1999 or euro headers on US 360 | FerrariChat
Discussion in '360/430' started by eskanday, Dec 28, 2019.
  1. eskanday
    eskanday Karting
    Jun 21, 2017
    94
    Hi guys, I have 2003 F360 US model with 12k miles. I would like at one point to get rid of the stock headers with precat to prevent possible headache in the future.
    Anybody installed 1999 headers or euro headers as they are stock and without precat? Would they work? Do they cause a CEL? And how to manage the O2 rail that comes with the US cars after 1999?
  2. 360trev
    360trev F1 Rookie
    Project Master
    Oct 29, 2005
    4,330
    Gibraltar
    360trev
    On later us cars than 1999 they will trigger a CEL unless you get the codes disabled. An ecu reflash is required. Search Ferrari SAK tool for more information. Lots of posts about it.
  3. eskanday
    eskanday Karting
    Jun 21, 2017
    94
    It is amazing how limited the options we have to solve this issue. I'm aware of Tubi and fabspeed headers beside stock used Ferrari that still has the same problem. Am I missing any other option that get rid off of the precat and does not cause a CEL?
  4. one4torque
    one4torque F1 Veteran
    5,710
    Houston
    One4torque
    Some have success w the little mini o2 sensor cats extenders. I’ll try these 1st. Then just get the tune if I get cel.
  5. BrettC
    BrettC Formula 3
    Aug 13, 2012
    2,113
    Calif
    Brett
    My extenders worked fine.
  6. Some Guy in the sky
    Some Guy in the sky Formula Junior
    Sep 19, 2018
    360
    Are the euro headers different than the 1999?
  7. eskanday
    eskanday Karting
    Jun 21, 2017
    94
    Thanks, what headers do you have?
  8. andy308
    andy308 Formula 3
    Jan 16, 2005
    2,024
    Sarasota, FL
    Andy
    I put on Fabspeed headers and cats last year, no CEL or emissions problems. No extenders needed. I have a 2002 360 Modena. I used Ron Reineke in Tucker, GA to perform the work. Where are you located?
  9. one4torque
    5,710
    Houston
    One4torque
    Andy- did they tune the cel out, or you are running stock ecu and no cel? Thx
    about to do this
  10. andy308
    andy308 Formula 3
    Jan 16, 2005
    2,024
    Sarasota, FL
    Andy
    #10 andy308, Dec 31, 2019
    I will check with Ron on the details, yes on the stock ECU and no CEL. I sent Ron an email or you can call him (Ron Reineke at Sports Car Service in Tucker, GA (404) 435-6760)
  11. andy308
    andy308 Formula 3
    Jan 16, 2005
    2,024
    Sarasota, FL
    Andy
    Here is what Ron told me when I asked if he did anything special so as not to get a CEL, "nothing special ,We just made sure the timing is right on. and no intake exhaust leaks."
    I hope this helps.
  12. eskanday
    eskanday Karting
    Jun 21, 2017
    94
    Thank you Andy, I live in Maryland
    So you put headers and cats not just headers. Would the cats play a role in avoiding CEL in comparison of just changing the headers?
  13. andy308
    andy308 Formula 3
    Jan 16, 2005
    2,024
    Sarasota, FL
    Andy
    Yes headers and cats were put on. My mechanic says they did nothing else special, no CEL.
  14. BrettC
    BrettC Formula 3
    Aug 13, 2012
    2,113
    Calif
    Brett
    Stock with no precats...
  15. driller1
    driller1 Karting
    125
    New Hampshire
    Scott
    My Extenders worked fine too. After initial header and extender install we had to clear a couple codes, but it has now been several years and have been CEL free.
    one4torque likes this.
  16. eskanday
    eskanday Karting
    Jun 21, 2017
    94
    So you have US car with euro or 1999 stock headers with extenders? What did you do with the air rail?
  17. EhellGuapo
    EhellGuapo Karting
    Sep 25, 2016
    146
    Does anyone know if I can put the euro exhaust manifold (no precat, no air rail) on 03 US spec 360?
  18. Skidkid
    Skidkid F1 Veteran
    9,515
    Campbell, CA
    John Zornes
    They will fit fine. They will throw a CEL
    sparetireless likes this.
  19. EhellGuapo
    EhellGuapo Karting
    Sep 25, 2016
    146
    Picked up a pair today that came off of a low hour Challenge car that met an unfortunate end. Challenge headers, test pipes, Capristo 3, Stradale MAFs, Gruppe M intake and a Mase reflash...should be interesting!!!
  20. 02360spider
    02360spider Formula 3
    May 27, 2015
    1,749
    Dartmouth
    Richard oliveira
    Are they parting out any more parts of that challenge car I would be interested in some stuff
    Sent from my SM-N981U1 using Tapatalk
  21. BrettC
    BrettC Formula 3
    Aug 13, 2012
    2,113
    Calif
    Brett
    Nope, cut out and rewelded the stock headers. no more precat issues.
  22. sparetireless
    sparetireless Formula 3
    Nov 2, 2003
    1,587
    if add a bung plug to the back of the main cats to screw the 02 sensor into,
    its a $2 part but you need have a muffler shop or welder weld it in, set up just like a '99
    works fine
    Skidkid likes this.
  23. GCalo
    GCalo F1 Veteran
    Sep 15, 2004
    7,645
    Northern California
    Greg Calo
    For you folks who live outside California the sky is the limit on headers and pre-cats.
    The Dragon Lady is at every smog station here, and they check for pre-cats.
    Have not been to a smog station that did not know to look!
    So it must be in the station's smog software notes to look for the pre-cats M/Y 2000+
  24. EhellGuapo
    EhellGuapo Karting
    Sep 25, 2016
    146
    Search Mullins Auto Parts eBay and they still have a few interesting bits up. Easy to work with when you finally arrive at the guy who is the buyer of the parts.
  25. 550nitis
    550nitis Formula Junior
    759
    Houston
    Reviving this thread. I'm installing 99 headers into my 03 to solve the pre-cat issue. Interested to hear the difference.
