For Sale - 1960 M-B 190SL restored by Mark Passarelli | FerrariChat
For Sale 1960 M-B 190SL restored by Mark Passarelli
Discussion in 'Other Cars' started by JF308, Aug 23, 2018.
  1. JF308
    JF308 Formula 3
    Jan 17, 2007
    1,263
    Boulder, CO
    John Feeney
    1960 Mercedes-Benz 190 SL
    s/n 121 042 10 016650
    matching number engine and drivetrain. (data card available).
    24 month concours rotisserie restoration by marque expert Mark Passarelli. Fresh restoration. 500 test miles since. (Mark is known for his 300SL restorations and I was lucky enough to be his first Colorado customer since he moved his shop back to his hometown to be closer to family in Salida, CO).
    DB172 Anthracite gray metallic over burgundy red interior (641) with matching custom 3 piece luggage. Books, tools, jack and full spare. We matched the absolutely stunning color combination of the last 300SL Gullwing that Mark restored.
    https://photos.app.goo.gl/5mu2F8W0cuh2zpXd2
    Additional detailed photos of every step of the restoration are archived and will go with the sale.
    Serious inquiries only. Mark is available to answer any questions regarding the restoration work.
    Asking $185,000. Vehicle is located in Colorado.
    Also included (added at the end of the restoration):
    > Bosch gear reduction starter
    > K&N Air filter conversion (original steel wool type is not serviceable)
    > 190SL Group Alternator (from generator/voltage regulator) conversion.
    > Bruce Adams “electric fuel pump” switch tied to choke lever to prime mechanical pump and load carbs.
    Components used in the mechanical and cosmetic restoration include the following (not exhaustive list, but reasonably complete).
    • Subframe and suspension
    • Front and rear subframe removed, disassembled, blasted and powder coated
      • New bushings
      • Proper mounts and connectors replaced
      • New shocks and springs
      • New tie rods, spring plates, etc
      • Underside prepared and painted in appropriate M-B color
    • Engine
      • Professionally rebuilt by Mark Passarelli
      • New pistons and rings
      • New bearings
      • New timing chains and rails
      • New valves and lifters
      • Original Solex PH44 carb’s rebuilt
      • Linkages replaced
      • Oil pump rebuilt
      • Water pump, thermostat rebuilt and new gasket
      • Radiator refurbished
      • Fuel pump rebuilt
      • Alternator rebuilt
      • Complete new wiring harness
      • New spark plugs
      • New stainless fuel lines and new fuel hoses
      • Manifolds coated
      • New stainless steel exhaust
      • All hardlines re-plated to specification
      • Proper fasteners and connectors
      • Distributor rebuilt
      • New Vintage Battery
      • New Airbox
      • Fuel tank restored and painted
      • Fabricated exhaust coupling
      • New Exhaust
      • Engine validated to spec
    • Transmission and driveline
      • Transmission dismantled and rebuilt
      • New gaskets
      • New flex disc
      • Starter rebuilt
      • New driveshaft u-joints
      • Validated to spec
    • Differential
      • Dismantled and rebuilt rear end
      • Bushings and gaskets
    • Tires, Wheels, hubs, brakes
      • Hubs dismantled and rebuilt
      • Master cylinder, wheel cylinders rebuilt
      • Rebuilt brake booster
      • Brake pads replaced
      • Brake hardline replaced
      • Brake soft rubber lines replaced
      • Wheels blasted and repainted
      • New Coker Classic wide white wall tires
      • New Coker Classic wide white wall full size spare
      • Hubcaps repainted to match body
    • Body and underbody
      • Body completely blasted to remove paint, primer and highlight body condition.
      • Weak points identified and replaced with new metal. Top notch metalwork.
      • Proper welds to specification (no overlap welds). Factory spot welds.
        • Lower rear quarters replaced (restorer preference).
        • Front passenger headlight bucket/surround repaired
        • Floor crossmember repair fabricated
        • Passenger floor small patch repaired
      • Underbody sealed and primed
      • Underbody painted in proper MB “beige” to specification
      • Wheel wells painted to proper MB specification including feathering in of underbody to wheel well
      • No tape lines. Factory overspray pattern replicated.
      • Battery box floor replaced to specification.
      • Engine bay prepped and painted to spec.
      • Trunk edge metal repaired and replaced with new metal
      • All gaps to MB specification. Hood corner required some modification.
