1991 Testarossa US Spec. | FerrariChat
Discussion in 'Boxers/TR/M' started by maghriha, Feb 19, 2020.
  1. maghriha
    maghriha Rookie
    Aug 18, 2006
    26
    Saudi Arabia
    Hosam maghribi
    Hi
    Can any one help to provide the Vacuum system drawing ? As i have some vacuum hoses missing and i want to connect them properly.
  2. Shamile
    Shamile F1 Veteran
    Dec 31, 2002
    6,712
    Lakeland FL
    Shamile
    I then if you open the rear engine cover, it shows the vacuum lines and where they go on a label.
    Shamile
    Freeze....Miami Vice!
    Sent from my SM-G950U using Tapatalk
    Rifledriver likes this.
  3. Shamile
    Shamile F1 Veteran
    Dec 31, 2002
    6,712
    Lakeland FL
    Shamile
  4. Shamile
    Shamile F1 Veteran
    Dec 31, 2002
    6,712
    Lakeland FL
    Shamile
    ....forgot to mention, mine is also a 91 US spec.
    Shamile
  5. vincenzo
    vincenzo F1 Rookie
    Nov 2, 2003
    3,373
  6. turbo-joe
    turbo-joe F1 Veteran
    Apr 6, 2008
    9,510
    romano schwabel
    the vacuum lines are not all the same for every country
  7. vincenzo
    vincenzo F1 Rookie
    Nov 2, 2003
    3,373
  8. Veedub00
    Veedub00 F1 Veteran
    Jun 30, 2006
    5,065
    Troy, Michigan
    James
    how does the air injection work in the second drawing? It's not forced air like the US models but just sucks from the atmosphere?
  9. Steve Magnusson
    26,726
    Yes, that's the air pumpless "pulse" air injection where the exhaust pulse draws in atmospheric air to the exhaust stream -- it was used on the circa 87~88 CH (Swiss) version TR. All US TR have the air pump style air injection system shown in Post #5.
    Shamile likes this.
  10. maghriha
    maghriha Rookie
    Aug 18, 2006
    26
    Saudi Arabia
    Hosam maghribi
    Hi
    Special thanks goes to you Gent's
    By the way, i cancelled the Catalyst system.I removed the whole exhaust US system and installed Koeing mufflers.And also cancelled the air injection with all its accessorizes.
    I found both MAP sensors.not connected with vacuum hoses.That is why i am looking for proper drawing.I Think Shamile send that vacuum sticker that attached to engine hood.
    Will come back to you .
    Shamile likes this.
