1975 308 GT4 Engine/Trans Rebuild | FerrariChat
Discussion in '308/328' started by jlonmark, Jul 21, 2021.
  1. jlonmark
    jlonmark F1 Rookie
    Mar 29, 2005
    3,175
    Beverly Hills, CA
    Jay
    So after all this time I've decided to pull the engine and trans from my 75 gt4. Total breakdown, machined the heads, new lines, new synchros in the trans. Anything else I should check or redo at the current time?
    Thanks!
    marklintott and NoGoSlow like this.
  2. miketuason
    miketuason F1 World Champ
    Feb 24, 2006
    15,541
    Cerritos, CA.
    How about a new set of high compression pistons?
  3. absostone
    absostone F1 Veteran
    9,282
    SS valves.
    NoGoSlow likes this.
  4. jlonmark
    jlonmark F1 Rookie
    Mar 29, 2005
    3,175
    Beverly Hills, CA
    Jay
    Keep em coming guys! I like all of the ideas thus far
  5. smg2
    smg2 F1 World Champ
    Sponsor
    Apr 1, 2004
    15,523
    Dumpster Fire #31
    SMG
    Mileage, condition, goals?
  6. kiwiokie
    kiwiokie Formula 3
    Aug 19, 2013
    1,464
    Tulsa, OK
    John McDermott
    Upgrade main +ve cable from battery to starter. Replace heater and brake vacuum hoses that run through drivers side rocker panel. Clean all electrical connectors. Rebuild starter (or go lightweight) and alternator. Thoroughly clean engine bay and address any corrosion. Clean and rebush shifter and new seals.
  7. absostone
    9,282
    I replaced the starter to alt cable with some really cool looking silver copper or something from a custom shop.
  8. marklintott
    marklintott Formula Junior
    579
    Taipei Taiwan / Somerset UK
    Mark Lintott
    Lightweight hi torque starter
    Repair/replace headers + ceramic coating
    Switch out ignition system to Pertronix or Black stallion or similar
    Change all your valves to solid SS - lose the sodium filled originals
    JE pistons from California
    Clean up the engine bay of course
    Possibly change the radiator to a modern aluminium item
    Shift shaft seals
    Service/rebuild your carbs
    etc etc.....good luck!
  9. dave80gtsi
    dave80gtsi Formula 3
    1,816
    Ohio
    Dave Meredith
    Since you will likely be using new pistons anyway, see if you can find a used 328 crankshaft. The "Poor Man's Stroker Kit"
  10. jlonmark
    jlonmark F1 Rookie
    Mar 29, 2005
    3,175
    Beverly Hills, CA
    Jay
    An old timer mechanic friend said you can put 365 cylinders on and make the car 4.0 liter! That coupled with the 328 crank would really be something. The car is a driver that goes out on the Ferrari club runs, first sat of every month. We go hard for 6-9 hours and cover 300-500 miles. So more power and reliability are in mind. This is the first time the motor has been opened. I really appreciate the help!
  11. steven_ew
    steven_ew Karting
    Apr 3, 2009
    107
    I would also replace the long aluminium water pipes to/from the radiator with stainless steel. Can only be done with engine out or jacked up and a sitting duck for corrosion
  12. miked
    miked Formula Junior
    Feb 7, 2001
    823
    Cincinnati, Ohio
    The 308 and the 365 share the same bore and stroke (81mm x 71mm), there would be no change in displacement. Using a 328 crankshaft (73.6 mm stroke) does increase displacement but not by much. Some people on this forum have used a 348 crankshaft (75mm) to increase displacement. Maybe your mechanic friend was thinking of replacing the V8 engine with a 330 (4.0 liter) V12 engine, it has been done.
  13. smg2
    smg2 F1 World Champ
    Sponsor
    Apr 1, 2004
    15,523
    Dumpster Fire #31
    SMG
    Crankshafts all the way up to the 360 will fit. Requires changes to connecting rod lengths and/or piston gudgeon pin to deck distance.
    I've built everything from 3.5L to 4L 308's. It's just a matter of how many wheelbarrows of cash one wants to spend.
    eskamobob1 likes this.
  14. derekw
    derekw Formula 3
    1,520
    London, UK
    Derek W
    The chances are your piston/wall clearances are beyond the limit. If so, hone the liners and order higher compression pistons to suit. If you can find a 348-360 crank and want to spend the extra $, then the pistons can be made to suit the longer stroke. I think the early GT4 cams are ok but for a little more power you could get higher lift CAT cams for $1500. You will need to tune the carbs for the new internals and change the advance curve to suit. Minimal gains from porting the head but make sure the machine shop didn’t fit new guides and cut the now eccentric seats to suit (sinking the valves into the seats.) It’s a common problem with these engines. Just check and fix if the inlet manifolds don’t match the ports (they were very close on my two engines.)
    As others have said, get solid stainless exhaust valves. I have some 21-4N valves left at £10 each but in the US several places sell them. Fit viton or Teflon stem seals as the nitrile seals don’t last as long on the hot exhaust valves. You can lighten the valve train with titanium valve spring caps (£160/set).
    Drill the exhaust cam seal drain hole and blind shifter vent hole in the intermediate plate (both discussed in this forum.)
  15. Pizzaman Chris
    Pizzaman Chris F1 Rookie
    Mar 13, 2005
    3,919
    New Hampshire
    Pizzaman Chris
    Wise quote from a wise man.
  16. eskamobob1
    eskamobob1 Karting
    May 9, 2020
    146
    SoCal
    Seconded. We need info. Without you giving a budget ima recomend a 3.6 qv conversion. They should start at like 40k if you dont do your own head work ;)
  17. jlonmark
    jlonmark F1 Rookie
    Mar 29, 2005
    3,175
    Beverly Hills, CA
    Jay
    Well to be "Feng shui," less is more. Our initial budget was $20,000 and I hope to not go over much. Just figure now is the time to do it. A stroker motor or turbo setup (like the 288 gto), would be awesome! But unrealistic
