Immobilizer defeat? | FerrariChat
Immobilizer defeat?
Discussion in 'Technical Q&A' started by Williamjweiner, Sep 15, 2017.
  1. Williamjweiner
    Jun 6, 2017
    23
    Los gatos
    IMO the factory immobilizer in my 575m is a pain and can result with inop that could spiral into a flat bed
    Ride to the doctor. Is there a procedure to defeat the system and will the auto door locks be lost in the process?
  2. Eric C
    Eric C F1 Veteran
    9,106
    St. Louis, MO
    Eric
    The immobilizer on my F430 took a dump. I just had to ship mine 5 hours away to the Ferrari dealer because of it. I wish there was a way to disable them. I don't want it. That's what insurance is for.
  3. Redneck Slim
    Redneck Slim Formula 3
    1,451
    Palo Alto,CA,USA
    Walt Kimball
    Removing the immobilizer has been discussed on this forum and can be done. Try EVOMSiT and Vivid Racing. Hopefully others will chime in.
  4. Williamjweiner
    Jun 6, 2017
    23
    Los gatos
    Will look for them
  5. Ingenere
    Ingenere F1 Veteran
    Dec 11, 2001
    6,344
    On the Limit
    Dino
    I have been fighting immobilizer issues and have not found a software way to bypass it. There are a couple of companies that help with immobilizer problems. Immofixer.com and ECU doctors may be able to point you in the right direction.
    The immobilizer is THE worst feature in my car. If I could make it vanish, I would.
  6. Skippr1999
    Skippr1999 F1 Rookie
    4,216
    ECU Dr. has the bypass for 355. I'd give them a call.
  7. radman
    radman Rookie
    Sep 7, 2016
    4
    uk
    Chris
    I have found away round this on my 360 and you dont have to buy anything.
  8. vrsurgeon
    vrsurgeon F1 World Champ
    15,918
    Charleston, SC
    Curt
    And you're not telling us what it is because...?
  9. mello
    mello F1 Veteran
    5,043
    CA Bay Area
    Steve
    ... I am a troll.
  10. radman
    radman Rookie
    Sep 7, 2016
    4
    uk
    Chris
    Like many others I purchased my 360 with only one remote and no pin. Like Ingeneres post I think the immobilizer is THE worst feature in my car so here is a way to get around it. My battery in the alarm sounder was shot so I removed the unit you will see there are other postings on how to do that. Next push and hold your remote button for 4 seconds this puts the alarm in panic mode and having no sounder nothing happens.
    Well you will now find the immobilizer is defeated and you will be able to start the car without the remote, works every time and stays in that mode even if you ditch the battery to lay your car up over the winter.
    Mine is a UK car and I have tried this on another UK 360 with same results. With a US spec car there is another problem to get over, when in panic mode the indicator lights flash to get over this I believe would be a disconnection of a cable wich I would be happy to look at if anyone was interested. The fob still opens doors ok and if you want to put back in immobilizer mode just hold the remote down for the 4 seconds again and the car is immobilezed. If you wish you can supplement the alarm with a third party device, I fiited a tracker with the facility that I could turn off the fuel pump remotely from my iphone.
    I would be interested in any feedback
  11. finnerty
    finnerty F1 World Champ
    May 18, 2004
    10,406
    It can be done, but it is rather complex.
    Most newer cars have the immobilizer function tied to the entire CDL (and alarm) system. So in order to bypass it, you will also lose some CDL functionality --- which most folks don't want to do.
  12. eulk328
    eulk328 F1 Rookie
    Feb 18, 2005
    2,800
    F683
    "With a US spec car there is another problem to get over, when in panic mode the indicator lights flash to get over this I believe would be a disconnection of a cable wich I would be happy to look at if anyone was interested."
    I'm interested to know how to stop the indicator lights flashing on a U.S. spec. car if you are able to determine that!
  13. Ingenere
    Ingenere F1 Veteran
    Dec 11, 2001
    6,344
    On the Limit
    Dino
    Very interesting! The next time it acts up, I will have to try this.
  14. DGS
    DGS Six Time F1 World Champ
    60,681
    MidTN
    DGS
    Should we change the thread title to "How to steal a Ferrari"? :p
    (Unsubscribed section.)
  15. hessank
    hessank Formula 3
    1,748
    Canada, Florida
    Fred
    Me too. I'd like to know.
  16. Michael Foreman
    Jul 11, 2017
    17
    Northeast PA
    Michael Foreman
    I've seen the ECU doctor bypass installed with success on a few cars
  17. Ingenere
    Ingenere F1 Veteran
    Dec 11, 2001
    6,344
    On the Limit
    Dino
    I tried this on my car and no luck. :(
  18. Eric C
    Eric C F1 Veteran
    9,106
    St. Louis, MO
    Eric
    Wish that worked on my F430. I just paid $3,000 to have my immobilizer fixed.
  19. radman
    radman Rookie
    Sep 7, 2016
    4
    uk
    Chris
    Shame it did not work. As I said it works on UK spec car when you put it into panic mode and I tried it on another 360. I guess you tried it with the sounder still connected which does not make any difference only upsets the neighbours while you test it.
    I have spent many hours looking and drawing out a wiring schematic of the alarm connections to see how the indicators could be disconnected from the alarm for US spec but not quite there yet, although if it does not work on US spec then I'm probably wasting my time.
  20. Skippr1999
    4,216
    The ECU Dr worked on my 355.
