For Sale - 2 Single Post Storage Lifts - $2000 (SA Airport area) | FerrariChat
For Sale 2 Single Post Storage Lifts - $2000 (SA Airport area)
Discussion in 'Other Parts & Collectibles' started by Sfumato, Feb 11, 2019.
  1. Sfumato
    Sfumato F1 World Champ
    Nov 1, 2003
    10,194
    Llanfairpwllgwyngyll, Anglesey, Wales
    Angus Podgorney
    2 used TUXEDO SP-6K-SS 6,000 LB SINGLE POST STORAGE LIFTs for sale. These were $3,800 new. Letting them go for $1,000 EACH plus you must pickup, dismantle, and load yourself. Both lifts are in good working condition and just need a good cleaning. Pictures on link below.
    PM me if interested, I’ll get you contact info
    Features:
    6000 lb capacity can handle most vehicles and light trucks
    Low profile approach ramps for vehicles with low ground clearance
    Lift can be installed to lift from left or right side
    Minimal footprint allows for multiple installations
    Low post height allows for low ceiling residential installations
    Commercial grade hydraulic cylinder and heavy duty leaf chain
    Reliable Duro electric/hydraulic cylinder
    Specifications:
    Model number: SP-6K-SS
    Lift capacity: 6000 lbs
    Max. undercar clearance: 77"
    Overall height: 110 1/4"
    Overall length: 188"
    Overall width: 112 5/8"
    Runway width: 18 7/8"
    Runway length: 152"(without ramp)
    Approach ramp length: 31"
    Clearance between runways: 42 1/2"
    Power supply: 110vac Duro electric/hydraulic pump
    Weight: 2425 lbs
    https://sanantonio.craigslist.org/pts/d/san-antonio-2-single-post-storage-lifts/6816868339.html
  2. rob lay
    rob lay Administrator
    Staff Member Admin Miami 2018 Owner
    Dec 1, 2000
    59,673
    Southlake, TX
    Rob Lay
    Lee, so the bottom car still drives up over some of the footings?
  3. Sfumato
    Nov 1, 2003
    10,194
    Angus Podgorney
    #3 Sfumato, Feb 11, 2019
    Yes. Pretty low so not huge issue. Depending how you mount it, I'd try to keep drivers door away from post, back in also helps with the footings.
    I'll try to get height of footings and post it
  4. Skidkid
    Skidkid F1 Veteran
    8,762
    Campbell, CA
    John Zornes
    Your CL post was deleted so can't access the pics.
