No Headlights, interior, sidemarkers or plate lights work | FerrariChat
Discussion in 'Mondial' started by dfranzen, Jun 13, 2015.
  1. dfranzen
    dfranzen Formula 3
    Aug 31, 2013
    1,577
    Ponte Vedra Beach , FL
    Don Franzen
    So got in car this morning and turn on lights nothing!
    position 1 turn to "off" position hear click
    position 2 I hear and see the motor knobs turning when turning to "off" position
    no lights whatsoever
    tested all fuses that say light on the clear cover and all fuses check good
    where do I find the mondial 3.2 schematic ?
    there are several relays that seem to control the lights is there any specific one to check
  2. hank sound
    hank sound F1 Veteran
    Jan 31, 2004
    5,953
    Burbank, CA
    Hank Garfield
    We need to call in "soucorp" !!!
    Cheers,
    Hank
  3. dfranzen
    dfranzen Formula 3
    Aug 31, 2013
    1,577
    Don Franzen
    +1
  4. dfranzen
    dfranzen Formula 3
    Aug 31, 2013
    1,577
    Don Franzen
    #4 dfranzen, Jun 13, 2015
    changed out relay O with new one still no headlights, interior, side marker, tail, license
    note: parking switch works front and rear lights
    blinkers work
    brake works
    passing light/ fog works all positions from headlight switch
    turning switch on seems to do nothing then off turns headlight motor one click
    Im puzzled?
  5. davem
    davem F1 Veteran
    8,246
    Stepford, Connecticut
    dave m
    Somewhat common issue. Bad ground. Valenzo had started thread recently about this.
  6. soucorp
    soucorp F1 Rookie
    Sep 20, 2011
    4,814
    Old Dominion
    #6 soucorp, Jun 13, 2015
  7. dfranzen
    dfranzen Formula 3
    Aug 31, 2013
    1,577
    Don Franzen
    #7 dfranzen, Jun 13, 2015
    Stalk End Switch had ground open
    So even though I did not have the schematic I went ahead and checked the stalk switch
    for future reference here's what I did :
    gently pry off the retaining ring (photo1)
    there is a ball bearing that fits in a groove of the cover don't lose ball!
    gently slide off the stalk cover and assess (photo2) all looked well
    notice the future crack in the plastic that will need future attention!
    pushed on ground solder and it lifted (photo 3)
    placed a small sheet of insulator (sandpaper 1000grit between the contacts)
    cleaned with light sanding to create rough surface to solder then re-soldered
    took out insulator and tested
    then gently slid cover back on noting position of bearing and inner groove
    pushed lock ring back on
    fyi as an electronic engineer this is the worst type connection very unreliable to solder directly unto copper, should be nickleplated then tinned then solder or just welded/brazed
  8. soucorp
    soucorp F1 Rookie
    Sep 20, 2011
    4,814
    Old Dominion
    Top work Don ! Well done.
    -Mike
  9. dfranzen
    dfranzen Formula 3
    Aug 31, 2013
    1,577
    Don Franzen
    thanks Mike!
    FEELING ACCOMPLISHED!
  10. 123howie
    123howie F1 World Champ
    Jul 3, 2014
    16,017
    El Segundo CA
    Howie
    We can all breathe again. Glad to hear all is fixed.
  11. Frevawan
    Frevawan Rookie
    Feb 12, 2006
    12
    Bruges, Belgium
    Does there exist a list or schematic showing the actual location of all the ground points in the car? Not talking about the electric shematics. I have currently the same problem and would like to check all grounds and would like to know where they all are so I won't miss any.
    Thx guys!
    Mondial QV '83
  12. theunissenguido
    theunissenguido Formula 3
    Jan 21, 2004
    2,372
    Argent/Brasil
    Guido
    Post nr 3 in this thread give you an idea...
    http://www.ferrarichat.com/forum/threads/sticky-mondial-8-qv-3-2-t-repair-thread.209843/
    Guido
    paulchua likes this.
  13. Steve Magnusson
    25,149
    Plus soldered to an area of the Copper piece that flexes = way bad. At a minimum, the Copper piece should've been extended beyond the rivet and the wire soldered there (in a non-flexing area).
