Removed resonator, now need Tubi | FerrariChat
Discussion in '456/550/575' started by JimEakin, Sep 16, 2017.
  1. JimEakin
    JimEakin Formula Junior
    Jun 13, 2015
    988
    Mountain Living
    Jim
    #1 JimEakin, Sep 16, 2017
    I just went down to the local muffler shop and swapped out the resonator on my 550 with custom made straight pipes, about $330. There is now more sound, but I can also understand why the resonator was put in. The added sound is only coming up into the cabin in the middle.
    Does anyone have a Tubi exhaust for sale? This should add sound to the rear.
    Regards.
  2. vee12
    vee12 Formula Junior
    333
    Atlanta
    Les
    Make sure you get the 575 stamped Tubis...the 550 Tubis will be WAAAY too load and have terrible resonance at cruising speeds. Ask me how I know.
  3. contadino
    contadino Karting
    Oct 18, 2016
    82
    ITALY
    Hello,
    in order to delete the resonance at cruising speeds is necessary to do another way....
    good luck
  4. JimEakin
    Jun 13, 2015
    988
    Mountain Living
    Jim
    Hi contadino,
    What is your recommendation? Or is there a thread for this already?
    Note that I don't find there is too much noise, especially at cruising.
  5. contadino
    contadino Karting
    Oct 18, 2016
    82
    ITALY
    Hi Jim,
    sorry i would not have understood badly.... but in your before post you told "the 550 Tubis will be too load and have terrible resonance at cruising speeds", i agree, i have a friend who have big experience in those exhausts and explaiened me in past some things ....
    When you write "that I don't find there is too much noise, especially at cruising", whht you intend exaclty? not too much noise inside or outside the car?
    In general tubi or capristo make resonation inside, that is amplified by the straight pipes ....
    greetings
  6. GTS Bruce
    GTS Bruce Pisses in your Cheerios
    Oct 10, 2012
    793
    Orchard Park NY
    Bruce Roche
    You might try rerouting the vacuum lines first to keep the mufflers fully open all the time. That helps but didn;t do it for me so I got rid of the mufflers too and went with tubi straight pipes.
  7. luca's308gts
    luca's308gts Karting
    Dec 16, 2016
    81
    Minneapolis
    Bill
    I recently put a Tubi on my 550 which had the resonator removed and also straight pipes installed.
    With the Tubi it is loud, no question, however at about 2,300 - 2,800 RPMs it's actually very mellow. After that the higher the revs the louder it gets.
    marce likes this.
  8. tazandjan
    38,085
    Fabio's H pipe HGTC mufflers eliminate the resonance and have those beautiful HGTC tailpipes. The H cross pieces act like balance tubes.
  9. toggie
    toggie F1 World Champ
    Nov 30, 2003
    19,036
    Virginia
    Toggie (Ron)
    I have the Braden dual straight pipes in the middle and 575 Tubi tailpipes (street version, not the louder race version 575 Tubis).
    I really like the sound and set-up of the pipes this way.
    At highway cruising speeds (60 - 85 mph) the pipes quiet down and have minimal droning effect.
    The sound level is very comfortable for long trips. Not Lexus quiet, but comfortable.
    At slower speeds it has the wonderful "burble and pop" sounds that only a Ferrari V12 can make.
    The pipes sound great under acceleration, especially as the RPMs rise.
    And, during down-shifting, the pipes make wonderful rumbling sounds.
    I still have the stock mid-pipe and stock tailpipes.
    I'll save them in my garage for the next owner.
    Here are pictures of the underside of the car.
  10. 308 GTB
    308 GTB F1 World Champ
    11,193
    New Jersey
    Barry Wolinsky
    I have the same setup on my 550 but with 321 SS straight pipes I had made up for me at Classic Coach nine years ago before Bradan made them available. Same experience as yours but I'll add that it makes a great sound when I get on the gas pedal.
  11. oss117
    oss117 F1 Rookie
    Jan 26, 2006
    4,185
    Plantation, Florida
    Alfredo
    I have a pair of Stebros made for the 550 / 575 that I have used on my 456 for 1 week, if you are interested
  12. Andrew D.
    Andrew D. F1 Rookie
    Jul 6, 2008
    3,979
    Goodwood Ontario
    Andrew D.
    I have a 456 with Tubis and Branden resonator delete. Cant beat that sound. If you want quiet on the hyway,just use 6th gear.
  13. JimEakin
    Jun 13, 2015
    988
    Mountain Living
    Jim
    Hi oss,
    Yes, I am interested. Tried to send PM, do I open a conversation in this new FChat format?
  14. JimEakin
    Jun 13, 2015
    988
    Mountain Living
    Jim
    Anyone else have experience with Stebro for 550 or 575M?
  15. Renman57
    Renman57 Formula Junior
    428
    North Carolina
    Reynolds
    I purchased my 2000 550 3 1/2 years ago and was very disappointed with the factory exhaust note. I have now been running the Braden straight pipes and Tubi's for three years and have been thrilled with the sound. It really sounds like a Ferrari now.I will not go back to the stock set up as long as I have the car which will most likely be many years!
  16. JimEakin
    Jun 13, 2015
    988
    Mountain Living
    Jim
    Thanks, Renman. Do you have the Tubis for 550 or 575M?
  17. tres55
    tres55 F1 Rookie
    3,496
    Canada
    F456M, NE550 and greg246 like this.
  18. cls
    cls Formula 3
    Jun 12, 2007
    1,663
    Los Angeles/Montreal
    Chris
    Once you see Fabio's work, everything else looks substandard. Fabio also takes the time to explain, in detail, what makes his products the best out there.
  19. tazandjan
    38,085
    Fabio's system is by far the best out there and the HGTC tailpipes look great. The H center pipe eliminates just about all resonance with its balance tube design without losing hp like a normal X-pipe.
  20. Canuck550
    Canuck550 Formula Junior
    Sep 8, 2015
    462
    Incognito
    RJA
    The setup I use ....
    Best sound I have heard on the 550...F1 sound valved if you need to close them for a quiet ride...with y pipes, in titanium
    http://kreissieg.ocnk.net/product/165
  21. 308 GTB
    11,193
    New Jersey
    Barry Wolinsky
    You also did away with these two restrictions...
  22. F456M
    F456M F1 Rookie
    Jan 8, 2010
    3,665
    Oslo
    Erik
  23. JimEakin
    Jun 13, 2015
    988
    Mountain Living
    Jim
    Hey tres,
    I've heard this setup in another post. Wow, it's awesome. But probably way out of my price range.
    Will this setup pass smog in CA?
  24. JimEakin
    Jun 13, 2015
    988
    Mountain Living
    Jim
    Found the link to Fabio's sound track:
    tres55 and marce like this.
  25. NE550
    NE550 Formula Junior
    Mar 23, 2017
    412
    Omaha, NE
    Dave
    I recently purchased Fabio's double-H pipe to replace my OE resonator. It is first-rate and Fabio is first-rate to do business with. Great guy!
