    Dec 29, 2006
    18,221
    Twin Cities
    Tim Keseluk
    Looks like you have a couple pulleys on backwards. The fences should alternate.
  17. waymar
    waymar Formula 3
    Sep 2, 2008
    1,354
    Northeast, PA - USA
    Wayne Martin
    Tim thank you for the input. I checked the pulley direction and they match the diagram. I will take apart the tension assembly and make sure it doesn’t stick before tightening later or tomorrow. Garage is mid 40s today with the high wind and cold.
  18. Rifledriver
    37,043
    The picture you are looking at is a 550, not a 308.
  19. 2NA
    2NA F1 World Champ
    Dec 29, 2006
    18,221
    Twin Cities
    Tim Keseluk
    The drawing I posted in #16 is for a 550. FBB posted a picture from his 550.
    If everything is running true, fences shouldn't really be necessary, except for one on the drive.
  20. johnk...
    johnk... F1 World Champ
    Jun 11, 2004
    11,214
    CT
    John Kreskovsky
    No fence on 550 cam pulleys. All 4 are the same.
  21. smg2
    smg2 F1 World Champ
    Sponsor
    Apr 1, 2004
    16,307
    Dumpster Fire #31
    SMG
    If I'm not mistaken on the 550 and those without alternating cam pulley fences, the idler pulley on the tensioner has a crown, we're talking in the thousandths of an inch. The lower drive is an outboard fence uppers are inboard, properly aligned pulleys won't need much to keep the belt in place, the fence is more of a "bump" stop, poorly aligned pulleys the belt will 'walk' right off, even with a fence.
    If you've watched the belts hum along at near redline the fence makes sense, harmonics and frequency cause the belt to move similar to a plucked guitar string, the belt will move about a bit when doing this, very different from walking off due to poor alignment.
  22. johnk...
    Jun 11, 2004
    11,214
    CT
    John Kreskovsky
    No fences on the cam pulleys. Drive pulley has inner and outer fences. Don't know about the bearing.
  23. waymar
    waymar Formula 3
    Sep 2, 2008
    1,354
    Northeast, PA - USA
    Wayne Martin
    Update: Superformance wants to examine the pulleys and will ship them back to the main mfg. I also noted the fences have burrs and some burrs face the belt side. I have my OEM pulleys back on now. Cheers.
    Milkshaker0007 likes this.
  24. Casino Square
    Casino Square Formula 3
    1,728
    Hong Kong / USA
    Andrew
    That is the thing I appreciate about Superformance, they really do care about their products and customer service. I have experienced that first hand.
