308,328, & Dino Gearbox Oil Change Procedure: VIDEO | FerrariChat
Discussion in '308/328' started by Nuvolari, Apr 12, 2021.
  1. Nuvolari
    Nuvolari F1 Veteran
    Sep 3, 2002
    6,422
    Toronto / SoCal
    Rob C.
    I've been playing a little with YouTube to try and create some videos outlining service procedures. Having benefited from tons of other peoples content I figured this would be a good way to give back.
    I have no illusions of becoming a YouTube star and am not even interested in running ads to monetize my channel. The content is free and without commercials but I would like to know that someone is at least watching my videos. If you like what you see please like, share, comment, and subscribe to my channel. I'm at barely over 90 followers so my first goal is to get to 100.
    Also please let me know what service videos you might be interested in and I'll see what I can do to make some.
    For now here is a video just released showing the procedure to change the gearbox oil in a 308, 328, or Dino including oil recommendations and some tips and tricks:
  2. mike996
    mike996 F1 Veteran
    Jun 14, 2008
    6,691
    Mike 996
    Good video! FWIW, I can't remember ever buying a new copper crush washer - I always anneal the old one just as you show. It's not because I'm cheap (or "mean" if you're in the UK), it's because I always forget to buy one! ;) An embarrassing lesson I learned is that often a used aluminum crush washer will have a hint of copperish color and you may think you will anneal this "copper" washer...only to see it melt in heat of the propane torch!
    maurice70 and Nuvolari like this.
  3. Du_Man
    Du_Man Formula Junior
    278
    Dallas, Texas
    Derek
    Really enjoyed watching the video last night, Rob - I even enjoyed not having to see every little step like "watching the oil being drained".
    I would love to see the procedure on how to adjust the gearshift linkage/forks/bushing.........." looking at the forks in the gearbox while a partner shifts thru the gears". But you know what that means......draining the gearbox oil! o_O liked and subscribed.......
    SJP 5 and Nuvolari like this.
  4. Lawrence Coppari
    Lawrence Coppari Formula 3
    Apr 29, 2002
    2,153
    Kingsport, TN
    Lawrence A. Coppari
    Aluminum washers can be annealed in a similar fashion. Lower temperatures are needed.
  5. Brian A
    Brian A F1 Rookie
    Dec 21, 2012
    3,086
    SanFrancisco BayArea
    1983 US 308 GTS QV
    Cool video! It was fun to watch even though I knew/do all the stuff you show.
    ... well, okay, I fill from the gearbox plug and the transfer case plug but I may try your way next time.
  6. bill brooks
    bill brooks F1 Veteran
    5,240
    waynesburg,pa
    bill brooks
    WOW! what a clean underside! and i thought my 328 was clean. you've shamed me!
  7. maurice70
    maurice70 F1 Rookie
    Jan 25, 2004
    4,319
    maurice T
    Been there, Done that :D
  8. JuLiTrO
    JuLiTrO Formula Junior
    Nov 2, 2017
    383
    Julio Saiz
    I am your 101 subscriber
    Good videos!
  9. Nuvolari
    Nuvolari F1 Veteran
    Sep 3, 2002
    6,422
    Toronto / SoCal
    Rob C.
    Thanks for the views and subscriptions. It is nice to know that people out there are seeing the videos and it also re-enforces that YouTube star is not in my future. Either way I'll keep making videos that will hopefully help someone in the middle of a mechanical bind.
    The project I really want to do is a comprehensive series that takes you through the Weber carbs, how to re-build them, and how to tune them. I did a blog on this many years back that was really well received and figure a video version can only be better.
    Now that I have said it in public and put it out there I have to do it :)
    SJP 5 and maurice70 like this.
  10. JuLiTrO
    Nov 2, 2017
    383
    Julio Saiz
    Cannot wait
    THANK YOU!
  11. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    5,692
    Central NJ
    Dominick
    Subscribed
  12. Milkshaker0007
    Milkshaker0007 Formula Junior
    Sep 22, 2012
    428
    Midlands,uk
    Paul
    104 now, cheers
  13. thorn
    thorn F1 Rookie
    3,322
    Tallahassee, FL
    Buy a pack of them on Amazon for like $8 while you're still thinking about it.
    Also, you aren't the only one that melted an aluminum one experimenting with annealing. ;)
