1985 400i 5-speed Auction | FerrariChat
Discussion in '365 GT4 2+2/400/412' started by Schumi, Feb 5, 2020.
  1. Schumi
    Schumi Formula Junior
    Jun 5, 2002
    865
    Missouri
    Daren
  2. pilotoCS
    pilotoCS F1 World Champ
    13,378
    The Capital of The United States of America
    Willis
  3. markcF355
    markcF355 F1 Rookie
    Jun 6, 2004
    3,493
    Schmeckelstan
    Mark
    Some is wrong with hydraulics. Probably the accumulators.
  4. SouthJersey400i
    SouthJersey400i Formula 3
    Mar 14, 2007
    1,679
    Romulus, NY (Finger Lakes)
    Ken Battle
    Mine is like that until motor is running; it comes up in a short time.
    Ken
    wrxmike likes this.
  5. markcF355
    markcF355 F1 Rookie
    Jun 6, 2004
    3,493
    Schmeckelstan
    Mark
    Ken, does it bang hard when you go over a bump?
  6. ONSilver
    ONSilver Karting
    May 26, 2008
    184
    Oakville, Ontario
    My 412 also goes lower at the rear when parked, but as soon as the engine is started, returns to normal ride height and stays there. Never concerned me. No bangs or noises, rides smoothly. Am having the rear shocks rebuilt and serviced as well as the central control arm for the hydraulics, as there are slight leaks from the shocks, so should be even better when completed. Wanted to keep the all-original component instead of going to coil overs.
    Sent from my BBB100-1 using FerrariChat.com mobile app
  7. SouthJersey400i
    Mar 14, 2007
    1,679
    Ken Battle
    No banging on bumps.
  8. steved033
    steved033 F1 World Champ
    Apr 12, 2017
    10,042
    Atlanta, GA
    Steve D.
    all those cars are BHCC cars.
    sjd
  9. dstacy
    dstacy F1 World Champ
    11,998
    GMT -5 & GMT +1
    Dave
    if “yes” then what?
  10. SouthJersey400i
    Mar 14, 2007
    1,679
    Ken Battle
    No banging on bumps so no action needed for me.
    Ken
  11. christc
    christc Formula Junior
    BANNED Silver Subscribed
    Mar 3, 2013
    470
    Germany
    If they sink that low and raise when started accumulators are gone. Membran inside is faulty and/ or gas in sphere has escaped.
    BR
    Christopher
  12. christc
    Mar 3, 2013
    470
    Germany
    ? Would interest me too
  13. SouthJersey400i
    Mar 14, 2007
    1,679
    Ken Battle
    Christopher
    I am not sure I agree with you. I believe there is a check valve in the level adjusting circuit and it can leak back to the reservoir over several hours or a more than a day which will lower the level. If the accumulators are gone (broken bladder) and the ride comes up to level, that means the accumulators are full of LIQUID (no gas) and ride would be very harsh at the rear. My ride is not hash.
    Ken
  14. dstacy
    11,998
    GMT -5 & GMT +1
    Dave
    Absolutely correct Ken.
  15. christc
    Mar 3, 2013
    470
    Germany
    #15 christc, Feb 12, 2020
    Hi Ken,
    mine sank to the ground with engine of after a few hours. I changed the accumulators. It now stays at the same height with the engine off and does not sink as in the pictures shown. Self levelling system works perfect now.
    Christopher
  16. dstacy
    11,998
    GMT -5 & GMT +1
    Dave
    Christopher, would you mind telling me which accumulators did you use and where did you get them?
  17. christc
    Mar 3, 2013
    470
    Germany
    ...and just to clarify I meant the prefiled gas inside the accumulator, not the liquid of the system.
    Cheers
    Christopher
  18. christc
    Mar 3, 2013
    470
    Germany
    Hi Dave,
    I was told that there is a ‘specialist’ exactly replicating them in Germany. I ordered two to find out that they are the Mercedes accumulators others used but for a higher price. Not satisfying and I had to rework them to be satisfied. I would recommend to order the Mercedes units. With two adapters for the hose connection and a simple bracket they can be easily adapted.
    Christopher
  19. christc
    Mar 3, 2013
    470
    Germany
  20. raemin
    raemin Formula 3
    Jan 16, 2007
    2,335
    Lyon (FR)
    R. Emin
    On Citroën cars, these could be as low as 25€! There are plenty of these available with quite a few after-market suppliers :
    https://www.mister-auto.com/spheres-accumulateur-de-suspension/mercedes-benz/
    (This online supplier belongs to PSA group i.e owner of the patents related to these types of suspensions, so they have plenty of these, do not ship overseas though)
  21. christc
    Mar 3, 2013
    470
    Germany
    Yes. That is a reasonable price and with little effort you have a conversion:
    - remove brackets from mercedes unit
    - take the brackets from your old units and weld it to new taking care not to heat the membran bowl to much
    - close the side outlets with two mandrel screws using thread sealant
    - buy two plugs for main connection with fitting thread and drill and tap it to except hydraulic lines
    BR
    Christopher
  22. SouthJersey400i
    Mar 14, 2007
    1,679
    Ken Battle
    Christopher
    I accept the cylinders may very well solve most similar problems, even mine! I have saved your part posting for a future R&R job if I am convinced I need a solution to only a small annoyance now.
    Having owned an E55 AMG track car, I got real familiar with Pelican parts. They offer three choices; here is link to the middle priced one (price each not two):
    https://www.pelicanparts.com/More_Info/1403280515M36.htm?pn=140-328-05-15-M36&bt=Y&fs=0&SVSVSI=W210
    Pelican has the OEM part for about $30 more.
    The Parts Geek offering is the low priced one but still $100+ from Pelican.
    The Euro price for two makes cheaper if shipping doesn't kill it. I like Pelican for parts and service.
    Ken
    christc likes this.
  23. raemin
    raemin Formula 3
    Jan 16, 2007
    2,335
    Lyon (FR)
    R. Emin
    I'd rather buy the type with the side bracket. That's less soldering trouble, that compensate for the additional shipping costs from Europe.
  24. christc
    Mar 3, 2013
    470
    Germany
    Agree. Much better. There are different types of mountings worth comparing.
