246 Door pockets | FerrariChat
246 Door pockets
Discussion in '206/246' started by TonyL, Dec 28, 2019.
  1. TonyL
    TonyL F1 Rookie
    Sep 27, 2007
    3,839
    Norfolk - UK
    Tony
  2. racerboy9
    racerboy9 F1 Rookie
    2,524
    My Swiss buddy called me from Italy and I mentioned the door pockets from passione500. By chance he was 10 minutes away from them at the time. He said they went through a bunch of them to find a nice one as many were less than perfect. The nice one he found was spot on to the original pocket. Ask them to pick out a nice one if you order from them.
  3. TonyL
    TonyL F1 Rookie
    Sep 27, 2007
    3,839
    Norfolk - UK
    Tony
    The guy told me he had a batch made but were not good enough and so ordered more. I bought a set some time ago just in case my old ones got broke, they were perfect quality.
    No harm in asking though!
    Tony
  4. Eltel246
    Eltel246 Karting
    May 14, 2012
    154
    London
    Charles Hill
    Hi Tony,
    I have one metal strip missing on my original door pockets. Can you give me any info as to where I can get or how to make a replacement please,
  5. TonyL
    TonyL F1 Rookie
    Sep 27, 2007
    3,839
    Norfolk - UK
    Tony
    Charles
    You will need to get hold of a few items, luckily you have one to copy:
    1. Some half round D section nickel plated beading - most specialist model shops will sell this stuff.
    https://eileensemporium.com/index.php?option=com_hikashop&ctrl=category&task=listing&cid=1078&name=square-rectangular-tube-1&Itemid=189
    2. 2 no 3/64" pins
    3. Small section of THIN nickel sheet to make centre clip (only on mid to late E series, early m to mid e series had no centre clip)
    I didnt make the clip so it fitted into the centre hole like the originals, all I did was make the face the same and glued it into position.
    At the time all i could get was brass d section bead, but had it nickel plated once it was cut to size.
    The difficult bit is to get the d section beading to sit into the groove, get the metal warm and malleable and it will bend very easily, hook one end over the door pocket and stretch into the groove, keeping the pressure on bead, then bend the tab over the other end. Drill the pin holes either end once in place, do not drill before as the tension and flexing will break the bead.
    Tony
    Eltel246 likes this.
  6. Eltel246
    Eltel246 Karting
    May 14, 2012
    154
    London
    Charles Hill
    That's great Tony, Fantastic info. Thank You.
    Wishing you and your family a very Happy New Year.
  7. mar3kl
    mar3kl Formula Junior
    Nov 17, 2011
    454
    Silicon Valley
    Mark
  8. synchro
    synchro F1 Veteran
    Feb 14, 2005
    9,294
    CHNDLR
    Scott
    Do these have the same internal markings as originals, such as below?
    Both my pairs have sequential numbering from Right to Left which would leave one to wonder why the different sides had different cast numbers ...
  9. racerboy9
    racerboy9 F1 Rookie
    2,524
    No markings. They are a little ripply on the inside but not bad. The one I received looks dead on externally and was dirt cheap.
  10. TonyL
    TonyL F1 Rookie
    Sep 27, 2007
    3,839
    Norfolk - UK
    Tony
