246 engine weight | FerrariChat
246 engine weight
Discussion in '206/246' started by russh, Feb 14, 2021.
  1. russh
    russh Karting
    146
    Northern California
    Russell Hazarian
    Hi, I am trying to determine the weight of the 246 engine. I haven't been able to find any information with regard to the weight. I am thinking about purchasing a hydraulic lift cart to place it on.
  2. Tobi
    Tobi Karting
    Jun 24, 2011
    116
    Alto Palatinato
    I'm not sure, but the pure engine should be about 140 kg. Add another 100 kg for the gearbox and accessories to be on the safe side for sizing the lift.
    Please excuse the European weight specification, but I'm not strong in converting this to gallons or square feet or whatever imperial units are used for this ;)
  3. russh
    russh Karting
    146
    Northern California
    Russell Hazarian
    Thank you very much. I was hoping that it would be somewhere around this weight, but it was only a guesstimate on my part. I have already removed the clutch housing (drop gears), clutch, and flywheel.
  4. daviekj
    daviekj Formula Junior
    486
  5. russh
    russh Karting
    146
    Northern California
    Russell Hazarian
    Hi Kevin,
    Yes, I am looking for a 2 ton engine hoist and trying to determine their specifications. I did read through your post and I didn't realize that you had listed an estimated weight. I was focused at the time on what you had indicated for the length of the engine hoist reach. Thank you.
  6. dgt
    dgt Formula 3
    Jan 14, 2011
    1,292
    Northeast, USA & Oz
    Andrew
    I use a 2 ton crane in the longest position (0.5 ton), it works fine but you need 3 people to operate and steady it.
    Also dropping the car closer to the ground on a mid-rise lift with wheels off helps.
