"250 GTO:" Drogo rebody mystery | FerrariChat
Discussion in 'Recreations & Non-Period Rebodies' started by VisualHomage, Jun 18, 2012.
  1. VisualHomage
    VisualHomage F1 Veteran
    Aug 30, 2006
    5,611
    San Antonio
    #1 VisualHomage, Jun 18, 2012
  2. miurasv
    miurasv F1 World Champ
    Nov 19, 2008
    10,722
    Cardiff, UK
    Steven Robertson
    Some of Drogo's designs look absolutely fantastic. So where do we look to find out if we guessed correctly?
  3. 2000 CVPI
    2000 CVPI Karting
    Apr 29, 2012
    135
    Maitland, FL
    Alex H.
    Carburetor setup?
  4. VisualHomage
    Aug 30, 2006
    5,611
    San Antonio
    #4 VisualHomage, Jun 18, 2012
    Agree.
    And that is the mystery: where do you look to identify the answer to: What gives this Ferrari away as not being a re-bodied GTO? When you guess correctly I will tell you.
  5. VisualHomage
    Aug 30, 2006
    5,611
    San Antonio
    That was my best guess but that is not the visually identifying trait.
    For readers in general, remember the body itself can be anything. It is the chassis and serial number that determines the car as being a real Ferrari. And a real Ferrari this is --but it is not a GTO. How can you tell it is not a GTO by visual-only discernment?
  6. miurasv
    Nov 19, 2008
    10,722
    Cardiff, UK
    Steven Robertson
    Well, the 6 pot instead of 12 is obvious. What about the c/n 2493GT identifying the car as a 250 GTE and dating it to 1960 and the first 250 GTO wasn't built until the end of 1961?
  7. Meister
    Meister F1 Veteran
    5,516
    Duluth, MN
    The Meister
    While not overly familar with the smalest details of real GTO's at first glance the side vents seem wrong and the entire windsheild/door and window frame/roof area does not look right. Windsheild seems to flat and wide, door window frame/roof geometry seems off as well. And fenders near bottom of window don't seem to dip enough.
    Novice guess....
  8. VisualHomage
    Aug 30, 2006
    5,611
    San Antonio
    Good guesses but this car is a V12. 3 deuces can be made operative on a Ferrari V12. So that is not a solid visual cue to set it apart as being a non-GTO chassis.
  9. VisualHomage
    Aug 30, 2006
    5,611
    San Antonio
    Remember, the body can be anything as long as the chassis is created as a GTO, marked with a GTO SN#. How can you tell this is not a GTO chassis from the photo? You CAN tell, just keep looking.
  10. miurasv
    Nov 19, 2008
    10,722
    Cardiff, UK
    Steven Robertson
    Is the longer wheelbase of the 250 GTE evident behind the door or is it obvious in the body that car has a wet sump?
  11. 2000 CVPI
    2000 CVPI Karting
    Apr 29, 2012
    135
    Maitland, FL
    Alex H.
    It retains the 250 GTE wheelbase? This is the only other thing I can think of, lol.
  12. VisualHomage
    Aug 30, 2006
    5,611
    San Antonio
    The wheelbase is longer but you cannot see that per se, but go with wet sump...... and then what happens with that setup versus a dry sump.....
  13. VisualHomage
    Aug 30, 2006
    5,611
    San Antonio
    yes it drove me nuts trying to figure it out..... go with the sump setup as a major clue ...
  14. PSk
    PSk F1 World Champ
    Nov 20, 2002
    17,673
    Tauranga, NZ
    Pete
    Are we saying that the perspex bonnet bulge is required because the engine is sitting higher than a GTO because it is a wet sump?
    Pete
  15. miurasv
    Nov 19, 2008
    10,722
    Cardiff, UK
    Steven Robertson
    Is the spare wheel where the oil tank would be on the GTO?
  16. VisualHomage
    Aug 30, 2006
    5,611
    San Antonio
    BINGO :)
  17. miurasv
    Nov 19, 2008
    10,722
    Cardiff, UK
    Steven Robertson
    Err. A GTO has a bonnet bulge.
  18. VisualHomage
    Aug 30, 2006
    5,611
    San Antonio
    Yes but he got the "engine is sitting higher" part exactly correct. A GTO's carbs would not be sitting that high in the bulge.
  19. miurasv
    Nov 19, 2008
    10,722
    Cardiff, UK
    Steven Robertson
    Well, I got the wheelbase and wet sump exactly correct first so I declare myself the winner. Lol.
  20. VisualHomage
    Aug 30, 2006
    5,611
    San Antonio
    Yes, you were on the right track, so close but .....
  21. miurasv
    Nov 19, 2008
    10,722
    Cardiff, UK
    Steven Robertson
    The story of my life, alas!!! Lol.
  22. PSk
    PSk F1 World Champ
    Nov 20, 2002
    17,673
    Tauranga, NZ
    Pete
    If I'm not home when you deliver my prize, please lock the Ferrari in my driveway and put the keys in the clothes drier you will find in our laundry (entrance via back of the house). Don't worry about our dogs they won't hurt you ... labradors.
    Pete
  23. arttidesco
    arttidesco Karting
    Oct 6, 2010
    133
    Bristol
    Ralph Colmar
    The nose is completely wrong, before you even get to the engine, squared off, too high and too short never mind the side vents being too square.
  24. VisualHomage
    Aug 30, 2006
    5,611
    San Antonio
    10/4 will do :)
  25. VisualHomage
    Aug 30, 2006
    5,611
    San Antonio
    Remember, rebodies on non-native Ferrari chassis can look like anything ;)