      • Exterior sealed, primed and painted in DB641 Anthracite Gray Metallic (matching 300SL Gullwing previously done by Mark)
      • Wheels and hubcaps painted to match
      • Final cut, buff and final detailing
      • All new rubber seals and gaskets; doors, windows and trunk.
      • New matching wind lace fabricated
      • Exterior lights and marker lights to proper US specification
    • Interior and Gauges
      • All Gauges, clock and dash components removed.
      • Dash painted in proper matching DB172 Anthracite gray metallic
      • Restored Steering wheel and chrome horn ring and wheel center star
      • New OEM turn signal stalk
      • All gauges removed and sent to Palo Alto Speedometer for restoration
      • Proper 190SL “wind up” glovebox clock restored
      • Vintage Becker radio (updated with USB and iPod) while maintaining classic look
      • OEM rubber front floor and console mat
      • OEM rubber trunk mat
      • German Squareweave Carpeting throughout. Including front floors under rubber mat (additional to OEM spec for consistency and appearance).
      • New Windshield Glass
      • Windows adjusted to Soft Top
      • New switches as needed.
      • New DB641 Burgundy red leather:
        • Dash recovered
        • Binnacle recovered
        • Door Panels
        • Arm rests
        • Visors
        • Convertible top boot cover
      • Original leather seats were re-padded with correct horsehair and foam padding to specification
      • New leather seating in matching DB641
    • Custom Luggage
      • Custom 3-piece Matching Trunk Luggage set: DB641 over complementing gray, red, white pattern interior per Customer request.
    • Convertible top
      • Restored soft top bows and frame. Fabricated proper strapping.
      • New German canvas top in OEM black canvas
      • New Chrome accent strip
    • Interior and exterior chrome, fasteners
      • All chrome either replaced with new or re-chromed.
      • Many pieces reChromed by Artistic (top notch supplier to Jay Leno and Chip Foose).
      • Fasteners re-plated to MB specification (zinc, cadmium, black oxide ) as needed.
      • Proper MB specification radio antennae (red tip)
      • Rechromed original bumpers and bumper guards
      • Rechromed front grille
      • Rechromed stone guards and trim
      • OEM Bosch horns restored
    Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
  2. Texas Forever
    Texas Forever Eight Time F1 World Champ
    BANNED Rossa Subscribed
    Apr 28, 2003
    85,600
    Texas!
    Mark does great work.
  3. Stentboy
    Stentboy F1 Rookie
    2,810
    Texas
    Ron
    Very nice!
  4. JF308
    JF308 Formula 3
    Jan 17, 2007
    1,263
    Boulder, CO
    John Feeney
    dmundy and one4torque like this.
  5. BigTex
    79,368
    Houston, Texas
    Bubba
    Stunning!!
    GLWS!
  6. Mmckee
    Mmckee Formula 3
    BANNED Silver Subscribed
    Sep 30, 2016
    2,339
    Alta Loma, Ca
    Beautiful
  7. full_garage
    full_garage Formula 3
    Feb 15, 2010
    2,241
    Sarasota Florida
    Jay
    I can vouch for John- Absolutely first class seller!
    If I did not have 4 restoration projects going right now this one would be in my garage already!
  8. jimpo1
    jimpo1 Two Time F1 World Champ
    Jul 30, 2001
    24,890
    Dallas, TX
    Jim E
    I don't think PASS hangs out here much any more, too bad.
    That car is gorgeous!
  9. ag512bbi
    ag512bbi F1 Veteran
    Nov 8, 2003
    7,692
    So. Cal
    Armen
    What a perfect color combo
    carguy246 likes this.
  10. Jdubbya
    Jdubbya The $10 Trillion Man
    42,994
    PNW
    Stunning car, so graceful and elegant.
  11. dmundy
    dmundy Formula 3
    Sep 11, 2010
    1,302
    Unspecified
    Arthur Dent
    These drive pretty nicely from what I recall. Beautiful car.
  12. slm
    slm F1 Rookie
    4,100
    Near Lambeau field
    Steve M
    Fantastic car, John. Congrats to you and Pass for an amazing restoration. GLWTS.
  13. JF308
    JF308 Formula 3
    Jan 17, 2007
    1,263
    Boulder, CO
    John Feeney
    SOLD. Thanks to everyone for the positive comments and interest.
